JDishong
I need some advise from you machine-shop types ...
Problem: I need to join 2 identical OD/ID steel tubes ( end-to-end ) so the total length of the combined tubes is adjustable by a few inches. This would be similar to telescopic tubes but I must use identical tubes in this application.
Idea#1: Machine shop to create swedge end on one tude so it becomes like a telescopic joint. This is not ideal since it adds cost to the manufacturing.
Idea#2: see drawing below. This is a concept I thought might work but lack the knowledge of what it is called. It looks like a possible solution but I would like to research it by name .. any advice on what this style/type of joint is called ??? any other suggestions on how to make a similar combiner joint?
Thanks!
Thanks!
