Ideas on how to move a shed.
mudcat
Wisconsin
I have a small 6'X7' shed in my back yard that I need to move about 30'. It sits on 4X4 skids and the path to the new location is very level. I am looking for ideas on ways to easily and cheaply move it. I will have the help of one other guy. I no longer have a garden tractor and my pickup wont fit. My only idea so far is to roll it across PVC pipes. Hoping for some other ideas or tips. Thanks.
78Bird
Charlotte, NC
do you have a come-a-long? if you have something heavy enough to latch onto, enough sturdy rope, some rollers, and a jack to get it up on the rollers it should move easy enough.
NUTTSGT
Northern Central Ohio
I think the roller is a sound idea.
The only thing that would make it easier is to lay a couple sheets of OSB or plywood down to to roll on. You would just have to leap frog them like the pipe rollers.
ADSR
This^^^
lisiecki1
SE Texas
Moved my 10x16 with a 4 wheel drive and a good length of cable.
Have any friends with a truck that has a winch?
Gary S
Bismarck, ND
When I had to move my 8x10" shed, I simply connected my come-along to it and tied the other end to a fence post in the direction I wanted the shed to go. It took me a few minutes to do it all by myself.
Ryf
Southern Ohio
I would mount a 2x4 across the bottom corner, this will give you a place to put your iron leverage bar and not damage your building, the iron bar I am talking about is about 1 1/4" thick with a stab spike on one end and a mushroom flat spot on the other. its hexagonal and its strong as hell, you stab sharp end in the ground and lever against the building to get your movement. as long as your dirt is pretty hard this would work well. if your dirt is soft, you will still want the wood board along the building, but use a 2x4 and instead of stabbing in, slip under a little and lift, this will rocker the weight away from you, more work, but cheaper.
if its level, you said it is, jack it up, put 2x8's down flat, pvc on top, way less rolling resistance than soil, but you dont' want to get going too fast or be on a slope if theres only two of you. you'd need 4 2x8x10ish and use two under, two ahead and roll on. on PVC and boards, you should be able to move it by hand though.
fotoflojoe
Boston, Ma/South Shore
I was thinking the same thing. However, I'd thought of using several 2x4s laid on their flats instead of OSB. Might be cheaper, and more likely to have a use for the studs after the fact.
Sureshot
Bridge Creek, OK
This is being way overthought. By the time you rigged up all this other stuff you could be done with a couple 3 or 4" posts or pipes. You will be shocked how easy it will move. If the ground is soft lay a couple 2x4's to roll on.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Get some buddies and buy some beer. Empty it out pry it up a little, run some straps under it and fasted the ends of the straps to a 2x4 so the 2x is about waist high. This way everyone can lift without bending over. Move the shed, crack open some cold ones, and enjoy the rest of the day.
zcar751
Knoxville, TN
I vote to use a skylift. Might be a little pricy but just imagine the neigbors standing around watching.:lol_hitti
DanarchyCustoms
Hudson Valley, NY
We had to move a few sheds a couple times and we always use some sort of roller, a come-along, floor jack to initially lift it, and a 2x4 as a lever to get your final placement. Each time it only took 2 people to move it.
Also as a precaution, make sure it is sturdy enough to move in the first place. :thumbup:
Deltarat
As said the rollers are the way go. We set a 6 room house with rollers, when the lowboy trailer would not fit where they wanted it.
TOOL_MONGER
So. Dak.
Could of had it moved in the time it took to read this...
I had to move a 12x18, full of ****, 40 miles... over width permits, had to borrow a 30' Gooseneck trailer... commercial plate permit... cribbing to get it 4' in the air... I love a challenge, but wish they weren't all brought to me to do by other people...
I think you have it figured out... in the end a simple spud bar jabbed into the ground can move most things... I moved several smaller sheds by just backing my pickup's rear bumper up against the wall and move away..
Good Luck
wvjunkie
4 - 2x8x10s and a dozen concrete test cores, transferring the ones that roll out the back to the front.
Moved a 12' x 16' LOADED building by myself with come-alongs about 75' with a left turn in the trip. At some places stopping was the problem !
mudcat
Wisconsin
Thank you for all the replies. I worked on getting the shed emptied last night and will be moving it this weekend. There is a tree near the new location that I could use as an anchor for a come along. I think I will start by trying to pull it with the come along and if that doesnt seem to be going well I will lift the shed and roll it. It is a pretty well built little shed that came with the house. They put the shed right in the middle of the backyard, and it just looks out of place. Its new location will just be temporary until I can build a bigger shed. Once the shed is moved, I am re-grading the whole yard and hydro-seeding. Any one have any advice on hydro-seeding. Thanks for the help.
Jsf721
LI, NY
Forklift rental. It is already on skids. Just get fork extensions since its so big.
NUTTSGT
2x4s would be cheaper and the OP might already have them on hand or any other 2x lumber. Plywood or OSB came to my mind first as that's how I moved my tool box across the driveway.
I was coming back to mention this. I was at HD yesterday and they were loading or unloading a prebuilt shed out front with a forklift and straps. . . . almost looked like the Squirrel Football League. :bounce:
burleyfarm
Northern Michigan
we've rolled sheds around using all kinds of things but 6" round cedar post were the easiest. The thing might as well been on wheels
I moved a 16 x 20 foot garage using cedar fence posts under the sill plate and a come-a-long attached to the hitch on my pickup truck.
I moved it about 40 feet, spun it around and set it on a new slab.
Did it all by myself while my wife was at work. Boy was she surprised.
Vegaman_Dan
Pacific, WA
While you're moving it, this is a great opportunity to consider other storage optionsyoucan do at the same time. Elevate it 18" or so on concrete piers. You can reuse those PVC pipes by mounting them to the bottom of the frame of the shed floor with plastic caps on the ends. I store my 10' lengths of angle iron and flat bar stock under the shed out of the way, yet still accessible. It's also a good spot to store other items like tires if need be. A simple step up in front of the door is worth the hassle.
Also consider if you can add a lean to on the outside. You might be able to add a small 8' by 4' lean to section on the side just large enough to hold a motorcycle, riding mower or similar. If you surround it with plastic or wood lattie work, you have good storage for tires, gas cans, body parts, etc, all while keeping it out of the weather, and out of the garage taking up space.
mudcat
Wisconsin
Well the shed moved way easier than I ever thought. I jacked up the shed and put two 2x4's under the sheds runners. I then used a landscape timber I had to lever the shed across the 2x4's. Moved really easy and is in a much better location. Again, thank you for all the suggestions.
Steve.S
Cincinnati, Ohio
I moved an 8 x 12 using PVC pipe rollers and a comealong.
A friend moved his by covering the ground with sheets of plywood, then jacking up the shed and putting wheel dollies under each corner:
This worked well for him as he needed to rotate the shed 180 degrees and move it to the other side of his yard.
