sewerzuk
Winter is coming…and I am getting tired of wrenching on my rigs with gloves, a coat, and hat. I assume there are quite a few gearheads out there in the same boat as I am; access to lots of old oil, not a lot of access to $$, and willing to build something cool to produce heat. I just finished converting an oil furnace to run on waste oil so I thought I would share it.
Cost is the main reason I decided to do this conversion. With propane at almost $3 per gallon and home heating oil between $3 and $4 per gallon, heating my shop was going to be expensive. My neighbor spends over $2000 each winter in heating oil to keep his house warm. According to the DOE, the average household that uses oil heat burns over 1000 gallons each year; at today’s prices, that’s around $4000 for heat! I wanted to heat for free; and I have access to an unlimited supply of waste motor oil, and about 5 gallons of vegetable oil per week. Start to finish, this project cost me around $600 and took me about 40 hours. I did manage to do some scrounging and got quite a bit of stuff for free. However, I did waste some $$ on some ideas that didn’t work out.
I need to give some credit to the members of the altfuelfurnace group in the Yahoo groups. I wouldn’t have attempted this conversion without first reading the info there.
This write-up is intended to demonstrate how I converted my furnace to run on waste oil; it isn’t supposed to give you a detailed step-by-step conversion process. If you’re going to attempt this conversion some basic mechanical skills, some good tools, a GOOD understanding of electrical systems, some patience, and a willingness to experiment are necessary. I’ll answer any questions to the best of my ability. I went through lots of ideas and alternatives before I settled on my final design. I’m listing the steps I took and the parts I used in my conversion; but feel free to be innovative! I’m sure somebody can improve on my design somehow. I believe that the Beckett burner I used is also used in boilers; so this could also be used for in-floor radiant heat, hot-water radiator type heaters, or hydroponic furnaces. A cart could also be built that holds the furnace and a primary oil tank, making this a portable high-capacity heater that you could roll to wherever heat was needed (although exhaust venting would still be necessary).
I don’t assume any kind of responsibility or liability for what you do in your shop. Keep in mind that you are working with flammable liquid and high voltage. If you set your house, shop, garage, or self on fire I’m truly sorry but it’s not my fault. I also know that the EPA prohibits the use of waste oil for heating your home (although it is permitted for heating a garage or shop). I have no idea how this would be enforced. I don’t know of any other laws, rules, statutes, etc. involving the use of waste oil for heating so it is up to you to decide if it is legal for your location and situation.
