What is the width and length of an 7-9K 4 post lift
Ross/Kzoo
Richland Mi.
I'm planning my garage and one of the stipulations in the plat is the detached garage looks like and made of the same materials as the house. I plan on 9' ceilings in the house so with the detached garage I can get away with 10' sidewalls. It will have a hip roof and be 24 x 36' and a double door on the 36' side. I'm hoping to have a "tray" ceiling to pick up a couple more feet of ceiling height. I would also like to get a 4 post lift so between the garage door hardware and ceiling height I want to get it all to work.
soapii
Go to any of the lift manufacturers websites and they will give you every possible spec on their lifts.
--Joe
R
Ross/Kzoo
Richland Mi.
--Joe
I guess that I was looking as to what others have done to overcome these problems with the garage door hardware and the lift.
32roadster
okla
Ross
I have a Quality/Challenger lift 9000 pound 4 post.
It is 105 inches wide at the outside edges of the posts, and 14' 6" long at the tip end of the runways. That is not including the approach ramps.
This is a big, thick, solid lift. Not one of the internet cheapies that wiggles when you are wrenching on a car.
Ray916MN
Orono, MN
Don't forget to consider what you plan on lifting. For example, trucks generally require wider lifts so the runways are wide enough for the wheel track and to clear the mirrors.
soapii
I went back and re-read my post, wasn't trying to sound like a ****, just didn't know which lift manufacturer you were looking at. Good luck.
--Joe
R
Ross/Kzoo
Richland Mi.
--Joe
No problem, I didn't take it as that. I just didn't explain my needs in the first post. I'm trying to figure out the relationship of the garage tracks and the 4 post lifts so that there is no interference because the lift will sit under or next to the track.
Junkman
Northeastern CT
I have an 11' high ceiling, and I find that my cars are so high that it doesn't afford me a lot of room under the car for working. If you can, I suggest that you consider a truss roof configuration that will allow you some additional space above the lift for the auto to occupy. When you are in the planning stages, it is a lot easier to make changes than to try to modify an existing structure.
If I had it to do all over again, I would build the garage around the lift, rather than building the garage around a particular vehicle. Chances are that you are only going to own one lift, but you will own a multitude of vehicles in your lifetime.
jomobco
Denver, CO
Ditto on the higher ceiling. Perhaps a fake upstairs to give you 14' ceilings. I'm tall and like to walk under my work.
