Cube *****, I would get the kit with the different adapters
The cube works well on very few calipers in my opinion. When the cube is easy to use , you most likely could have used a pair of needle nose to rotate the piston. I prefer the kit with the adapters. Up here in the Northeast I prefer to replace calipers more often because the piston tends to rust up and stick from the salt and slush we drive in.
I used the cube every day when I worked at Honda. A 7.00 tool compared to some 50.00+ tool that does the same thing but with discs instead? I admit its nicer.. But I never had a problem with the cube. I guess my main reason is since I mainly work on heavy stuff, I didnt want to spend the money for something to work on cars for a short time.
, cheap, takes up less space than a 3/8th dr deep socket. It's a great on the road tool for when you go help a friend do brakes
I have the cube and don't like it much. I like this much better.
http://www.tooltopia.com/sunex-tool...utm_term=SUN3930&utm_campaign=pricegrabber_r1
