HF Scissor Lift Or ???
frdtrknut
I'm thinking about getting a mid height scissor lift since I'm old enough now to not appreciate jack stands and creapers any more. I did a ring and pinion in my Mustang last year and thought I'd die under there. Does any one have any experience with the Harbor Freight lift #91315 they are selling now for about $1400. Are there others I should look at? It would be used infrequently and nothing over 4000 lbs. Thanks.
Danglerb
SoCal
Midrise scissor goes in the middle of the car, and lifts to typically OK to work under sitting on a rolling seat, but the middle of the car is blocked.
Do a search here on Midrise or scissor lift, and/or in the main garage portion of the forum for many long threads on the good and bad. Hot deals section has a group buy on a mobile two post, which would be a lot better for a Mustang.
HF would not be my vendor of choice for a generic Chinese scissor jack. Pick somebody in the business of selling shop gear like lifts.
zkling
I'd try to find a used, good condition big name brand first. If it was ~$500 sure, but $1400 seems to be a good used range. Most I've seen sell for much less than that.
TAMPAGT07
Palm Harbor, Fl
I bought mine for $700 off of CL a while back, here in St Pete...Mine is an SO...
Also in the picture is my old Autolifters (1959) ramp system, for unobstructed access to the middle of the car..
Danglerb
SoCal
anything HF= RUN AWAY
Everything that looks sort of like the old Snapon scissor is made in the same factory in China, its called something 6000. All the different USA vendors do is select from a few options on the various parts like the hydraulic pump. The reason to avoid HF is that they are not in the business of selling this kind of stuff, so they combine no knowledge with limited volume.
Bendpak sells a ton of lifts, also sells a small scissor, but stands behind it and knows enough to order them with good options.
F
frdtrknut
Good info, thanks for the replies. I will look at the Bendpak. Went on Craigslist but didn't find much. There was one but they want new price. Thanks again.
Jagmandave
Overland Park, Ks.
I bought a no-name mid rise scissor lift off CL just a few weeks ago for $600 after looking for almost 2 years, it was in excellent condition and lightly used and it works perfectly for what I do in my little shop. It gives fantastic access for front wheel drive vehicles under the engine, and I could probably change an exhaust also. For those of us with limited ceiling height, it's hugely better than working on jackstands and the floor.
As to buying HF over any other no-name Chinese lift, at least with HF you have a nationally sized company to get redress if something goes wrong or if you need parts of some sort. Chances are good they're all made in the same factory anyway.... fwiw, my lift looks exactly like the one in Subyroo's post
View media item 35553
Complete access to the engine from underneath...
View media item 35554
TAMPAGT07
Palm Harbor, Fl
I do like the open design on Jagmandave's......Mine is basically like a giant table...But not a big deal since I have the other drive on lift, with full access to the bottom...
pwhittle
Woodstock, GA
Count me in the guys that have a HF mid-rise scissor lift.
Mine looks just like jagmandave's, but in blue.
It works well for me. I had a problem with the brake cable that raises the safety, and called HF in the warranty period, and they sent me another. It took a few weeks, but no problems.
I'd buy another one.
Paul
32roadster
okla
An autolifters for 600 ??
Not bad ! a 4 post for 600 ?
I have had my kwik-lift for years and couldn't do without it. I guess it really depends on the type of cars a person is working on. I need to access the middle of my cars and trucks and rarely have a need to do brake or suspension work
When I do need to do brakes, the bridge with the kwik-lift works quite well.
