gearheadglen
Hello, I am new to the site, but I have read quite a few threads and find the site to be a wealth of knowledge. I currently own a Craftsman 30 gallon oil-less compressor from 2002 and was getting tired of the noise level. I wanted to upgrade but was on a tight budget. I recently bought a 1985 Craftsman 2HP 20 gallon (220volt) horizontal portable compressor model 919.176320 off craigslist 7.5CFM @90psi. The tank had some heavy surface rust and after reading some posts on here I got concerned about safety. I then thought why not mount the oil lube motor and pump on my 30 gallon tank since I know I have drained it after most uses and it has been well cared for. My tank is rated for 150 PSI and the 20 gallon is rated for 125PSI. My idea is to cut the mounting plate off of the 20 gallon tank mount it on top of the 30 gallon tank using the components from the 20 gallon setup to match everything correctly. The only thing I would have to fabricate would be the lines to the tank which I was going to do out of copper with compression fittings. I was also going to use rubber washers between the mounting plate to minimize vibration. Has anyone else done something similar?
