Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-30-2013, 05:36 PM   #1
mustangcrazy77
Senior Member
Default Help ID Air Compressor Specs "EL Smith and Sons"
Hey, I just picked up this 30 gallon air compressor for $100. It cycles fine, holds air etc. I have no idea however the specs on the compressor itself, and have never heard of the brand "EL Smith and Sons". I cant seem to find a serial number or model number anywhere. Any help would be great!
Thanks!
Dan
mustangcrazy77 is offline   Reply With Quote
Old 12-30-2013, 06:58 PM   #2
truckdriver
Senior Member
truckdriver's Avatar
Default Re: Help ID Air Compressor Specs "EL Smith and Sons"
That pump looks like a Quincy to me. That could just be a sticker from the dealer that sold it.What does the plate on the compressor below the dipstick say?
truckdriver is offline   Reply With Quote
Old 12-30-2013, 07:27 PM   #3
mustangcrazy77
Senior Member
Quote:
Unfortunately, it doesn't say a thing.
Old 12-31-2013, 07:44 PM   #4
unashamedlaborer
Senior Member
unashamedlaborer's Avatar
Not a quincy. It looks like an old Le-Roi. Look for a metal tag on the pump. It may be painted over.
unashamedlaborer is offline   Reply With Quote
Old 12-31-2013, 07:57 PM   #5
unashamedlaborer
Senior Member
My bad. It's a Rol-Air. For sure. Here is a pic for reference. Also notice the correct orientation of the discharge from the coalescing condensate drain.
Old 12-31-2013, 08:27 PM   #6
kams1973
Senior Member
kams1973's Avatar
It's an old rebranded Curtis design.
kams1973 is offline   Reply With Quote
Old 01-01-2014, 10:19 AM   #7
mustangcrazy77
Senior Member
Awesome..thanks! That will at least give me a bit more to search on.
I have found a few more people with a similar setup, and according to this...http://www.practicalmachinist.com/vb...ressor-277610/ on mine it's a "bleed chamber" and hooked up properly.
Old 01-01-2014, 10:20 AM   #8
mustangcrazy77
Senior Member
Quote:
If it is, you wouldn't happen to have any info on it would you?
Thanks!
Dan
Old 01-01-2014, 03:42 PM   #9
unashamedlaborer
Senior Member
If your going to use the pump for a practical purpose the "pulsation chamber" is useless, actually it is Inefficient, pulsation chambers are valuable on large high pressure piston machines, on a little pump like that it is just more air to waste by bleeding it to atmosphere so that the pump can start without excess load. Unless you have a functional unloader to keep the inlet valves open.
Old 01-03-2014, 07:09 AM   #10
mustangcrazy77
Senior Member
Interesting for sure. It being what looks like original equipment, I'll likely keep it as is though.
As for the pump itself, I'm not so certain it's a Rol-Air. Perhaps they used another manufacturers compressor on that tank?
Old 05-01-2014, 06:50 PM   #11
jimbowlie
Junior Member
Hi, I have the same search going, have you had any more luck in your investigations?
jimbowlie is offline   Reply With Quote
Old 05-01-2014, 06:53 PM   #12
mustangcrazy77
Senior Member
Quote:
No luck. I actually sold it shortly after posting as what it developed a pin hole in the tank. Good luck!
Old 05-01-2014, 09:17 PM   #13
kams1973
Senior Member
kams1973's Avatar
Thanks!
Dan
Sorry I missed your question. Below are a couple photos of the same model pump. Ignore the flywheel. The one pictured isn't original to the pump.
[IMG][/IMG]
[IMG][/IMG]
Old 05-01-2014, 11:51 PM   #14
Fixnair
Senior Member
Fixnair's Avatar
If it was assembled by a reputable company then you would get about 4.5 CFM per horsepower. You have a two horsepower motor so it should deliver 9 CFM @ 100 PSIG.
Now if it was assembled by some hack who just threw a bunch of parts at it to sell it quick then who knows how much air it puts out.
It looks like it was done by someone who knew what he was doing though. I wouldn't use it at pressures higher than 125 PSI though.
__________________
Any man can handle adversity, but if you want to test his character. Give him some power. A Lincoln
Measure with a micrometer, mark with a crayon and cut with an ax!
Just trying to outlive my life.
Fixnair is offline   Reply With Quote
Old 07-16-2014, 05:47 PM   #15
Old Skull
Junior Member
Old Skull's Avatar
I know this thread is old but since I own a dual pump E.L.Smith compressor I know what they look like and my post may help future owner of this brand of compressor .
This American company have been sold long ago to the US company American Eagle, today they sell one of the best hydraulic air compressor unit on the market, they still sell parts and even pump!
Here the link :http://www.americaneagleacc.com/pumps.php
Old Skull is offline   Reply With Quote
Old 09-18-2014, 10:21 AM   #16
jimbowlie
Junior Member
Old skull is spot on... I have same compressor 143 and parts are same back to the model 84. I bought this pump branded sanborn (but is e.l. smith (p.k. lindsey) was bought out by american eagle. Mine had pressure rating max 165 running 95-120.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
