jrfiero
Seems to me it doesn't, and here's why.
I have a 30 gallon electric domestic water heater as the heat source for my heated slab. You can see the building and system description in "Radiant Slab Recent Experience" here http://www.garagejournal.com/forum/showthread.php?t=185015&highlight=jrfiero .
It takes about ten minutes to empty the initial 30 gallons of ~100* water, then an element stays on until the system is no longer calling for heat and the tank is back up to 100. It took 15+ hours to raise the air temp from 50 to 60 last weekend, so having 10 minutes of preheated water doesn’t seem to mean much. During most of the time it is acting as a point-of-use heater. So heat output in BTU or watts and the physical size would seem to be the determining factors in choosing a heater, not the storage capacity.
When the slab is around 50* and starting to heat, the heater puts mid-80s water into the slab, I assume running on the upper 3800W element. At some point when the return fluid gets warm enough so the bottom 5500 element again kicks in and the heater puts mid-90s fluid into the slab. These are assumptions about the elements, I just received two 240V indicator lights and a switch for the convertible bottom element, so I'll know more later.
Thoughts?
Jonas
Thoughts?
Jonas
