How to flatten out a car hood?
dbilik
Hey everyone,
Just wondering if anyone knows how I would go about flattening out the curves in a car hood to get myself a flat sheet of metal?
I saw this photo album and wanted to give it a shot. The bending and welding I can handle. The flattening seems like it may be harder to pull off.
http://www.flickr.com/photos/weldhouse/
rockwithjason
Las Vegas
Re: How to flatten our a car hood?
it looks to me like they cut out the reasonably flat areas and then either hammer and dollied them or pressed them flat
rsanter
visalia ca
Sheet metal roll
Adjust the third roller out of the way so,it dosent put a curve in the metal
Bob
nonhog
Arizona (Tucson)
Personally I would leave the center ridge for character. Makes a worse table
but also a cooler one. IMO.
2 ea. there own.
dogdog
it's the patina and the shapes for characteristics.
I guess once you took/grind off the reinforcement on the bottom of the hood, it's treated just like another piece of 12 14 or 16 gauge sheet?
That person also build some sort of very level square frame on that acorn table. Some picture indicated that the sheet metal are tacked onto the frame maybe using that table as a press, sheet down frame on top and lots of clamps?
But very nice shinny table.
Toxicscrew
Saint Louis, MO
Most still have the center ridge in them.
Start at center, weld it and clamp your way to the edge?
Patina looks good, bookmarked that page for future inspiration.
dogdog
The shinny top looks like a self leveling epoxy resins for table top. which explains the reason why it is so shinny with patina look.
kazlx
Tustin, CA
He does that in a giant press.
Automotive clear coat.
Ronny
They have been rolled flat . You don't need a press to flatten them,just a set of plate rollers as used by Boiler makers.
Toxicscrew
Saint Louis, MO
This would probably do it:
Volvo_DD110B_asphalt-roller_compactor_machine_datas_Operating_weight_engine_drum_vibration_horse_power_rate_out.jpg
Did see once, an artist took all the body panels off a Porsche 914, rolled over them with one of these and then mounted on a wall. They weren't as smooth as this guys work though.
jeffhayden
Hey everyone,
Hi everyone
I am new to the existing discussion.
Through your discussion I want to say that you can do this work easily with just cutting the extra part and struck the flat area according to your comfort.
