Hey there I'm new here, I recently found that I have a lot of free time on my hands and decided to restore an old drill press I found on craigslist for cheap. Thought I'd share with you guys and hopefully learn a few things in the process.
Here it is.
The model number is 113.24501, from what I've found this means it was made in 1965.
No arc of shame
A close up of the chuck
This is the motor that came with it don't know much about it, it looks old enough to be original. The cord on it is pretty short ~3 feet long. and it doesn't have a switch, just plug it in and go.
Here is a close up of the motors info plate.
I followed this thread http://www.garagejournal.com/forum/showthread.php?t=51384 for disassembling most of it.
One difference between mine and envintho's is that mine doesn't have a hand knob(9) instead there was nothing in that spot, but after looking around I found a little pin hole and then looked inside and found a pin that the spring had a loop around, and with a little push on the spring loop it sprung off and the assembly slid right out.
sorry no pics of the process but you can see the pin in this photo after everything was out.
At this point I have everything taken out of the housing but the quill and pulley.
Here's all the little parts.
And all the big parts.
At this point everything that I've read says that the quill should slide out with a bit of a pull, but I some how got it stuck and its not budging from the pulley assembly. I've tried banging on it a bit to see if that could free it but its not budging, any advice would be greatly appreciated
here are a few pictures of the spindle pulley assembly that wont come off.
Here it is.
No arc of shame
