Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-15-2013, 02:16 AM   #1
jmillspaugh
Junior Member
Default Hanging OSB on Ceiling in shop
Going with 1/2 OSB on ceiling and walls. Question is do I need to run stringers on trusses or can I attach OSB directly to trusses. Its a 24X24 with 12' walls. Trusses are on 2' centers.
jmillspaugh is offline   Reply With Quote
Old 04-15-2013, 05:12 AM   #2
58Yeoman
Senior Member
58Yeoman's Avatar
Default Re: Hanging OSB on Ceiling in shop
I did mine right on the trusses and it's 24" on center. No sagging yet.
__________________
Phil
Life is what happens when you're making other plans...
58Yeoman is offline   Reply With Quote
Old 04-15-2013, 07:51 AM   #3
deter
Senior Member
either will work in a garage
deter is offline   Reply With Quote
Old 04-15-2013, 08:39 AM   #4
Clik
Senior Member
I've got a couple of sags, but no big deal.
Clik is offline   Reply With Quote
Old 04-15-2013, 09:04 AM   #5
Falcon67
Senior Member
Falcon67's Avatar
I'm at 24" OC with 7/16" OSB, no issues. Run it at right angles to the joists.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 04-15-2013, 09:13 AM   #6
dirttracker18
Senior Member
dirttracker18's Avatar
Quote:
Same here, no issues going on 5 years now.
Same some money and muscle and use 7/16" OSB
IMHO
__________________
"Success is when you reach a point in your life when you don't feel the need to go back and change things."
Johnny S.
www.LauraMyersPhotography.com
dirttracker18 is offline   Reply With Quote
Old 04-15-2013, 11:22 AM   #7
Highbeam
Senior Member
Since you sheet the roof of a house with trusses on 24" centers and 7/16" osb I would do it. You walk around on that roof with that spacing and even pile snow on it.
With the roof deck you also use these metal clips at the sheet edges. Do you guys use the clips?
Highbeam is offline   Reply With Quote
Old 04-15-2013, 11:51 AM   #8
ringneck
Were the trusses built to support a ceiling load? You can probably get away with attaching them directly, but if the trusses werent built to support a ceiling load you are weakening the structure. Adding stingers will only make it worse (more weight on the bottom chord).
__________________
ringneck
Shop Build
Garage Makeover
ringneck is offline   Reply With Quote
Old 04-15-2013, 01:40 PM   #9
JC23
Senior Member
JC23's Avatar
Same here.
JC23 is offline   Reply With Quote
Old 04-30-2013, 01:34 PM   #10
jmillspaugh
Junior Member
Cool thanks all for the info. I attached them directly to trusses and it worked out great.
Old 04-30-2013, 11:14 PM   #11
NUTTSGT
NUTTSGT's Avatar
Quote:
How about some pics ?
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 05-01-2013, 12:03 AM   #12
ddawg16
Senior Member
ddawg16's Avatar
Why OSB on the ceiling when drywall would be just as cheap....and not so flammable?
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 05-01-2013, 12:32 AM   #13
mark52621
Senior Member
I attached osb directly to the joists, and I should have used stringers. The boards of the joists are on edge and very narrow. It's not bad until you start the second row, and each row after that gets worse.
If the walls or joists aren't square, or you don't get the osb put on perfectly then you have to trim each sheet so you have room o screw on the next. It was a major pain to do.
If you're careful when putting up stringers putting up the osb will be easy.
mark52621 is offline   Reply With Quote
Old 05-01-2013, 02:56 PM   #14
Slednut
Senior Member
Slednut's Avatar
I put OSB on the ceiling of my patio cover, how does this happen?
Slednut is offline   Reply With Quote
Old 05-02-2013, 06:49 AM   #15
Coursey
I had it in my last shop, and i am using it again in this one.
Hang it direct to bottom of truss, and run it perpendicular.
Coursey is offline   Reply With Quote
Old 05-02-2013, 07:40 AM   #16
Blk88GT
Senior Member
Send a message via MSN to Blk88GT
I used 1/2" 4 ply plywood. The seams can be touched up with latex caulking.
Blk88GT is offline   Reply With Quote
Old 05-02-2013, 07:47 AM   #17
NUTTSGT
NUTTSGT's Avatar
Quote:
I think it's a trademark stamp or something. As much as it happens, there can't be a machine running with that many loose bolts or ones that have fallen out.
__________________
ERIC
Old 05-02-2013, 08:02 AM   #18
dbonne
Senior Member
dbonne's Avatar
I assumed when I hung 7/16 OSB that the sheets were 48 x 96. I learned the hard way that they are 1/8 inch shorter in both directions (for installing "I" clips in roofing applications). When I had 8 sheets installed, I was off of the framing member, scratching my head. 1/8 spacing is needed to keep on center!! I used 1/2 crown construction staples, those sheets won't come off without ruining them, something else I learned the hard way!
dbonne is offline   Reply With Quote
Old 05-02-2013, 08:09 AM   #19
Nowater
Senior Member
One way to "fix" a spacing problem is to sister a 2 by 4 even with the bottom of the trusses and then use the new 2 x4 as a point of attachment. No one will know it is there except for you! DAMHIK.
Nowater is offline   Reply With Quote
Old 05-02-2013, 08:43 AM   #20
Blk88GT
Senior Member
Nowater - great tip. Also a tip someone gave me AFTER I was finished. Wish I had thought of it during the process
You get pretty good with a belt sander after sheeting the inside of a large building... LOL
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
