Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 02-26-2013, 09:26 AM   #1
BellyUpFish
Senior Member
BellyUpFish's Avatar
Default Turning a hose faucet into electrical on/off?
How would you guys go about turning this faucet into an electrical on/off? I've got some ideas, but it never hurts to ask.
BellyUpFish is offline   Reply With Quote
Old 02-26-2013, 09:28 AM   #2
Erampu
Senior Member
Erampu's Avatar
Default Re: Turning a hose faucet into electrical on/off?
Wouldn't that make water shoot out your outlets?
Erampu is offline   Reply With Quote
Old 02-26-2013, 09:32 AM   #3
BellyUpFish
Senior Member
Default
That's 1/2 the fun!
Old 02-26-2013, 09:39 AM   #4
Big-Foot
Senior Member
Big-Foot's Avatar
A Rotary On/off switch comes immediately to mind - something along the lines of this:
http://www.digikey.com/product-detai...806-ND/1202341
But.... Why????
__________________
Regards - Randy
http://www.GT-Forty.com
Big-Foot is offline   Reply With Quote
Old 02-26-2013, 09:40 AM   #5
KPSquared
Senior Member
Default
12 volt or 120?
__________________
My 1921 Shop and Brewery --> CLICK HERE
KPSquared is offline   Reply With Quote
Old 02-26-2013, 09:58 AM   #6
Iron-Iceberg
Senior Member
Iron-Iceberg's Avatar
Sprinkler valve.
Iron-Iceberg is offline   Reply With Quote
Old 02-26-2013, 10:04 AM   #7
KPSquared
Senior Member
Default
Are you doing like a "secret switch" sort of thing? Does this need to have water flowing through it or just look like a faucet?
I have a coupl ideas if you're going for a "secret switch".
A momentary on switch that would be pushed down and held on by the gate inside the valve. That would fire a relay for whatever you are running.
Drill a hole in the gate and mount a long, skinny pin to it that could flick a toggle on and off.
The rotary switch is probably the easiest.
If you want it it to still flow water, I have no idea.
__________________
Old 02-26-2013, 10:28 AM   #8
BellyUpFish
Senior Member
Default
I'm making a light or three..
The momentary switch was the first thought..
Old 02-26-2013, 10:46 AM   #9
hh76
Senior Member
hh76's Avatar
Quick warning in case you didn't know.
A normal switch usually incorporates some sort of spring that makes or breaks the circuit in a very quick action. This is to minimize arcing as the conductors are traveling through the area where the gap is small enough for the electricity to jump.
When I picture a gate valve, I think of the plunger moving really slow as the handle is turned. If that were relied on to close the circuit, it would allow the electricity to arc for quite awhile as the contacts were slowly brought together. It would also allow the user to stop the plunger just short of making a solid connection, letting heat build as the electricity tries to move accross.
I would try to find a commercially made switch that could be activated by the valve somehow. A momentary switch (button type) wired directly would not be a good idea for the reasons listed above.
Depending on the load, I would try and find a really small toggle switch that could be worked by a push/pull rod rigged to the turning of the valve.
hh76 is offline   Reply With Quote
Old 02-26-2013, 10:46 AM   #10
Kevin54
Senior Member
Kevin54's Avatar
Do you have any lathe experience? If not, you could find someone to make it, but if you do you can make it yourself. Use a push on / push off button type of switch. You can get "micro-switches. I'll snap a pic of one type in a second. You would need to take the packing out of the valve, and make a new piece that foes in that the handle would screw to, but underneath the packing nut, you'd have to have a small spring and a micro switch. Push down on the handle to turn it on and push down again to turn it off. If you can't find a switch small enough, you could make another housing that looks like the valve only a little larger. The bad part, you need to isolate the wires and connections from ever touching the copper and brass.
Another thing you could look at doing is go to Big Lots, Odd Lots or whatever it's called and pick up a cheap touch lamp, rip the guts out of it and use it in your setup. That way, all you would have to do is touch the lamp anywhere to turn it on or off.
Kevin54 is offline   Reply With Quote
Old 02-26-2013, 10:50 AM   #11
Kevin54
Senior Member
Kevin54's Avatar
Well....I can't find mine. I think the wife scarfed on that stuff. Anyways, here is a pic of a couple different types. The small round one could possibly work.
Old 02-26-2013, 11:21 AM   #12
BellyUpFish
Senior Member
Default
Ooh a touch lamp would be sweet..
Old 02-26-2013, 11:39 AM   #13
KPSquared
Senior Member
Ok, it has nothing to do with water. . .that's cool. I like the lamp idea.
I would just get a rotary switch, gut the valve and get creative with some JB weld. Just so you can turn the knob on and off.
Seems to be the easiest approach.
__________________
Old 02-26-2013, 11:42 AM   #14
KPSquared
Senior Member
Quote:
I think that would be sweet as well.
Check this out:
http://www.amazon.com/Carlon-AR135D-...N%3DB000BQWVE6
Or just pick up some old touch lamps from the thrift store and gut the wiring.
__________________
Old 02-26-2013, 11:48 AM   #15
BellyUpFish
Senior Member
Default
Yeh, just gonna make a few lamps for my office..
Old 02-26-2013, 11:51 AM   #16
Big-Foot
Senior Member
Big-Foot's Avatar
Pretty cool idea!
__________________
Regards - Randy
Old 02-26-2013, 11:52 AM   #17
BellyUpFish
Senior Member
Default
Quote:
Check this out:
I'll have to check that out.
Old 02-26-2013, 11:59 AM   #18
gayler
Senior Member
gayler's Avatar
How about mounting a micro reed switch inside under the plunger inside the faucet? This may not meet your needs, but there are many sizes and specs to chose from. http://www.pic-gmbh.com/files/pmc0701_ds_e_3.3.pdf
gayler is offline   Reply With Quote
Old 02-26-2013, 01:26 PM   #19
zkling
Senior Member
Agree with whomever said the rotary / clicker switch like you see on a common lamp. I think using a push button switch could be dangerous as you may over crank the valve and crush the switch. Flip side, you may not seat the switch button fully and cause the contacts to arc. Either could lead to a short and thus fire or shock.
Using a rotary switch would also be super simple to integrate into the valve body.
zkling is offline   Reply With Quote
Old 02-26-2013, 01:56 PM   #20
BD1
Senior Member
BD1's Avatar
Just get a 1/2 '' or 3/4'' normally closed electric solenoid valve for the water line. Pipe it in water line, add power and a switch.
http://www.amazon.com/Normally-Close...m_sbs_indust_8
BD1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
