Should I replace my insulation
hdesert
In the course of my home remodel I have discovered that my 2x4 exterior walls have been filled with R19 batt insulation from 30 years ago. I am concerned that I am losing insulating value due the compression of the batt. Since my walls are all exposed at this point is it worth replacing the R19 with R13-15? The R-19 fits and appears to be in pretty good condition but it is compressed when the wood T&G siding is put on. Any thoughts on the best course of action? The home is in a winter climate at 7000 ft elevation.
Thanks for your ideas
high desert
volaredon
IL
nope its done its job this long/ put it back together and save your $$$$
cowboyjosh
Don't replace unless you intend on doing a closed cell spray foam (I don't recommend spray foam in walls for various reasons I still insulate my homes with batts; I do spray foam rim joist though).
One thing you MIGHT want to do with the walls open is take a can of Great Stuff and air seal any penetrations and the bottom and top plates of the wall.
Happy building.
Kevin C
Portland OR
I used R19 in the walls of my shop to get better sound deadening. You can put up to R21 to get the highest R value for that cavity depth (may bulge out thin sheet rock). R21 compressed down gets you ~ R15. R19 is probably a little bit better than R13 but not enough to call it R14.
Option 1: Put the siding back on and get approximately R13.4 from the batts.
Option 2: Run furring strips to space the wall out and get R19 from the batts.
Option 3: Buy new insulation, spend a bunch of cash and get the same or lower performance. :)
Option 4: Place a 1/2 to 1" foam under the plywood as a thermal break to increase the R value of the wall.
Effective R Wall Assembly R Values (16" OC, assumes 20 % of the wall is studs):
A few possible wall combinations.
1: No insulation is about ~ R4.6 (I put this in as a baseline for all of those that have sheet rocked, uninsulated walls.
2: R13 Batts ~ R12.7
3: R15 Batts ~ R13.7
4: Frame wall out to 2x6 equivalent with R 19 batts~ R17.4
5: 1/2 EPS Foam (R2) under plywood with r13 batts ~ 15.2
6: 1" EPS Foam (R4) under wood, R13 batts ~ R17.3
7: 2" XPS Foam under siding, R13 batts ~ R23.6
http://www.energystar.gov/index.cfm?c=home_sealing.hm_improvement_insulation_table
http://www.coloradoenergy.org/procorner/stuff/r-values.htm
PAToyota
South Central Pennsylvania, USA
It won't be less that the R13/15, so no, don't replace, you just waste $$
No leave it alone. compressed r-19 will give you a higher r-value than r-13. something in the neighborhood of r-15...
Nope and nope. Batt insulation works on the principle of "trapping" air. When you compress it, it removes those air voids and lowers the R value. So compressed R19 can have less insulating capacity than R13.
Tim The Tool Man
Lehigh Valley, PA
Yes and no. Compressing r-19 into a 2x4 cavity will yield a higher than r-13 r-value BUT less than an r-19 value. Compressing insulation and r-value are related to each other on a geometric bell curve. As you begin to compress the fiberglass your r-value per inch starts to increase but once you hit a point where there in no more captured (around 1/2" or less for r-19) air the r-value drops sharply.
The reason you don't see r-15 batts of insulation for a 2x4 wall cavity is simply a matter of diminishing returns on investment. It just isn't cost effective.
Here is a quote that I shamelessly stole from an energy auditor type website which explains what I was just saying much more eloquently (here is the link):
"How many of you have heard the statement, "compressing fiberglass insulation reduces it's r-value"? I'm going to assume everyone has, myself included. Well, the statement is correct, but the interpretation or application of it often leads to a wrong conclusion, for example: Stuffing extra fiberglass insulation into a wall cavity will reduce the walls r-value. That statement is most often wrong, here's why.
I found it confusing that compressing fiberglass insulation would reduce it's r-value, yet we could buy high density fiberglass at a higher r-value. So what is the difference between high density fiberglass and regular density that we compress into a tighter space? It turns out to be, not as much as we thought. The distinction is between the r-value of the fiberglass batt and its r-value per inch. Take for example, r-19 batts. They are nominally 6 1/4 " in thickness, thus an r-value of 3.04 per inch. Now, that's not the r-value our books give us, but it is what the numbers say and what the pink panther says. Now, install it in the normal 5 1/2" cavity and what do you get, 3.04 X 5 1/2" = 16.72, no. The panther says we get r-18, so what happened to the r per inch. It went up to 3.27.
So compressing the batts increased their r per inch, while reducing the total number of inches, resulting in a lower total r-value, and although the total went down, we can see that a limited amount of compression is not necessarily a bad thing. Where the turning point is, I haven't determined and obviously we can't squash the fiberglass flat and expect it to continue to increase its r per inch. But a little stuffing here and a little there can be a good thing.
Here is the panther's web page with the numbers I used and it does show that their high density for a a 5.5 inch cavity is actually R-21. Whether that's accomplished because they know how to increase the density better or because we need to add more insulation than the 6.25 in the example I started with, I don't know.
http://www.idimn.com/pdf/insulation/fiberglass/high-density/21149-D.pdf
I however do know I now understand the original statement better, I just hope my explanation helped you as well. Corrections welcome if I am wrong. -Bud"
Kevin C
Portland OR
PAToyota
bigbubba
Poplar Bluff Mo
Would it be possible to install 1-2" of foam on the inside walls since they are all exposed?
Off the top of my head I'd say it would be more of a pain than it's worth.1st you would have to reset all your electrical boxes so they sit flush with the new walls.And you will lose some inside sq. footage.
Kevin C
Portland OR
You can use mud rings on the boxes... At least that my plan.
