New Garage
Dupree
Agawam, MA
I’m trying to decide how to seal the floor in my new garage. There is so much to learn here! I’m leaning towards the Legacy Industrial HD6600. It seems more to my taste than epoxy. Before I jump in, I have a few questions: The floor was poured two weeks ago. How can I tell if my floor is ready to seal?
Is there anything I should / need to/ do with the saw cuts before I apply the sealer?
How slippery is this stuff when it is wet?
Thanks For your wisdom!
Cheers :beer:
Shea
California
Check with Legacy first, but I believe the HD6600 can be applied to green concrete. No waiting necessary. No prep is needed for you saw cuts, just apply right over them.
LegacyIndustrial
deerfield, IL
Make sure it's clean and go for it.
(2) coats minimum, keep a wet edge.
Don't be stingy but no puddles either.
It can be slippery on a smooth floor.
Use our Soft-Skid, 1/5th bottle per gallon of topcoat or (1) bottle per five gallons.
Use the extra-fine.
D
Dupree
Agawam, MA
Thanks for the prompt responses guys! That sounds good! My floor is 28x32. The calculator on the website says I need 3 gallons. Is that Per coat? or will a 5 gallon bucket do me? Is the heat and humidity a problem? It's both here lately...
LegacyIndustrial
deerfield, IL
per coat.
Yes, a five gallon should do it as your last coat will go much further than the first.
Apply later in the evening or early.
Don't do it in the heat of the day.
It is WB so the air moisture (humidity) should not change it. It may take a little longer to cure.
czr12x
WI/IL stateline
my concrete was power trowled.... excuse my spelling. i have two coats of the hd6600 on now. still have half a 5 gallon bucket. do i need three coats or is that overkill?
czr12x
WI/IL stateline
Thanks. Been a long day. Can I redcoat in the am. About 15 hours from now? Or do I have to get that 3rd coat on tonight. Will post pics when complete..
anthonyc12
why are you doing it by yourself, let someone experienced so this for you. DIY can cause you lots of mess.
D
Dupree
Agawam, MA
After a lot of research, I decided to go with the HD6600 sealer. I am pleased to say It is exactly what I wanted. I was looking for a product to seal a new garage floor. I didn't want to spend much money, I didn't want to wait months for the concrete to cure, and I didn't want to deal with a primer and a two-part epoxy. About two weeks after the floor was poured, I spent a day smoothing the edges and washing the floor (mostly dust). Then I woke up the next morning and started rolling. I had to wait until evening for the temperature to drop a bit, then I put down a second coat. The floor is about 900 sq.ft. I bought a 5 gallon bucket, and I have almost a gallon left. I was worried about durability, but I am impressed. I slid a metal workbench across it, and it didn't leave a mark. Also, I like the way the gloss brings out the patterns and shades of the concrete.
Here are some pictures: The first is before, and the others are not.
Cheers
Shea
California
No, they have a different product that can be used on the exterior. HD -6500 I think? If you check their website you can find it.
cnyeco1
Oklahoma City, Oklahoma
What does this 6600 sealer protect the floor from? I read the info on the website and it say it is water based. Will it breakdown after years of traffic or need re-coated at some point?
Looks like there are a few choices in different price ranges of sealers on their website. How to know which one would best suit me.
Thanks in advance.
LegacyIndustrial
deerfield, IL
Zippercat/Shea: Yes, the HD6500 is perfect for exterior and can be tinted for an opaque look if desired.
Dupree: Great job! Send me a PM with your shirt size and address.
Cnyeco1: Let me know what condition the floor is in and the activity level in your space.
HD6600 is not your common acrylic and will not automatically need to be freshened.
It's longevity is based on activity and maintenance.
