Exterior Insulation around Foundation
sands35
St. Joseph, MI
Reading through the guidelines on frost protection. (garage has 42" footers, looking at it more from an energy savings, then from the frost protection needs).
http://www.toolbase.org/PDF/DesignGuides/revisedFPSFguide.pdf
What is common for a DIY job to protect the insulation board above and below grade?
Cement board looks like the simplest with an AL flashing cap. What about some of the spray/roll on stuccos?
Any experience with this?
burleyfarm
Northern Michigan
I'm doing the same thing this fall. One inch foam with brush on cement coating. Flashing/drip edge between the vinyl siding and foam. I want to reduce the amount of heat transfer from my heated garage to the outside in the winter. My foundation is only three blocks high, sitting on a concrete footing. I'll have on average 6-8 inches exposed. I'm going down the 24 inches to the top of the footing but have to wait till fall after the flowers in the bed next to the garage have died back.
Wish I would have done this before pouring the concrete drive as I won't be able to insulate 36 feet along the front of the garage.
Has anyone else done this?
NUTTSGT
Northern Central Ohio
sytro industries makes a few coatings for above grade, no reason to worry about it below grade.
I disagree about not worrying about below grade. If you plan on heating continually the garage, you want the concrete floor to act as a heat sink and absorb the heat. By insulating the foundation and below grade, you create a thermal break to keep the cold away.
fpianka
By "no reason to worry about it below grade," I wonder if he meant the protection of the insulation with the brush-on cement, and not the complete omission of insulation below grade. Related question: what insulation/vapour barrier/geotextile materials should go below the slab and in what relative position? Would insulating under the slab reduce the thermal mass available to retain heat, provided the perimeter is insulated properly?
1233user
CT
I had a local sheet metal shop bend up some stainless steel sheet metal to protect the styrofoam insulation that was above grade on my garage addition. I thought about what to do with this for awhile, and decided that the stainless was the only thing that would offer strong enough protection and I would never have to worry about it again. It was a little expensive, but it was really easy to install, and won't require any maintenance in the future.
1233user
CT
1233, what does that look like now that it's done ?
Well, the garage isn't built yet, just the foundation and backfill done. I don't have any pictures with it backfilled, but I can take some. I think it looks great. The stainless weathered a little bit over the winter, so its not as reflective as it was when new. Unless you look at it closely, you don't even know that your not looking at the concrete. I'm very happy with how it came out.
burleyfarm
Northern Michigan
I'm pretty sure that's what he meant.
2" of foam minimum, 4" is better especially if you have radiant heat. It should go down to the frost line. Above ground needs protection.
srode
That's a great patch for termites to follow and have a good feed undetected.
ed_h
I've used the Styrofoam brush-on stuff. It looks good and lasts if you can protect it. It is a little fragile.
ed_h
Agreed. I see the benefits of below grade insulation, but I would be afraid that it would destroyed by ants and termites in just a couple years.
I've seen field mice hollow out a little pocket and nest in the rigid insulation, but never saw evidence of insect attack. I think the implication was that termites would travel undetected under the insulation to get to wood.
jkeyser14
(rural) Maryland
Carpenter ants love the foam because it's the same consistency as rotted wood. Termites love it because it gives them a protected, easy to bore through path to various parts of your home.
http://www.ornl.gov/sci/buildings/2012/Session PDFs/153_New.pdf
Here's a good technical paper that details the need for specially treated foams. They have mostly done short term tests on the foams, with some promising long term results, but if you look at how they define "long term" it's "3 years or greater". I don't care if the foam is good for 3 years, I want to know if it will be good for the life of the structure.
