Garages, machines, and talent
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Hey guys......I'm kicking something around and want to see what sort of interest others would have in doing it. If I would come up with some sort of a spreadsheet with a list of machines on it, would you be willing to put up your name, what machines you have, and what capabilities you have, and a State only, no town location?
The reason I ask this is that although it is summer and everyone should be out in the garage, (or banging the neighbors wife :lol:) I think with as many members we have now, there is a lot more activity in the Fab Forum. With that, there are many members that don't have a lathe, mill, grinder, and so on, but at times need something made. If they knew who to contact, or knew who had what, then they could get in touch with a member or two and get their parts fabricated. I'm still thinking about the spreadsheet and how to post it up so ones could get their name on it. I may have to check with (well hell..a case of CRS at the moment) the member who made the spreadsheet up about the garages, with the size and so on that you can search for. I'll remember it later.
If the members would at least list the State they are in, excluding "confusion", then other members in the same state would more than likely PM the member that is close, or if close enough meet them in person, or even mail or ship things back and forth.
As it stands now, the members may know one or two with appropriate machinery to get something done, but don't want to ask for them to do something. Some may not want to ask other members for help in something because they figure that "he wouldn't want to machine something for me".
And don't get me wrong, I'm not implying that ANYTHING be done for free. What is discussed in PM's is your own private business. Any monetary discussion is up to the members in private. But if you want to throw a freebie to someone, that's okay too!!! :spit:
But I wanted to toss a line out to see what I can catch, and if it's worth it, I'll get with the Mod(s) or Ryan and see if we can get it made a sticky post.
Just like myself, I have a mill, lathe, press, shear, but if I need a piece precision ground, I don't know who to ask without just walking into the room and shouting it out to everyone. If there was a list, I could look, see who's got a surface grinder, PM the member to see if he (or she) would be interested in a little side work for some coin, and be done. I would MUCH rather exchange money between members, or even Barter between members if one would choose, than to take my chances with some shop around the next town or whatever.
Think it over guys and let me know what you think. If you think it would be a good idea, then I'll figure out some sort of spreadsheet or chart. Or if you have any ideas to add to it or take away from it, we'll consider every and all ideas and we will move forward. :rocker:
Who's with me?
aggierailroad
Houston, TX
Great idea - for the bigger states, would be nice to break it down to cities (it's an 11 hour drive to the other side of Texas for me)
I'm in Houston, Texas. I don't have much, but happy to help out.
Metal:
Millermatic 211 MIG
Drill press
Grinders, cut off tools, etc.
Dry cut saw
Wood:
Miter saw
Circular saw
Jig saw
Pocket hole jointery
Router
Ability to do jointery and big layups up to 6'x8'
Electricity:
Soldering irons
Multimeters
general tools
astroracer
Mid_Michigan
I'm in. I was trying to be worried about disclosure, you know, "look what this guy has" kinda stuff. No reason to worry now though, you can see just about every piece of equipment I have if you read through my build threads...
Here is my list:
The FrankenMill
Jet lathe
Smithy combo lathe/mill
drill press
30T Hydraulic Press
Pro-Tools tubing bender
HF tubing roller
Small tubing bender
Pro-Tools metal benders - Large and Small
HF Bead Roller
Beverly Shear
Woodward Fab 8" shear
Woodward Fab Shrinker/Stretcher
Woodward Fab 4" metal brake
HF 3 in 1 machine
Homemade Sheetmetal Bender
Pexto 37" shear
16" Scroll Saw
Cabinet style sand blaster
Hopper style sand blaster
Combo 6" Belt/Disc Sander
Airco Dipstick 160 Mig Welder
Lincoln 135 Tig Welder
Plasma Cutter
2 post hoist
Engine Hoist
Numerous spray guns, grinders, die grinders, vise grips, c-clamps, bar clamps and what-have-you
Router and table
Router speed controller
In addition too:
H/V Bandsaw
14" Vertical metal cutting Bandsaw
14" Chopsaw
Swag Press brake for the hydraulic press
2 Stage Air Compressor
Bench mounted sheet metal hole punch
2 homemade Chassis Fab Tables
Automotive Wiring Work Station w/ Soldering/Heat Gun Station
Soldering Guns
6" Carbide Grinder
5" and 6" bench grinders (Use 1 strictly for Tig electrodes)
Amitygravel
Claremont Illinois
I'm in Kevin.
My list is pretty short.
Access to a forge and two Little Giant Power Hammers. (Think damascus steel here, billet form or barstock. And the option of surface ground. )
Burr-King belt grinder.
Baldor Buffers.
All this equipment is actually in Central Illinois too , not at my home. But I do have quick access to it.
Craig
kazlx
Tustin, CA
I'm down. You could also add in zip code or county, which would narrow it down but still give a location people could search. I'm in SoCal. Kevin...I think on google maps you can do se sort of location map and add info and locations. I've seen it done on other boards I'm on for various things.
Edit: Found it. Go to Google Maps, click on my places, create map. You'll get a box for a title and a description and right above that, there is a link that says collaborate. Click on that and it gives you a couple more options. Like I said, I've never done it, but I've seen the results and I think it would be ideal for what you want to do. People can just find their location on a map and see where others are on the map. If you use generic locations, you can still stay somewhat anonymous and use your screen name for your location. Then, people can locate you through the board.
Bridgeport Mill
Logan 11" lathe
Drill press
Big fab table
Portaband with Swag table
Miller 180 mig
50T press
Cold cut chop saw
Hypertherm 1000 plasma cutter
Soon to have done CNC plasma table
Clamps, grinders, etc related tools.
rsanter
visalia ca
Central valley CA
Mill
Lathe
Mig
Tig
Arc
Plasma
Grinder
Box&pan brake 4ft 16ga
Table saw
Shaper
Jointer
Planer
Sander
Valve grinding and engine building equipment
Precision measuring tools
Drill press
kkroger
KC MO area
I have a
12x36 Lathe with Gap Bed to swing up to 17"
Mill Drill... Meh
Oxy Fuel Torch, Heat and Beat,
GMAW
GTAW
SMAW
Plasma Cutter
bench and angle grinders
Drill Press
Chop Saw
Sawzall
2 Ton hydraulic Crane
!0 ton and 4 ton porta powers
Air Compressor
Bead Blast Cabinet and Dust Collector
Shop Vac...
Many Hand tools
Air Tools
Numerous Clamps and Engine related tools
I can fab pretty much anything.
Design most anything
Build most anything
Future Equipment
Larger Building (40x60)
Twin side Post Hoist
JD2 Bender and dies
Tubing Roller
CNC Plasma Table (BUILDING FIRST)
Build Pro Fab Table
Eventually a CNC turning center
and a CNC Machining center and some lincenses...
Then I go back into Business...
bczygan
DETROIT! Arsenal of Scrappers
Great thread. But this is going to be complicated to go through. If we had a format where you could not just list machines, but what capabilities you have for production, that might make more sense. That makes it even more complicated. We need an online spreadsheet where people can enter their own data.
My garage shop is just a-building and not worth mentioning yet. My personal capabilities are very minimal.
But I work in a 1 1/2 man (I;m the 1/2 man) machine shop that can do many things including aircraft production. We share space with a large grinding machine and we know a network of small shops with different capabilities.
K
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That's what I plan on doing if there is a lot of favorable response, although I may have to recruit some help :lol:
I know myself that I would send some items to others that I don't have the capabilities of doing myself yet.
Kick up any ideas that anyone may have
deere2210
Kevin, great idea! I'm in..
Southwest Ohio
Tormach 1100 CNC w/ 4th axis
Haas TL-2 CNC lathe
Haas VF-2 (on it's way)
Mig/Tig
Powdercoating
Laser Engraving
Solidworks 3D modeling/design
Prototyping and prod runs small batch or large (coming)
bczygan
This is SO a good idea.
Even commercial shops are NOT jacks of all trades, nor do they have all capabilities.
One of the most important capabilities, that the guy I work for has, is knowledge of all the other shops in the area. When he gets a job that calls for, say, laser etching as part of the work, he knows who to price it with. He can then quote the job and sub the laser work out. And if he gets a job that is too big for us, he knows who to get help from. Or sometimes, if it is work he doesn't want to do, for one reason or another, he will either sub it. or give it away entirely. Sometimes you have the capability but just don't like that kind of work and prefer to do other things.
So, my little home shop has (Operable and ready for work) the following:
Kalamazoo horizontal bandsaw Model 610
Buffalo floor model drill press
Numerous Sears block grinders in 1/3 and 1/2 HP
Baldor 1/2 HP pedestal grinder
Greenerd 5 ton arbor press Model #4 3/4
Sensitive drill press 1/4HP Dumore Model #37-011
Future equipment capabilities (Need installation and hooking up):
Trinco 24" blast cabinet Model #BP24
Bridgeport vertical knee mill
Parts washer
South Bend 9x48 lathe Model A
South Bend 10x36 lathe Heavy 10
Camelback drill press
Delta Rockwell 17" 1HP floor model drill press
HF "H" press
Campbell Hausfeld 6HP 60Gal compressor
Walker Turner disc and belt sander Model #SM700
Various woodworking machines
Small anvil
Welder
Bill
kazlx
Tustin, CA
Southwest Ohio
Haas TL-2 CNC lathe
Mig/Tig
Powdercoating
Laser Engraving
I need to be closer to this guy lol. You have the machines on my wish list!
sharkytm
Pocasset, MA
What the heck:
Pocasset, MA (Cape Cod)
Metal:
Millermatic 210 with spoolgun
Scratch-start 180A Stick/TIG
Rockwell 17" DP
Thermal Dynamics Cutmaster 42 plasma
Grinders and supplies in 4", 4.5", and 5"/6".
O/A setup
2 bench grinders, several vises
5HP/80Gallon compressor
Wood:
DP as above
crappy table saw
10" chopsaw
Drills of all sizes
Several kinds of sander (belt, RO, etc)
Auto:
Full sets of just about everything you could imagine for basic work. No lift.
garboui
Southern Ontario
Hamilton Ontario area
Listing abilities:
Engineering design: mechanical, electrical, automation
CAD:solidworks, autocad
General welding and fabrication. Anything that doesn't exceed 1/2"stock and requires machining.
Thumper68
Duluth MN
Northeast MN
Shop is a mess but buried somewhere in there:
Metal
OA setup
mig welder Lincoln sp250
many right angle grinders
floor drill press
3+ vises
clamps/straps
horizontal bandsaw
Wood
5 hp table saw
plainer
8 in jointer
router table and 100's of bits
lathe
12 in power miter saw
12 in radial arm saw 220 volt
drills, chisles, planes, handsaws
auto:
Jacks
jack stands
hand and air tools
parts washer
cherry picker
adding soon
post crane
outside 5 ton hoist
500 acre lake with crappie, northern, bass, walleye, sunnies/bluegill
Jim Johnstone
Brantford, Ontario
Brantford Ontario Canada
Engineering design Solidworks in particular
Hydraulic OD/ID cylindrical grinder
Drill presses
Hopefully by the end of the summer I will add a surface grinder mill and lathe.
At work I have access to everything short of a cnc lathe. Wire edm is a real treat to have access to!
deere2210
Little bit of both.. Work a different industry day job and and own an LLC where I spend late evenings/weekends in the home shop trying to design/build the next must have widget. Burning the candle at both ends.
Deere are you in business or just hobby?
JonnFX
Arizona
Great idea, Kevin. Looking forward to what you come up with, to organize this.
I have a wrench or two.
tymbo
West Chicago
West Suburbs of Chicago:
wood:
Striebig vertical panel saw(sold but not picked up yet)
Ayen 23 spindle line boring machine(for adj. shelf pin holes)FOR SALE!
5hp 3ph powermatic table saw FOR SALE!
cabinet lift (for installing upper cabinets)FOR SALE!
shop panel carts(3)FOR SALE!
all equipment is under power and operational.
Tim
kazlx
Tustin, CA
I added myself and Aggie, just since he had an easy location and list to copy paste. I just dropped my pin in the middle of my city. I can set it up to invite people though so they can add their own location. The map is not public. You need the link to view it, but anyone can edit the map. Collaborators can also invite anyone.
bullnerd
Jersey
Very cool, Congrats on your new machine. I have a Prototrak MX2,would love to someday move up to a VMC.
LShee778
Central PA
Central PA:
Personal Tools:
Solidworks 2013 (and my brain)
Hobart 140 Handler
Drill Press
Lots of Automotive repair tools
Grinders, Saws, etc.
Have access at work to:
Miller 252 MIG
Miller Diversion 180 TIG
Horizontal Bandsaw
Vertical Bandsaw
Drill Presses
Various other metalworking equipment.
I also work closely with some large sheet metal/structural steel suppliers that I can get very good pricing from. They all have laser/plasma, press brake, shear, and powdercoat capabilities as well.
Jason Lister
Coarsegold, CA
I am in Coarsegold, CA
~4x8 CNC Plasma Table w/ Hypertherm 65
~251 Millermatic Mig
~Dynasty 200DX
~7x12 Jet Bandsaw
~20 Ton HF Press
and more associated hand tools
drmarkr
Tucson
Looks good.....can't figure out how to edit to add my info though??
Zeppe807
Sonoma County, Ca.
Sonoma County, Ca
Metal Machinery
*Small Jet Vert. Mill
*9" Atlas Lathe
*Miller 251 w/spool gun
*Lincoln SP175 Plus
*Miller Thunder bolt AC/DC - SMAW
*Drill Press
*Torches
*Portable Band Saw
*bench grinder
*Anvil
*Forge
*misc hand tools
Wood Tools
*10" Table saw
*Router
*Miter saw
*Skilsaws
*CHAIN SAW <--my favorite
*misc hand tools
General
*Air Compressor
*Work Tables
*electrical tools
*mini shop crane of sorts
Experience
*grew up on a ranch (learned how to fix other's fixes correctly)
*machinist/machine assembler
*pump mechanic
*Degree in Bioresource and Agricultural Engineering
*Construction Engineer
**I guess this is mostly general info that can be found off reading other post of mine.
I enjoy helping and a good challenge.
Joe Zeppe :beer:
K
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Wow....This has generated some pretty good responses. I'm going to start working up a spreadsheet that can be put online and anyone can access it to update it as needed.
I think I may have to get in touch with ShopNut and ask him a few questions as to how he did a few things. I know most definitely that a lot of members will find this useful. And as soon as I get a few of my projects done, I'm going to have to find one member around that has a surface grinder.
LShee778
Central PA
Great idea for the thread Kevin. An interactive spreadsheet like in the sticky for the garage gallery would be cool. Not sure how much work that is though.
kazlx
Tustin, CA
If people are actually interested, I can start taking PMs with e-mail addresses. Then I can just add you to the collaborator list and you can edit the map. I just did it to test it out and see if anyone was interested.
LShee778
Central PA
Just added myself. Not too hard. Just gott hit Edit and then right click where you want your placemark to be added.
JonnFX
Arizona
Kevin, should we post on here and/or do the Google Maps thing?
kazlx
Tustin, CA
Nice, this looks like it might work pretty well. I wonder if there's a way to search the text in the map location details?
drmarkr
Tucson
Did the same. The "edit" button wasn't there last PM. That map works excellent for this! And I think when you save it to your places, it stays updated when anyone adds themselves in there.....
Steve from Socal
Hutchinson Ks.
OK Kevin,
Here is the list of equipment in Hutchinson Ks.
Machine tools;
K&T 320TF-17 Horiz/Vert mill 20 HP 68X17 table 40X18X20 envelope
K&T 310 S15 Universal Horiz 10HP/BP 2J vertical head
K&T 2H Plain Horiz/Vert mill 5 HP
Monarch Series 62 2013X102 lathe 20HP Taper, Versa Mil attachment
Monarch Model 10EE 13X30 lathe 5 HP Inch/ Metric, Taper
Cincinnati Bickford Super Service Radial Drill 15 HP #5MT Two bases V style
Cincinnati Bickford Radial Drill 5 HP #4 MT tilting box table
Thompson Surface Grinder 20X60 envelope 15 HP spindle
Blanchard Surface Grinder Rotary surface grinder 37 inch diameter
DoAll 1612-3 Vertical Band Saw Servo-Hydraulic feed
Buffalo 20" Drill Press production table
Walker Turner 20" Drill Press
Welding/ Fab and Coatings
20 X35 Sand Blast Room with 1 Ton Bridge Crane
20X35 Paint Spray Booth with supplied air
3 Ton Bridge Crane 35X80
3 Ton Bridge Crane 35X180 with three bridges
Several jib cranes 1/2 Ton
Miller TIG MIG Stick and Oxy Acetylene torches
Hypertherm 65 Plasma Torch
Several pedestal grinders, disc, belt and wheel
36X134" ground Cast Iron Surface Table
Material Handling
Hyster 24K Fork Lift Pneumatic tires
Hyster 7K Fork Lift Pneumatic tires
International 4700 Service Truck Liftmoore 6036 6K crane
Several Trailers to 20 tons
Grove Scissor lift 8X15' platform lift to 47 feet rough terrain all wheel drive
In addition I have 20K+ sq ft of flex space under roof 24X16' entry doors suitable for long or short term projects.
Steve
bobadame
I'll play,
Fab equipment:
40" throat English wheel
Helve hammer
32" throat pneumatic planishing hammer
bead roller
Nibbler Junior
52" shear
52" brake
corner notcher
arbor press
strippitt clone single station quick change punch press 36ton
Gabro pneumatic punch press to 3.5" dia.
Chip making machines:
Lagun FTV2 mill
Pratt & Whitney 10 x 40 engine lathe
Gallmeyer & Livingston surface grinder 8" x 16"
Vertical band saw
Horizontal band saw
Belt grinders and buffers
Wood:
table saw
jointer
thickness planer
Welding:
300 amp TIG
oxy/acet.
Material handling:
2500 lb. Big Joe
overhead crane about 6000 lbs. capacity
9000 lb 2 post lift
CNC:
MCV-OP Leadwell Vertical Machining center (needs a bit of work)
Software: Bobcadcam V-23, V24 lathe and mill
