Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 02-22-2013, 12:55 AM   #1
Cabbie
Junior Member
Default How to find the right GE circuit breaker?
I have been trying to collect the needed parts to wire my garage. I have many options on the sub panel, and wires, but I cant seem to find the correct breaker for my main panel. Ive been told to find a breaker that is a 30A/50A quad. I have a GE main panel, and cant seem to find any breakers that resemble what has been described to me.
The 30A would be used for my AC unit, and the 50A would be for the garage. I have attached a copy pictures of what I think I should be looking for. My panel says I can use the following breakers:
THQP
THHQP
THQL
THHQL
TXQL
THQL-GF
THHQL-GF
TQDL
THQDL
Can anyone lead me to the right breaker?
Thanks,
Dan
Cabbie is offline   Reply With Quote
Old 02-22-2013, 01:16 AM   #2
Norcal
Senior Member
Default Re: How to find the right GE circuit breaker?
Those SQ D breakers pictured are listed or classified for any panel other then a SQ D Homeline model, they may fit but are always wrong in other then SQ D gear. GE twin/tandem breakers only fit GE panels & because of the way they are built ONLY GE twin breakers will work, as far as I know GE does not make a quad breaker but that is not a deal breaker for you.
You need a THQP230 & a THQP250, post a pic of your panel & there a a number of folks who can help you shift things around, this needs to be thought out as moving a multiwire circuit if present, to the wrong leg will not be good....
Norcal is online now   Reply With Quote
Old 02-22-2013, 01:32 AM   #3
bronc3buster842001
Senior Member
GE does not make a quad style breaker.... Just use 2 seperate breakers....
bronc3buster842001 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
