walker floor jack restoration
fireman164
owasso ok
This is a all mechanical floor jack the pat. date is 1922 not sure when it was made, this is the day I picked it up, it was rusted and frozen solid.
F
fireman164
owasso ok
Here someone screwed a nut and bolt through the back of the main bar that runs through the jack , not sure why its not possible for it to go that far through
F
fireman164
owasso ok
finally got it completely dissasembled, notice the mail arms are bent I am guessing someone overloaded it at some point in the last 80 yrs, I had to use new steel, didnt want to but it was bent bad enough that the jack looked funny
F
fireman164
owasso ok
new arms , then had to duplicate the channels
F
fireman164
owasso ok
went to several fastener places to find the rivets that are recessed into the channel, no one sells them anymore so I had to get creative
F
fireman164
owasso ok
Then I decided I didnt like the weld so I found regular hex head screws and countersunk the steel, then heated the stud coming through the back side to semi liquid and smashed them in the arbor press. Then welded the hex head closed and ground them down
F
fireman164
owasso ok
parts back from the powder coaters , I went with the closest color I could find to the walker blue, the only pics I could find of this jack were in black and white, the thing that makes me wonder if it was ever a color is the tag riveted on the side that says " Clean with gasoline and re-oil every 30 days to keep it on the job". Guessing also back then gasoline was their solvent:headscrat
F
fireman164
owasso ok
Here are the roller bearings out of the front wheels, the second pic shows new hardware and roll pins for the wheels
F
fireman164
owasso ok
The old pic I have has a logo down the side that says "walker roll-a-car 740" so I had a sign shop make me up a set
F
fireman164
owasso ok
This is where I am with it as of tonight
I really like the look of the shiny nuts on that blue background. I also love the lettering !
Is the load on the nuts (not the bolts or pivots) low enough that you can use stainless ?
F
fireman164
owasso ok
The jack is rated at 5000 lbs , the bolts I used are zink plated, stainless would have cost alot, and i will probably just use this for a conversation piece.
Fyrme
Green country, Oklahoma
Very nice work! Were the bolts for the rear caster plates mounted threads out originally? Looks awkward that way. The effort you've put into this thing is awesome. I don't know if I would have ever put that much time in it.
slow chevy
Gorgeous.. awesome to think that things mechanically can stand the test of time like that.
F
fireman164
owasso ok
Yes , which I thought looked backwards too , would have looked a lot better the other way but I was trying to stay original as possible
F
fireman164
owasso ok
found these on ebay they look to be originals, if you look close all the nuts are facing to the ouside of the jack, notice the date on the ad 12-12-1929. I would love to know what exact year these were made.
Sweet Old Bill
N. California
Great job in progress. As with everyone else, I am looking forward to seeing you post a completed project photo.
What is the diameter of the lift pad? Curious to see how it relates to the hydraulic Walkers. Thanks again for posting & restoring the Walker.
F
fireman164
owasso ok
thank you, looks like the lift pad is 4-5/8'' square ish give or take a 1/16 th
johninct
I am pretty sure that I have that same jack. My father bought it used in the 1950's. It was our go to jack until I bought a used Snap-On YA 700 for $100.00 at an auction in 1992. Mine is still in great shape and is all original but when I painted it, I painted it red 20 years ago. I had the red paint around and I didn't know that the original color was blue. I have to say I think it is easier to jack up the same car with the mechanical jack than with my Snap-On YA700. That jack has the star wheel to quickly raise the saddle up and you can lower the car one notch at a time or let the car jack itself all of the way down. I like to see the handle swinging fast as the car comes down. The only reason that that jack is not still my go to jack is that I sometimes need the lift height of my Snap-On YA700. My YA700 is down right now but I am not worried because I have my old mechanical jack. Oil yours up good then use it. You won't be disappointed!!!
F
fireman164
owasso ok
Have you posted yours on here ? I saw a red one, very cool that you have and still use !
Turbo1Ton
Very nice work. I like the effort you put in to complete the rivets in the channels on the main arms.
You and Thomas have me twitching to get one of these old things. I don't need any other projects right now. Guess I need to get off my **** and finish a few so I can start some new ones!!!
Heck, I just realized we are neighbors! I'm down south in BA.
Jeff
