Brand New Titan 7000 4 Post Lift!
Pluribus
Skagit County, WA
What's your ceiling height? I'm looking at a four-post for storage (mostly) in a just shy of 10' ceiling height garage. Figure a lift is a lot cheaper than adding more garage!
rponfick
Looks like you could use a little ceiling cutout above the Camaro, unless your bedroom is up there. In that case, you could call the bump a coffee table.
Ralph
Shawn18jgr
LOL @ the coffey table! I have 10.7 ceiling height, 11 towards the bottom. The lift is maxed out, but enough to raise it up to get it off the locks. Still room to raise it more, and I can stand up under the lift, so it works. Actually, it is a Scion FRS, like the BRZ, small differences. Thanks guys!
rponfick
Sounds like you are set up. Couldn't tell from pictures if you were maxed out. I have to be careful not to put my car into the attic.
Ralph
6t7gto
bedford,ohio
Shawn,
what do you mean about the power unit?
I moved mine from the outside of the post to parallel with the lift.
david
Shawn18jgr
Mine sits near the wall on the garage wall side, and does not give me much room to move lift over 6" that I need to get it out of the 2nd bay area.
Udnudn
I am thinking of purchasing this lift from a seller in Troy Ohio. If thats the one you bought yours from, was your experience good with that company?
Thanks a lot
Steve
Vandalia, Ohio
