The Truck Tool Equivalents Thread 2.0 - Expanded with Part Numbers
ihateminimumwage
The purpose of this thread is the same as the original "Tool Truck Equivalents" thread; To provide information on the original manufacturers of many of the "Truck Brand" re-badged tools, so they can be bought without the markup.
The original thread has been in major need an update with all the part numbers and newer submissions in the last 2̶-̶1̶/̶2̶ ̶y̶e̶a̶r̶s̶ (now nearing 5 years). That said, I've taken the last couple of days to compile the tools from the original thread, as well as others that I found along the way, and streamlined them with the type of tool and the part number. Each of the 'Big 4' truck brands has their own post to try and make things slightly less overwhelming, and easier to reference. The last page in the lineup is dedicated to Industrial/Non-Truck brands.
This will be a constantly evolving thread, which will be updated as often as I can as more information comes in, and hopefully with enough work and support it can become a sticky in the place of the original.
Thanks to everyone that submitted to the original thread, and thanks in advance for everyone that will continue to add to this one! Cheers folks!:beer:
7/10/17 NOTE: Listings with red text are items no longer offered, usually due to a change in manufacturer. I may remove them altogether as time goes on, but for now will leave them for reference, and for folks buying used or NOS.
I
ihateminimumwage
Snap-on/Blue Point
Ratchets:
T72 1/4" Ratchet - Bahco 6950 (72 Tooth)*
F80 3/8" Ratchet - Bahco 7750 (80 Tooth)*
S80 1/2" Ratchet - Bahco 8150 (80 Tooth)*
*Bahco version only offered in comfort grip.
T936 1/4" Ratchet - Williams M-52EHA, CAT 239-6823 (36 Tooth)
TL936 1/4" Long Ratchet - Williams M-52EHLA (36 Tooth)
TF936 1/4" Flex Ratchet - Williams M-52EHFA (36 tooth)
F936 3/8" Ratchet - Williams B-52EHA, CAT 239-6824 (36 Tooth)
FL936 3/8" Long Ratchet - Williams B-52EHLA (36 Tooth)
FLF936 3/8" Flex Ratchet - Williams B-52EHFA (36 tooth)
S936 1/2" Ratchet - Williams S-52EHA, CAT 239-6825 (36 Tooth)
SL936 1/2" Long Ratchet - Williams S-52EHLA, CAT 239-6826 (36 Tooth)
SF936 1/2" Flex Ratchet - Williams S-52EHFA (36 tooth)
BPRTR936 1/4" QR Ratchet (Blue Point) - Williams 30001, Westward 4YP73 (36 tooth)
BPRFR938 3/8" QR Ratchet (Blue Point) - Williams 31001, Westward 4YP74 (38 tooth)
BPRSR940 1/2" QR Ratchet (Blue Point) - Williams 32001, Westward 4YP75 (40 tooth)
BLPCGHD146 1/4" Drive 6" Spinner Handle (Blue Point) - Williams 30006
BLPCGHD388 3/8" Drive 9" Spinner Handle (Blue Point) - Williams 31016
TM4CSA 1/4" Drive 6" Spinner Handle - CAT 9S-1722
BLPPTSS3822 3/8" Drive Pass Through Ratchet/Socket Set (Blue Point) - Williams 50671
Torque Tools:
TQR100B 3/8" Drive Click Torque Wrench (20-100 ft/lbs) - Precision Instruments C2R100F
TQFR100C 3/8" Drive Flex Torque Wrench (20-100 ft/lbs) - Precision Instruments C2FR100F
TQFR50B/C 3/8" Drive Flex Torque Wrench (100-600 in/lbs) - Precision Instruments C2FR600H
TQFRN68B 3/8" Drive Flex Torque Wrench (14-68 Nm) - Precision Instruments C2FR68N
TQFRN130B 3/8" Drive Flex Torque Wrench (25-135 Nm) - Precision Instruments C2FR130N
TQR250E 1/2" Drive Click Torque Wrench (40-250 ft/lbs) - Precision Instruments C3F250F
TQFR250E 1/2" Drive Flex Click Torque Wrench (40-250 ft/lbs) - Precision Instruments C3FR250F
TQFRM34D 1/2" Drive Flex Click Torque Wrench (5-34 kg.m) - Precision Instruments C3FR34M
TQFRN350D 1/2" Drive Flex Click Torque Wrench (60-350 Nm) - Precision Instruments C3FR350N
TQR400E 3/4" Drive Click Torque Wrench (130-400 ft/lbs) - Precision Instruments C4D400F
TQR600E 3/4" Drive Click Torque Wrench (200-600 ft/lbs) - Precision Instruments C4D600F
TQRM80C 3/4" Drive Click Torque Wrench (26-80 kg.m) - Precision Instruments C4D80M
Wrenches:
BLPCWS711B 11pc BP Combo Wrench Set (3/8"-1") - Williams 11007
BOER704 4pc BP Reversible Ratcheting Combo Set (13/16"-1") - Williams WS-1164RC
BOER708 8pc BP Reversible Ratcheting Combo Set (5/16"-3/4") - Williams WS-1168RC
BOERM712 12pc BP Reversible Ratcheting Combo Set (8mm–19mm) - Williams MWS-12RC
BOERMF712A 12pc BP Flex Reversible Ratcheting Combo Set (8mm-19mm) - Williams MWS-12RCF
BOERF708A 8pc BP Flex Reversible Ratcheting Combo Set (5/16"-3/4") - Williams WS-1168RCF
GAJS30A 30" Adjustable Wrench, Industrial Finish (Blue Point) - Bahco 87
VS814A 14pc SAE Open End Angle Wrench Set (3/8" - 1-1/4") - CAT 1P-3515
Screwdrivers:
SSDMR4B Ratcheting Screwdriver - Williams WRS-1, CAT 9U-7291, Case IH SC80005
SSDMRT1 2" Shank T-Handle Ratcheting Screwdriver - Williams WRST1
SSDMRT4 4" Shank T-Handle Ratcheting Screwdriver - Williams WRST4
SSDMRT8A 8" Shank T-Handle Ratcheting Screwdriver - Williams WRST8
SSF1/SSFP1/SSFP2 3pc Ultra Low Profile Screwdrivers - Anex 6102T
Pick Sets:
PSLR4 4pc Hook & Pick Set - Ullman CHP4-L, Matco CHP4L, Craftsman CHP4-L, MAC PSCHP4L
PSLR6 6pc Hook & Pick Set - Ullman CHP6-L, Matco CHP6L, MAC PSCHP6L
Hex & Torx Key Sets
AWEF6K 6pc SAE Folding Hex Key Set (5/32"-3/8") - Eklind 25611
AWEF9K 9pc SAE Folding Hex Key Set (.5"-3/16") - Eklind 25912
AWMEF6K 6pc Metric Folding Hex Key Set (3-10mm) - Eklind 25161
AWMEF7K 7pc Metric Folding Hex Key Set (1.5-6mm) - Eklind 25171
AWMEF8K 8pc Metric Folding Hex Key Set (2-8mm) - Eklind 25181
AWTEF8K 8pc Torx Folding Hex Key Set (T8-T40) - Eklind 25581
BHM9A 9pc Metric Ball End Hex L-Key Set (1.5-10mm) - Eklind 13609
BHS13A 13pc SAE Ball End Hex L-Key Set (.5"-3/8") - Eklind 13213
Pliers:
BDG96LMP (Blue Point) Mini Long Reach Long Nose Pliers - Williams 23471
BDG86LMP (Blue Point) Mini Long Reach Diagonal Cutter - Williams 23473
BDG9645LMP (Blue Point) Mini Long Reach Bent Nose Pliers - Williams 23475
BDG97LMP (Blue Point) Mini Long Reach Needle Nose Pliers - Williams 23477
BDGPL400LMP (Blue Point) 4pc Mini Long Reach Pliers Set - Williams 23064
PHP3 Mini Hose Pinch Pliers - Craftsman 47050*, Imperial HP54, KD 3791, SK 7601, Matco HP54
PHP1 9" Hose Pinch off Pliers - Craftsman 47051*, Imperial HP55, KD 3792, SK 7602, Matco HP55
PHP2 Heavy Duty Pinch Pliers - Craftsman 47060*, Imperial HP56, KD 3793, SK 7603, Matco HP56
*All 3 in Craftsman set 74Z706
PL300CF 3 pc Pliers/Cutters Set - CAT 233-1639
47ACF Slip Joint Pliers - CAT 6V-6192
87ACF Diagonal Cutters - CAT 6V-6193
96ACF Needle Nose Pliers - CAT 6V-6194
PRH406 6pc Camlock Retaining Ring Pliers Set - Imperial Stride IR-6CK, Matco MST4306, SK 7780, Urrea 370L, Craftsman 950465, Armstrong 68-056
PR50A 2pc Heavy Duty Replaceable Tip Retaining Ring Pliers Set (Blue Point) - Imperial Stride IR-50K
PRH503 3pc Quick Switch Snap Ring Pliers Set - Lang 1465, Channellock RT-3, Craftsman 47394, Matco SPRC3A, Wright 9H1265K
PWZ0 8-7/16" Pliers Wrench 1-3/16" Jaw - Bahco 140
PWZ1 11" Pliers Wrench 1-3/8" Jaw - Bahco 141
PWZ2 14-1/2" Pliers Wrench 2-1/16" Jaw - Bahco 142
PWZ3 21-7/8" Pliers Wrench 3-1/16" Jaw - Bahco 143
PWZ4 28-3/8" Pliers Wrench 4-3/8" Jaw - Bahco 144
PWZ5 41-3/4" Pliers Wrench 6-5/16" Jaw - Bahco 147
LP5WR 5" Locking Pliers Curved Jaw w. Cutter - Grip-On GR12105
LP7WR 7" Locking Pliers Curved Jaw w. Cutter - Grip-On GR12107
LP10WR 10" Locking Pliers Curved Jaw w. Cutter - Grip-On GR12110
LP6LN 6" Locking Pliers Long Nose - Grip-On GR12706
VGP23312 12" Locking Clamp with Self Leveling Jaws - Grip-On GR23312
VGP13709 9" Locking Plugweld Pliers - Grip-On GR13709BK, NAPA P821
VGP14412 12" Aluminum Locking C-Clamp - Grip-On GR14412
YA824ASTR (Blue Point) Spark Plug Boot Pliers - SE Tools 824S, Matco SP824S
YA824C (Blue Point) 45° Spark Plug Boot Pliers - SE Tools 824A, Matco SP824
SBP5 (BLue Point) 5-Position Spark Plug Boot Pliers - Lisle 51750, Matco LS51750
Air Tools:
FAR2500 1/4" Mini Air Ratchet - Sioux SRW03S25
FAR2505 3/8" Mini Air Ratchet - Sioux SRW03S38
Hammers:
BC7B 5lb Deadblow Sledgehammer (Blue Point) - Trusty Cook #7
BC110B 8lb Deadblow Sledgehammer (Blue Point) - Trusty Cook #10
BC114B 11lb Deadblow Sledgehammer (Blue Point) - Trusty Cook #14
BD10ESG 10lb Fiberglass Handle Sledgehammer (Blue Point) - Williams SHF-10L
Damaged Nut/Bolt Removal, Thread Cutting/Repair:
ATSSET 2pc Adjustable Tap Socket Set - Irwin 3095001, Matco ATS2
E1020 20pc Extractor Set - Ridgid 35585
EXD35 35pc Drill Bit and Extractor Set - Irwin 11135
EXDL10 Left Hand Extractor Set - Irwin 11119
EXD35 35pc Master Extractor Set - Irwin 11135ZR, Matco MEX35, Cornwell ATC11135, MAC SCEX35S
EXDMS48 48pc Master Extractor Set - Irwin 3101010, Cornwell ATC3101010
RTD40 40pc Master Rethreading Kit - Kastar 972, Craftsman 52105, MAC TRCOMBO
RTD48 48pc Master Rethreading Kit - Kastar 971, Craftsman 42275, MAC TRCOMBO-48
TDTDM117A* 117pc Tap/Die & Drill Set - Irwin 26377, Matco 676TDP, MAC TDPLUS, Cornwell VG1813817
TDTDM500A* 76pc Tap/Die Set - Irwin 26376, Matco 676TD, MAC TDCOMBO, Cornwell VG1813816
*Snap-On sets include adjustable dies
Specialty Tools:
BTCP500 Brake Caliper Press - Kastar 279
BTWSMPK 7pc Bit Ratchet Wrench Set - Kastar KAS5220, Matco FTR7, Craftsman 47477
CJ1200 Slide Hammer Dent Puller Set - Keysco 77081
FB310B 25 Blade Master Feeler Gauge Set - Craftsman 40804, Proto J000AA, MAC FG002
FB325A 6 Blade Non-Magnetic Feeler Gauge Set - Proto J000BR, Matco FG23A
GA285 Camshaft Bearing Tool Kit - Lisle 18000, Matco CBT18, MAC CBT18A
GA486A Battery Terminal Puller - Lisle 54150, Matco BT54150, MAC BP21K, Cornwell ECBK706
HP200 Pop Riveter kit - Marson 39001
LDT8 18pc AC/Fuel Line Master Disconnect Set - Lisle 39900, Matco MDS399, MAC MD4000
LCSS600 Steel Line Stopper Kit - Private Brand Tools PBT71106, Cornwell PBT71106, Matco SLSK90
LKP620 Master Lock Pick Set - Lock Technology LT620
PGH8A 11 Piece Gasket Cutter Set - Kastar 950, Matco 79PK, MAC GC950
TF5A Double Flaring Tool Set - Wilde 250DF, MAC FT158B, NAPA 41860
TORCH6 Mini Butane Torch - Portasol TORCH820 (012680040)
TT12KT 12pc Terminal Tool Kit - Sealy VS920, Proto JFE96030, Matco TTK031, MAC TT96030, Cornwell JS96033
TT3K Terminal Tool Set with Handle - Lisle 57750, Matco TWT577, MAC TT7750
YA105 Seal Puller (Blue Point) - Lisle 56750, Craftsman 947645, Matco SP56
YAKS32A Butane Soldering Iron - Portasol/Weller PSI100K
YA832A Spark Tester - Lisle 19380, Matco SPT79
YA840 Inline Spark Tester - Lisle 20610, Matco ST20610
Funnels
OFHARLEY Harley 2007+/Kia Threaded Funnel - Assenmacher OFHD35
OFHD Harley 1999-2006 Threaded Funnel - Assenmacher OFHD419, Matco OFHD419
OFFM Ford/Mazda Threaded Funnel - Assenmacher ASMOFFM2012
OFHON33 Honda/Nissan/Chrysler/Ford Threaded Funnel - Assenmacher ASMOFHON1033, Matco HON1033
OFTOY38 Toyota Threaded Funnel - Assenmacher OFTOY1038, Matco TOY1038
OFGMFORD GM/Ford Threaded Funnel - Assenmacher ASSOFGMRD08, Matco GMRD08
OFKIT 5 pc Master Oil Funnel Kit - Assenmacher FUN14KIT
Shop Equipment and Tool Storage
AWSTAND T-handle Hex/Allen Key Rack - Williams HKTSTAND, McMaster-Carr 53045A36
BPTRYLAS 76pc Lock-a-Socket Tray - Mechanics Time Saver MTSLASTRAY
KMAGBIT37R Magnetic 37 Hole Hex Bit Organizer - Mechanics Time Saver 581, Torin 581T
KRBC2T 2 Shelf Roll Cart (Blue Point) - Williams 50722
KRBC3TD 2 Shelf Roll Cart w. Locking Drawer (Blue-Point) - Williams 50723
KRBC7TD 4 Drawer Roll Cart with Lid, Rack and Shelf (Blue-Point) - 50724
NOTES:
Snap-On Chrome Sockets - Williams USA Chrome Sockets, No direct set crossover.
Blue Point Chrome Sockets - Williams Taiwan Chrome Sockets, No direct set crossover.
Snap-On Torx Insert Bits - Zephyr Torx Insert Bits
Snap-On Bench Vises (Part Number WV####) - Wilton #### (Example: WV300N = Wilton 300N)
Snap-On Drill Bits - Triumph Twist Drill Co. Bits
I
ihateminimumwage
Matco
Ratchets:
AFR58T 1/4" 88T Ratchet - Armstrong 10-992*
BFR88T 3/8" 88T Ratchet - Armstrong 11-992*
CFR108T 1/2" 88T Ratchet - Armstrong 12-992*
AFR68LFT 1/4" 88T Locking Flex Ratchet - Armstrong 10-994*
BFR128LFT ̶3/8" 88T Locking Flex Ratchet - Armstrong 11-994*
CFR178LFT 1/2" 88T Locking Flex Ratchet - Armstrong 12-994*
AIR10 1/4" Drive 6" Indexible Ratchet - Armstrong 10-996 (72 Tooth)
BIR10 3/8" Drive 10" Indexible Ratchet - Armstrong 11-996 (72 Tooth)
CIR12 1/2" Drive 12" Indexible Ratchet - Armstrong 12-996 (72 Tooth)
DR40T 3/4" Drive Extendable Ratchet 24"-40" - EZ Red MR34, Neiko 03069A (24 Tooth)
*Armstrong models vary between 60T/88T. Matco & Armstrong 60T/88T rebuild kits are interchangeable, as well as Gearwrench 60T/84T rebuild kits.
Sockets & Extensions
BUP2BB 3/8" Pinless Impact Universal Joint - Craftsman 23766 , Armstrong 19-947, Gearwrench 84427
CUP2BB 1/2" Pinless Impact Universal Joint - Craftsman 23765 , Armstrong 20-947, Gearwrench 84691
SBUPM106TB 10pc 3/8" Pinless Universal Impact Set (10-19mm) - Gearwrench 84921, Armstrong 46-910, Craftsman 15397*
SBUP76TB 7pc 3/8" Pinless Universal Impact Set (3/8"-3/4") - Gearwrench 84922, Armstrong 19-894, Craftsman 15396
SBXP3L 3/8" 3pc Locking Impact Extension Set - Armstrong 19-940
SALXK3TA 1/4" 3pc Chrome Locking Extension Set - Armstrong 10-920
*No 19mm included in Craftsman set. 10-18mm Only.
Torque Tools:
TRA200 1/4" Torque Wrench (30-200 in/lbs) - Gearwrench 85050, Armstrong 64-032
TRB250 3/8" Torque Wrench (50-250 in/lbs) - Gearwrench 85051
TRB100 3/8" Torque Wrench (10-100 ft/lbs) - Husky H3DTW, Gearwrench 85052, Armstrong 64-046
TRB75F 3/8" Flex Head Torque Wrench (5-75 ft/lbs) - Armstrong 64-146, Gearwrench 85056
ETWB100A 3/8" Drive Electronic Torque Wrench (10-100ft/lbs) - Gearwrench 85070
TRC250A 1/2" Torque Wrench (25-250 ft/lbs) - Husky H2DTW, Gearwrench 85054, Armstrong 64-086
TRC250FA 1/2" Flex Head Torque Wrench (25-250 ft/lbs) - Armstrong 64-186, Gearwrench 85057
ETWC250A 1/2" Drive Electronic Torque Wrench (25-250ft/lbs) - Gearwrench 85071
TRD600R 3/4" Torque Wrench (100-600 ft/lbs) - Gearwrench 85055, Armstrong 64-095, KD 2953
SBTA7R 7pc SAE Torque Adapter Set - Armstrong 64-750
Wrenches:
SRF102PA 10 Piece Flexible Ratcheting Wrench Set - Mountain 9410
SRRFXLM52T 5pc Extra Long Double Flex Ratcheting Wrench Set - Mountain RM6
Screwdrivers:
SSPCO5C/SSPCG5C 5 Piece Screwdriver Set - Witte 663865
SSPRI7 7 Piece Insulated Screwdriver Set - Gearwrench 80063
SSR3C 3 Piece Square Tip Screwdriver Set - Witte 63061, 63062 & 63063
Pry Bars:
IDPB8 8" Indexing Pry Bar - Gearwrench 82208
IDPB16 16" Indexing Pry Bar - Gearwrench 82216
IDPBSET2 2pc Indexing Pry Bar Set (8" & 16") - Gearwrench 82300
IDEXPB33A 33" Indexing Pry Bar - Gearwrench 82220, Quinn 57314
Pick Sets:
HP4RB/HP40B/HP4GB - Witte 691008
CHP4L 4pc Hook & Pick Set - Ullman CHP4-L, Snap-on PSLR4, Craftsman CHP4-L, MAC PSCHP4L
CHP6L 6pc Hook & Pick Set - Ullman CHP6-L, Snap-on PSLR6 (Blue Point), MAC PSCHP6L
CHP8L 8pc Hook & Pick Set - Ullman CHP8-L
Pliers:
25W Wire Twisting Pliers - Milbar 25W, MAC WTR6, SK 7726, Proto J196
PC7 7" Cobra Pliers - Knipex 8701180, Craftsman 45431
PC10 10" Cobra Pliers - Knipex 8701250, Craftsman 45430
PC12 12" Cobra Pliers - Knipex 8701300
PDC7E 7" Angled High Leverage Diagonal Cutting Pliers - Orbis 9O 21-180
PN890 Bent Angle Needle Nose Pliers - Knipex 38-81-200B
PNC8E 8-3/4" Angled Long Nose Pliers - Orbis 9O 21-150
PU3SA 3pc Universal Pliers Set - Knipex 00-20-08
SPM4 4pc Precision Pliers Set - Knipex 00-80-81
SPRIE8 8pc Snap Ring Pliers Set - Knipex 00-20-04
MST3723 2pc Push Pin Pliers Set - KD 41840
MST5950A Angled Wire Service Plier - OTC 5950A
MST5950S Straight Wire Service Plier - OTC 5950S, NAPA CHT-WSCCP
MST700E 3pc Mini Stripper/Cutter/Crimp Pliers Set - KD 3794, Cornwell ML700E
QRP4S 4pc Quick Release Pliers Set - Direct Source QRP4
HCPR20A Ratcheting Hose Clamp Pliers - Otc 4525, Astro Pneumatic 9409A
PLA8-20 8" Angle Head Lever Action Cutter - Knipex 71 21 200
SGW82106 - 2pc Double-X Pliers Set - Crescent PSX203C, Gearwrench 82106, Cornwell KD82106, NAPA P900
SRP230 U-Joint Snap Ring Pliers - Vim Tools V230
OF29700 Adjustable Filter Pliers - OTC 4560
OF29900 Extra Large Adjustable Filter Pliers - OTC 4561
ADJFP2 Adjustable Filter Pliers Twin Pack - OTC 4562
OF5075A Slip Joint Oil Filter Pliers - Lisle 50750
OF5095 Large Slip Joint Oil Filter Pliers - Lisle 50950
209G 9" Oil Filter Pliers - Channellock 209
212G 12" Oil Filter Pliers - Channellock 212
HP54 Mini Hose Pinch Pliers - Craftsman 47050*, Imperial HP54, KD 3791, SK 7601, Blue Point PHP3
HP55 9" Hose Pinch off Pliers - Craftsman 47051*, Imperial HP55, KD 3792, SK 7602, Blue Point PHP1
HP56 Heavy Duty Pinch Pliers - Craftsman 47060*, Imperial HP56, KD 3793, SK 7603, Blue Point PHP2
LCS3 3pc Flexible Line Clamp Pliers Set- Craftsman 42454
MST4306 6pc Camlock Retaining Ring Pliers Set - Imperial Stride IR-6CK, Snap-On PRH406, SK 7780, Urrea 370L, Craftsman 950465, Armstrong 68-056
MST1225 12pc Quarter Turn Internal/External Snap Ring Pliers Set - Imperial Stride IR-12K, SK 7612, Proto 360B, MAC PK1250, Craftsman 950464, Urrea 360B
SPRC3A 3pc Quick Switch Snap Ring Pliers Set - Lang 1465, Craftsman 47394, Channellock RT-3, Snap On PRH503, Wright 9H1265K
SP824S Spark Plug Boot Pliers - SE Tools 824S, Snap-On YA824ASTR
SP824 45° Spark Plug Boot Pliers - SE Tools 824A, Snap-On YA824C
LS51750 5-Position Spark Plug Boot Pliers - Lisle 51750, Snap-On SBP5
Air Tools:
MT2120 3/8" Composite Impact Wrench - Ingersoll Rand 2115TiMAX
MT2138 3/8” Composite Impact Wrench - NAPA 6-1122, Cornwell CAT2150
SE210 3/8" Impact Wrench - Florida Pneumatic FP-739
MT2769 1/2" Extended Anvil Composite Impact Wrench - NAPA 6-1124, Corwell CAT4152
MT2250 1/2" Compact Composite Impact Wrench - Cornwell CAT2135
MT1727 1/2" Reversable Air Drill - Astro Pneumatic 527C
MT1769QA 1/2" Quiet Impact Wrench - Ingersoll Rand 2135QTIMAX
MT2234 3/4" Compact Composite Impact Wrench - NAPA 6-1125, Cornwell CAT3125
LT855 Texas Twister Air Hammer Puller Kit - Lock Technology 855, MAC LT855
Hammers:
DB13 13oz Deadblow - Trusty Cook 0, Estwing CCD13, Cornwell CTHTC0, Carlyle HDB13
DB21 21oz Deadblow - Trusty Cook 1, Estwing CCD21, Cornwell CTHTC1, Carlyle HDB21
DB26 26oz Deadblow - Trusty Cook 2, Estwing CCD26, Cornwell CTHTC2, Carlyle HDB26
DB45 45oz Deadblow - Trusty Cook 3, Estwing CCD45, Cornwell CTHTC3, Carlyle HDB45
DB53 53oz Deadblow - Trusty Cook 4, Estwing CCD53
BH16DB 16oz DB Ball Peen - Trusty Cook TCBP16, Estwing CCBP16, Armstrong 68-516, Cornwell CTH16BP
BH24DB 24oz DB Ball Peen - Trusty Cook TCBP24, Estwing CCBP24, Armstrong 68-524, Cornwell CTH24BP
BH32DB 32oz DB Ball Peen - Trusty Cook TCBP32, Estwing CCBP32, Armstrong 68-532, Cornwell CTH32BP, Carlyle HDBBP32
BH40DB 40oz DB Ball Peen - Trusty Cook TCBP40, Estwing CCBP40, Armstrong 68-540, Cornwell CTH40BP, Carlyle HDBBP40
BH8F 8oz Ball Peen - Nupla 21008
BH12F 12oz Ball Peen - Nupla 21012
BH16F 16oz Ball Peen - Nupla 21016
BH20F 20oz Ball Peen - Nupla 21020
BH24F 24oz Ball Peen - Nupla 21024
BH32F 32oz Ball Peen - Nupla 21032
BH40F 40oz Ball Peen - Nupla 21040
BH48F 48oz Ball Peen - Nupla 21048
BRS64 64oz Brass - Nupla 30040
EXPH48D 48oz Extreme Power Drive - Nupla 10063, Williams HPDX-3
EXPH64D 64oz Extreme Power Drive - Nupla 10064, Williams HPDX-4
EXPH32DS 2LB Steel Tip Deadblow Hammer - Nupla 10028
PH35 16oz Cusion Blow - Nupla 02549
PH32D 32oz Power Drive - Nupla 10025, Williams HPD-2
PH48D 48oz Power Drive - Nupla 10035, Williams HPD-3
ATS2 2pc Adjustable Tap Socket Set - Irwin 3095001, Snap-On ATSSET
676TD 76pc Tap/Die Set - Irwin 26376, MAC TDCOMBO, Snap-On TDTDM500A*, Cornwell VG1813816
676TDP 117pc Tap/Die & Drill Set - Irwin 26377, MAC TDPLUS, Snap-On TDTDM117A*, Cornwell VG1813817
MEX35 35pc Master Extractor Set - Irwin 11135ZR, Snap-on EXD35, Cornwell ATC11135, MAC SCEX35S
SR20K 20pc Master Spindle Rethread Kit - Kastar 2599
TS705 8pc Tap Socket Set - Lisle 70500, MAC TSS70500, Napa 77-4032
TSSLP10C 10pc Low-Profile Twist Socket Set - Craftsman 52166
I
ihateminimumwage
Matco Tools Continued...
Specialty Tools:
23970 In-Line Spark Checker Kit for Recessed Plugs - Tool Aid 23970
79PK 11 Piece Gasket Cutter Set - Kastar 950, Snap-On PGH8A, MAC GC950
AE755 6pc Wheel Stud Installer Kit - Kastar 938
BJP7025C Ball Joint Press Kit - OTC 7249
BRS99PC Bearing Race Driver Set - Astro 7824, OTC 4507, Lisle 12980, Nieko 20704A
BT54150 Battery Terminal Puller - Lisle 54150, Blue Point GA486A, MAC BP21K, Cornwell ECBK706
BTS528 7pc Battery Service Tool Set - OTC 4639
CBT18 Camshaft Bearing Tool Kit - Lisle 18000, Snap-On GA285, MAC CBT18A
CGSS2A 2pc Carbide Scraper Set - Lisle 81780
CSS2 2pc Carbide Scraper Set - Mueller Kueps 268220, ATD 8564
CSS216 5/8" Carbide Scraper - Titan 17010
CSS232 1-1/4" Carbide Scraper - Titan 17011
CT66K Compression Tester Kit - Star Industries STATU3PB
DBPS260 Double Brake Pad Spreader - Lisle 25750
DRG04B Digital Brake Rotor Gauge - KD 3774, Gearwrench 3774D
FG23A 6 Blade Non-Magnetic Feeler Gauge Set - Proto J000BR, Snap-On FB325A
FG275 26 Blade Offset Feeler Gauge Set - Kastar 3275A, Cornwell RBFG26
FR35260 Plastic Fastener Remover - Lisle 35260
FTR7 7pc Bit Ratchet Wrench Set - Lang/Kastar KAS5220, Snap-On BTWSMPK, Craftsman 47477
GM2 16lb Telescopic Magnetic Pick-Up Tool - Ullman GM-2
HB460 Harmonic Balancer Installer Set - Lisle 53460
HH7 Hood Prop - Lisle 45900
HT1 2-1/2lb Telescopic Magnetic Pick-Up Tool - Ullman HT-5, Gearwrench 84088
HT2LM Rectangular Lighted Inspection Mirror - Ullman HTK2LT, NAPA SER-HTK2LT
MDS399 18pc AC/Fuel Line Master Disconnect Set - Lisle 39900, Snap-On LDT8, MAC MD4000
MG25 25 Blade Metric Feeler Gauge Set - KD 2274, Proto J00MM25, MAC FG030, Cornwell RBFG30MM
MHHFL Rechargeable LED Slimlight - Astro 40SL
MS600 Monster Scraper 6" - EZ Red MS600, MAC MS600A
MSBT15 Serpentine Belt Wrench Set - Gearwrench 3680
MST4410 Master Bushing Driver Set - OTC 4410
MST4531 Harmonic Balancer Puller/Installer Set - OTC 4531, MAC HB531
MST4579A 9 Way Slide Hammer Puller Set - OTC 4579
MVP5000 Hand Vacuum/Pressure Pump Kit - Mityvac MV8500
PCHOB Punch and Chisel Holder - KD/Gearwrench 84090
PFC440 Pneumatic Fan clutch set - Lisle 43300
PP390 Pulley Puller/Installer - Lisle 39000
PTK70888 Deluxe Cooling System Pressure Tester - Craftsman 70888
SCPMTW36V 3pc 1/2" Drive Wheel Protector Impact Socket Set - Sunex 2842
SLSK90 Steel Line Stopper Kit - PB Tools PBT71106, Cornwell PBT71106, Snap-On LCSS600
SP56 Seal Puller - Lisle 56750, Craftsman 947645, Snap-On YA105
SP5665 Adjustable Seal Puller - Lisle 56650, Cornwell LS56650
SPT79 Spark Tester - Lisle 19380, Snap-On (Blue Point) YA832A
SPW100 Brake Bleeder Wrench 5/16 x 3/8 - Vim Tools B456
SPW79M Brake Bleeder Wrench 7mm x 9mm - Vim Tools B460
SPW810M Brake Bleeder Wrench 8mm x 10mm - Vim Tools B457
SRPPC 3pc Seal & O-Ring Puller Set - Astro Pneumatic 9519
SSCA4M 4pc Angled Scraper Set - Mayhew 60004
SSP584 Shaft Type Seal Puller - Lisle 58430
ST20610 Inline Spark Tester - Lisle 20610, Snap-On (Blue Point) YA840
USS39 39-Piece Strut/Shock Installation Tool Kit - Steelman 78554
Electrical:
AE1129 Retractable Test Leads (3 Leads x 10 ft) - Kastar 1129
ATK5 5pc Asian Terminal Kit - Astro Pneumatic 78445
MASTERM23 - 23pc Master Terminal Tool Kit - Wilmar W89732, Steelman 95839, MAC TT95839
RB190 Relay Tester - Electronic Specialties ES190, MAC EST190
RTK825 Master Relay/Fused Circuit Test Set - Lisle 69300
TTK031 12pc Terminal Tool Kit - Sealy VS920, Proto JFE96030, Snap On TT12KT, MAC TT96030, Cornwell JS96033
WT577 Terminal Tool Set with Handle - Lisle 57750, Snap-On TT3KT, MAC TT7750
Diesel:
5056 Automatic Slack Adjuster Puller - OTC 5056
7077 Axle Stud Cone Pliers - OTC 7077
AE4651M 2pc Automatic Slack Adjuster Set - Kastar/Lang 4651, Cornwell RB4651
CW7028 Heavy Duty Clutch Adjusting Wrench - OTC 7028
DCT1570 Heavy Duty Diesel Compression Test Kit - Star Industries STRTU1570
DFW6 Davco 6" Diesel Filter Wrench - Lisle 61110, Cornwell LS61110
LCR5047 Lugnut Cap Remover - OTC 5047
MST5055 Manual Slack Adjuster Puller - OTC 5055
MST7069A Heavy Duty Truck Brake Spring Pliers - OTC 7069A
TBS81 Heavy Duty Truck Air Brake Spring Remover - OTC 5081
Funnels:
OFHD419 (Harley 1999-2006) Threaded Funnel - Assenmacher OFHD419, Snap-On OFHD
HON1033 (Honda/Nissan/Chrysler/Ford) Threaded Funnel - Assenmacher ASMOFHON1033, Snap-On OFHON33
TOY1038 (Toyota) Threaded Funnel - Assenmacher OFTOY1038, Snap-On OFTOY38
GMRD08 (GM/Ford) Threaded Funnel - Assenmacher ASSOFGMRD08, Snap-On OFGMFORD
Shop Equipment:
BMONLO Extra Wide Creeper - Whiteside MTLVMONLOP
CS4D Padded Creeper Seat - Whiteside HRS, MAC CR50R
MCB3 Plastic Creeper (Blue) - Lisle 94102, Cornwell LS94102
LOWZC450 Low Profile Z Creeper - Omega 91000
MWCART 3 Shelf Welding Cart - Eastwood 12236
SP8225A Economy Service Cart - Sunex SUN8005SC
SP8225AS Economy Service Cart Add On Shelf - Sunex SUN8007
SP8230 Service Cart w. Drawer and Lid (Red) - Sunex 8013A
SP8230BK Service Cart w. Drawer and Lid (Black) - Sunex 8013ABK
SP8230BL Service Cart w. Drawer and Lid (Blue) - Sunex 8013ABL
SP8230Y Service Cart w. Drawer and Lid (Yellow) - Sunex 8013AY
SP8230SS Side Shelf (Red) - Sunex 8009
SP8230SSBK Side Shelf (Black) - Sunex 8009BK
SP8225BLDA Locking Drawer for Service Cart (Red) - Sunex 8006RB
SP8230LDBK Locking Drawer for Service Cart (Black) - Sunex 8006CRBBK
SP8230LDBL Locking Drawer for Service Cart (Blue) - Sunex 8006CRBBL
SP8230LDY Locking Drawer for Service Cart (Yellow) - Sunex 8006CRBY
SP8230PH Locking Prybar Holder (Red) - Sunex SUN8011
SP8230PHBK Locking Prybar Holder (Black) - Sunex SUN8011BK
SP8230PHBL Locking Prybar Holder (Blue) - Sunex SUN8011BL
SP8230PHY Locking Prybar Holder (Yellow) - Sunex SUN8011Y
MSDH15R Magnetic Screwdriver Holder (Red) - Mechanics Time Saver MTSSDH15-R
NOTES:
Matco Twist Sockets - Irwin Bolt Extractors, No direct set crossover.
I
ihateminimumwage
MAC
Ratchets:
MRS7FPA 1/4" Spinflex Ratchet (Flex, Rotating Hard Handle) - Proto 4750 (30 tooth)
XRS11FPA 3/8" Spinflex Ratchet (Flex, Rotating Hard Handle) - Proto 5750 (30 tooth)
MR100SPA 1/4" Drive Roto Ratchet - Carlyle CHTR14S100, Cornwell CTGTSHHR (100 tooth)
XR100SPA 3/8" Drive Roto Ratchet - Carlyle CHTR38S100, Cornwell CTGJSHHR (100 tooth)
VR100SPA 1/2" Drive Roto Ratchet - Carlyle CHTR12S100, Cornwell CTGSSHHR (100 tooth)
Screwdrivers
SDB8CR 8pc Combination Screwdriver Set - Proto J1208SCP
SND7F 7pc SAE Nut Driver Set (3/16"-1/2") - Proto J1207SND
SND9M 9pc Metric Nut Driver Set (4mm-12mm) - Proto J1212MND (Set adds 4mm,13mm & 14mm)
Pick Sets:
PSCHP4L 4 Piece Hook & Pick Set - Ullman CHP4-L, Craftsman CHP4-L, Matco CHP4, Snap-On PSLR4
PSCHP6L 6 Piece Hook & Pick Set - Ullman CHP6-L, Matco CHP6L
Pliers:
M318G 8-1/2" Long Nose Pliers with Cutter - Channellock 318
M356G 6" End Cutter - Channellock 356
M447G 7-3/4" Curved Diagonal Pliers - Channellock 447
M728G 7-1/2" Long Reach Diagonal Cutter - Channellock 728
P7WR 7" Pliers Wrench - Knipex 86-03-180
P10WR 10" Pliers Wrench - Knipex 86-03-250
P12WR 12" Pliers Wrench - Knipex 86-03-300
P14 8" Mechanic's Cranked Nose Pliers - Knipex 38-35-200
P162BN 16" Long Reach 45 Degee Bent Needle Nose Pliers - Sunex 3717
P162S 16" Long Reach Straight Needle Nose Pliers - Sunex 3718
P19 8" Compound Leverage Action Center Cutter - Knipex KNP7101-8
P210KN 10" High Leverage Diagonal Cutter - Knipex 74 01 250
P22 8" 70° Bent Nose Pliers - Knipex 38-71-200
P5FDP 5" Flush Cut Diagonal Pliers - Knipex 72-01-140
WSC7 Wire Stripper/Crimper/Cutter - Cornwell CTG60, VIM WS57, OTC 5950S, Carlyle WSCCP
WTR6 Wire Twisting Pliers - Milbar 25W, Matco 25W, SK 7726, Proto J196
PK1250 12pc Convertable Retaining Ring Plier Set - Imperial Stride IR-12K, Craftsman 950464, SK 7612, Matco MST1225, Urrea 360B
PK100 2pc Replaceable Tip Retaining Ring Plier Set - Imperial Stride IR-44K, Wilde 444K, Proto J380
Air Tools:
AH520 Air Hammer - Ingersoll Rand 116
AR1776 3/8" Sealed Head Air Ratchet - SP Air SP-7786
AW280Q 3/8" Composite Impact Wrench - Aircat AC1300TH
AW280QA 3/8" Composite Impact Wrench - Aircat ACA1300TH, Nitrocat 1355-XL
AWP038 3/8" Titanium Impact Wrench - Proto J138WP
AWQP380 3/8" Quiet Impact Wrench - Sunex SUNSX4335
AW232 1/2" Impact Wrench - Chicago Pneumatic CP734
AW284Q 1/2" Mini Composite Impact - Aircat AC1375-XL (Old Style)
AW5500 1/2" Composite Impact Wrench - Ingersoll Rand 2135TI
AW612Q 1/2" Composite Impact Wrench - Aircat ACA1100K, Nitrocat ACA1200K
AWP050 1/2" Titanium Impact Wrench - Proto J150WP
AWQP120 1/2" Quiet Impact Wrench - Sunex SX4345, Husky H4480
AWP075 3/4" Titanium Impact Wrench - Proto J175WP
LT855 Texas Twister Air Hammer Puller Kit - Lock Technology 855, Matco LT855
Hammers:
BH04AV 4oz Antivibe Ball Pein Hammer - Proto J1304AVP
BH08AV 8oz Antivibe Ball Pein Hammer - Stanley 54-144, Proto J1308AVP
BH12AV 12oz Antivibe Ball Pein Hammer - Stanley 54-145, Proto J1312AVP
BH16AV 16oz Antivibe Ball Pein Hammer - Stanley 54-146, Proto J1316AVP
BH24AV 24oz Antivibe Ball Pein Hammer - Stanley 54-147, Proto J1324AVP
BH32AV 32oz Antivibe Ball Pein Hammer - Stanley 54-148, Proto J1332AVP
BH40AV 40oz Antivibe Ball Pein Hammer - Proto J1340AVP
BH48AV 48oz Antivibe Ball Pein Hammer - Proto J1348AVP
CBH16 16 oz Compo-Cast Ball Pein Hammer - Stanley 54-516
CBH24 24 oz Compo-Cast Ball Pein Hammer - Stanley 54-524
CBH32 32 oz Compo-Cast Ball Pein Hammer - Stanley 54-532
CH23 2.5lbs Compo-Cast Piston Dead Blow Hammer - Proto J57-544
CH15DS 15oz Compo-Cast Dead Blow Hammer - Proto J57-530
CH21DS 21oz Compo-Cast Dead Blow Hammer - Proto J57-531
CH50DS 28oz Compo-Cast Dead Blow Hammer - Proto J57-532
CH54DS 48oz Compo-Cast Dead Blow Hammer - Proto J57-533
CH58DS 56oz Compo-Cast Dead Blow Hammer - Proto J57-534
CH90 11.5lbs Compo-Cast Sledge Hammer - Stanly 57-554
DH193AV 3lbs Antivibe Drilling Hammer - Stanley 56-001, Bostitch 56-513
SH2AV 2lb Antivibe Blacksmith Hammer - Stanley 56-003
SCEX35S 35pc Master Extractor Set - Irwin 11135ZR, Snap-on EXD35, Matco MEX35, Cornwell ATC11135
TDCOMBO 76pc Tap/Die Set - Irwin 26376, Matco 676TD, Snap-On TDTDM500A*, Cornwell VG1813816
TDPLUS 117pc Tap/Die & Drill Set - Irwin 26377, Matco 676TDP, Snap-On TDTDM117A*, Cornwell VG1813817
TRCOMBO 40pc Master Rethreading Kit - Kastar 972, Craftsman 52105, Snap-On RTD40
TRCOMBO-48 48pc Master Rethreading Kit - Kastar 971, Craftsman 9712750, Snap-On RTD48
TSS70500 8pc Tap Socket Set - Lisle 70500, Matco TS705, Napa 77-4032
Specialty Tools:
BP21K Battery Terminal Puller - Lisle 54150, Blue Point GA486A, Matco BT54150, Cornwell ECBK706
CBT18A Universal Camshaft Bearing Tool - Lisle 18000, Matco CBT18, Snap-on GA285
FT158B Double Flaring Tool Set - Wilde 250DF, Snap-On TF5A, NAPA 41860
EST190 Relay Tester - Electronic Specialties ES190, Matco RB190
FG002 25 Blade Master Feeler Gauge - Craftsman 40804, Proto J000AA
FG030 25 Blade Metric Feeler Gauge - KD 2274, Proto J00MM25, Matco MG25, Cornwell RBFG30MM
GC950 11 Piece Gasket Cutter Set - Kastar 950, Snap-On PGH8A, Matco 79PK
HB531 Harmonic Balancer Puller/Installer Set - OTC 4531, Matco MST4531
MD4000 18pc AC/Fuel Line Master Disconnect Set - Lisle 39900, Snap-On LDT8, Matco MDS399
MD6000 26pc AC/Fuel Line Master Disconnect Set - Lisle 39850
MS600A Monster Scraper 6" - EZ Red MS600, Matco MS600
SID13BA 13-Piece 3/8" Drive Manual Impact Driver Set - Proto J7099A
TT96030 12pc Terminal Tool Kit - Sealy VS920, Proto JFE96030, Snap On TT12KT, Matco TTK031, Cornwell JS96033
TT7750 Terminal Tool Set with Handle - Lisle 57750, Snap-On TT3K, Matco TWT577
TT95839 - 23pc Master Terminal Tool Kit - Wilmar W89732, Steelman 95839, Matco MASTERM23
Shop Equipment:
CR50R Padded Creeper Seat - Whiteside HRS, Matco CS4D
I
ihateminimumwage
Cornwell
Ratchets:
CTGTSHHR 1/4" Drive Roto Ratchet - Carlyle CHTR14S100, MAC MR100SPA (100 tooth)
CTGJSHHR 3/8" Drive Roto Ratchet - Carlyle CHTR38S100, MAC XR100SPA (100 tooth)
CTGSSHHR 1/2" Drive Roto Ratchet - Carlyle CHTR12S100, MAC VR100SPA (100 tooth)
EC4S12L 1/4" Combination Drive Flex Head (Square and Hex) - EZ Red 4S12
EC4S38L 1/4"-3/8" Combination Drive Flex Head (Square) - EZ Red 4S38L
Pliers:
CCL307 7" Parrot Nose Plier - Channellock 307
CCL317 7" Long Nose Plier - Channellock 317
CCL318 8” Heavy Duty Long Nose Plier - Channellock 318
CCL337 7” Cutting Plier - Channellock 337
CCL410 9-1/2” Nutbuster Plier - Channellock 410
CCL420 9-1/2” Tongue & Groove Plier - Channellock 420
CCL424 4-1/2” Tongue & Groove Plier - Channellock 424
CCL436 6” Diagonal Plier - Channellock 436
CCL437 7” Cutting Plier - Channellock 437
CCL440 12” Tongue & Groove Plier - Channellock 440
CCL460 16” Tongue & Groove Plier - Channellock 460
CCL480 20” Tongue & Groove Plier - Channellock 480
CCL516 6” Slip Joint Plier - Channellock 516
CCL5410 10” Heavy Duty Slip Joint Plier - Channellock 5410
CCL548 8” Slip Joint Plier - Channellock 548
CCL748 8” Long Reach End Cut Plier - Channellock 748
CCL909 Crimping Tool - Channellock 909
CCL911 Cable Cutter - Channellock 911
CTG60 Wire Stripper/Crimper/Cutter - MAC WSC7, VIM WS57, OTC 5950S, Carlyle WSCCP
KD82106 - 2pc Double-X Pliers Set - Crescent PSX203C, Gearwrench 82106, Matco SGW82106, NAPA P900
ML700E 3pc Mini Stripper/Cutter/Crimp Pliers Set - KD 3794, Matco MST700E
Air Tools:
CAT2150 3/8" Composite Impact Wrench - NAPA 6-1122, Matco MT2138
IRC2115 3/8" Composite Impact Wrench - Ingersoll Rand 2115
CAT2135 1/2" Compact Composite Impact Wrench - Matco MT2250
CAT4150 1/2" Composite Impact Wrench - NAPA 6-1123
CAT4152 1/2" Extended Anvil Composite Impact Wrench - NAPA 6-1124, Matco MT2769-2
IRC232A 1/2" Impact Wrench - Ingersoll Rand 232A
IRC8000 1/2" Composite Impact Wrench - Ingersoll Rand 2135
CAT3125 3/4" Compact Composite Impact Wrench - NAPA 6-1125, Matco MT2234
CAT37906 1" Impact Wrench with 6” Extension Anvil - NAPA 6-1138
Hammers:
CTHTC0 13oz. Deadblow - Trusty Cook 0, Estwing CCD13, Matco DB13, Carlyle HDB13
CTHTC1 21oz. Deadblow - Trusty Cook 1, Estwing CCD21, Matco DB21, Carlyle HDB21
CTHTC2 26oz. Deadblow - Trusty Cook 2, Estwing CCD26, Matco DB26, Carlyle HDB26
CTHTC3 45oz. Deadblow - Trusty Cook 3, Estwing CCD45, Matco DB45, Carlyle HDB45
CTHTCS4 32oz. Dead Blow Piston Hammer - Trusty Cook MODEL S4, Carlyle HDBS32
CTHTC7 5.5lb Dead Blow Sledgehammer - Trusty Cook MODEL 7, Carlyle HDBSH55
CTH16BP 16oz. DB Ball Pein - Trusty Cook TCBP16, Estwing CCBP16, Armstrong 68-516, Matco BH16DB
CTH24BP 24oz. DB Ball Pein - Trusty Cook TCBP24, Estwing CCBP24, Armstrong 68-524, Matco BH24DB
CTH32BP 32oz. DB Ball Pein - Trusty Cook TCBP32, Estwing CCBP32, Armstrong 68-532, Matco BH32DB, Carlyle HDBBP32
CTH40BP 40oz. DB Ball Pein - Trusty Cook TCBP40, Estwing CCBP40, Armstrong 68-540, Matco BH40DB, Carlyle HDBBP40
ATC11135 35 pc Master Extractor Set - Irwin 11135ZR, Snap-on EXD35, Matco MEX35, MAC SCEX35S
ATC3101010 48pc Master Extractor Set - Irwin 3101010, Snap-on EXDMS48
VG1813816 76pc Tap/Die Set - Irwin 26376, Matco 676TD, Snap-On TDTDM500A*, MAC TDCOMBO
VG1813817 117pc Tap/Die & Drill Set - Irwin 26377, Matco 676TDP, Snap-On TDTDM117A*, MAC TDPLUS
Specialty Tools:
ECBK706Battery Terminal Puller - Lisle 54150, Blue Point GA486A, Matco BT54150, MAC BP21K
JS96033 12pc Terminal Tool Kit - Sealy VS920, Proto JFE96030, Snap On TT12KT, Matco TTK031, MAC TT96030
LS41900 - Pitman Arm Puller - Lisle 41900
LS56650 Adjustable Seal Puller - Lisle 56650, Matco SP5665
LS61110 Davco 6" Diesel Filter Wrench - Lisle 61110, Matco DFW6
PBT71106 Steel Line Stopper Kit - Private Brand Tools PBT71106, Matco SLSK90, Snap-On LCSS600
RBFG30MM 25 Blade Metric Feeler Gauge Set - KD 2274, Proto J00MM25, Matco MG25, MAC FG030
RBFG26 26 Blade Offset Feeler Gauge Set - Kastar 3275A, Matco FG275
RB4651 2pc Automatic Slack Adjuster Set - Kastar/Lang 4651, Matco AE4651M
Shop Equipment:
LS94102 Plastic Creeper (Blue) - Lisle 94102, Matco MCB3
Craftsman
Impact Sockets:
23766 3/8" Pinless Impact Universal Joint - Matco BUP2BB, Armstrong 19-947, Gearwrench 84427
23765 1/2" Pinless Impact Universal Joint - Matco CUP2BB, Armstrong 20-947, Gearwrench 84691
15397* 10pc 3/8" Pinless Universal Impact Set (10-19mm) - Gearwrench 84921, Armstrong 46-910, Matco SBUPM106TB
15396 7pc 3/8" Pinless Universal Impact Set (3/8"-3/4") - Gearwrench 84922, Armstrong 19-894, Matco SBUP76TB
Pick Sets:
CHP4-L 4 Piece Hook & Pick Set - Ullman CHP4-L, Snap-On PSLR4, Matco CHP4L, MAC PSCHP4L
Pliers:
42454 3pc Flexible Line Clamp Pliers Set - Matco LCS3
45431 7" Cobra Pliers - Knipex 8701180, Matco PC7
45430 10" Cobra Pliers - Knipex 8701250, Matco PC10
45433 2pc Cobra Pliers Set (7" & 10") - Knipex 9K0008025
47412 8" Internal/External Retaining Ring Pliers - Channellock 927
47050* Mini Hose Pinch Pliers - Imperial HP54, KD 3791, SK 7601, Blue Point PHP3, Matco HP54
47051* 9" Hose Pinch off Pliers - Imperial HP55, KD 3792, SK 7602, Blue Point PHP1, Matco HP55
47060* Heavy Duty Pinch Pliers- Imperial HP56, KD 3793, SK 7603, Blue Point PHP2, Matco HP56
950465 6pc Camlock Retaining Ring Pliers Set - Imperial Stride IR-6CK, Snap-On PRH406, Matco MST4306, SK 7780, Urrea 370L, Armstrong 68-056
950464 12pc Quarter Turn Internal/External Snap Ring Pliers Set - Imperial Stride IR-12K, SK 7612, Proto 360B, MAC PK1250, Matco MST1225, Urrea 360B
47394 3pc Quick Switch Snap Ring Pliers Set - Lang 1465, Channellock RT-3, Matco SPRC3A, Snap On PRH503, Wright 9H1265K
Screwdrivers:
49020 6pc Professional Screwdriver Set - SK 86330, Armstrong 66-621
49300 5pc Professional Screwdriver Set - SK 86331
49305 4pc Professional Stubby Screwdriver Set - SK 86335
49302 7pc Professional Torx Set - SK 86333
41612 Professional Scratch Awl - Armstrong 66-450
Pry bars:
43278 3pc Hard Handle Pry Bar Set (12", 17", 25") - Wilde 3-SQ.B/CL, Master Mechanic 134484
43275 12" Hard Handle Pry Bar - Wilde 7B
43276 17" Hard Handle Pry Bar - Wilde 12B
43277 25" Hard Handle Pry Bar - Wilde 18B
43285 31" Hard Handle Pry Bar - Wilde 24B
43286 36" Hard Handle Pry Bar - Wilde 28B
61355-998 3pc Professional Pry Bar Set - Mayhew 61355
Air Tools:
19905 1/2" Professional Impact Wrench - Ingersoll Rand 2131
Specialty Tools:
40804 25 Blade Master Feeler Gauge Set - Proto J000AA, MAC FG002
52060 5pc Bolt Out Set - Irwin 394001
52061 5pc Bolt Out Upgrade Set - Irwin 394002
52166 10pc Low-Profile Twist Socket Set - Matco TSSLP10C
52105 40pc Master Rethreading Kit - Kastar 972, Snap-On RTD40, MAC TRCOMBO
9712750 48pc Master Rethreading Kit - Kastar 971, Snap-On RTD48, MAC TRCOMBO-48
947645 Seal Puller - Lisle 56750, Matco SP56, Snap-On YA105
Tool Storage:
33411 26" Heavy Duty Road Chest - Williams 50946B, International ZRT-2605BK
334111 34" Heavy Duty Road Chest - Williams 50947B, International ZRT-3405BK
Proto
Screwdrivers
J1208SCP 8pc Duratek Combination Screwdriver Set - MAC SDB8CR
Pliers:
J196 Wire Twisting Pliers - Milbar 25W, Matco 25W, MAC WTR6, SK 7726
J278GXL 8" XL Series Slip Joint Pliers - Wilde G263FP.NP/CC
J260SGXL 10" XL Series Groove Joint Pliers - Wilde G271FP.NP/CC
J228GXL 8" XL Series Needle Nose Pliers - Wilde#
J209GXL 7" XL Series Heavy Duty Diagonal Cutting Pliers - Wilde 4276/CS
J360A 6pc Convertable Retaining Ring Plier Set - Imperial Stride IR-090K, Armstrong 68-015
360B 12pc Quarter Turn Internal/External Snap Ring Plier Set - Imperial Stride IR-12K, SK 7612, Matco MST1225, Snap-On SRPC112, MAC PK1250
Specialty Tools:
JFE96030 12pc Terminal Tool Kit - Sealy VS920, Snap On TT12KT, Matco TTK031, MAC TT96030, Cornwell JS96033
J000AA 25 Blade Master Feeler Gauge - Craftsman 40804, MAC FG002
J000BR 6 Blade Non-Magnetic Feeler Gauge - Snap-On FB325A, Matco FG23A
J00MM25 25 Blade Metric Feeler Gauge - KD 2274, Matco MG25, MAC FG030, Cornwell RBFG30MM
SK
Screwdrivers:
86330 6pc Cushion Grip (Pro) Screwdriver Set - Craftsman 49020, Armstrong 66-621
86331 5pc Cushion Grip (Pro) Screwdriver Set - Craftsman 49300
86335 4pc Cushion Grip (Pro) Stubby Screwdriver Set - Craftsman 49305
86333 7pc Cushion Grip (Pro) Torx Set - Craftsman 49302
Pliers:
7601 Mini Hose Pinch Pliers - Craftsman 47050*, Imperial HP54, KD 3791, Snap-On PHP3, Matco HP54
7602 9" Hose Pinch off Pliers - Craftsman 47051*, Imperial HP55, KD 3792, Snap-On PHP1, Matco HP55
7603 Heavy Duty Pinch Pliers - Craftsman 47060*, Imperial HP56, KD 3793, Snap-On PHP2, Matco HP56
7612 12pc Quarter Turn Internal/External Snap Ring Pliers Set - Imperial Stride IR-12K, Proto 360B, Matco MST1225, MAC PK1250, Craftsman 950464, Urrea 360B
7780 6pc Camlock Retaining Ring Pliers Set - Imperial Stride IR-6CK, Matco MST4306, Snap-On PRH406, Urrea 370L, Craftsman 950465, Armstrong 68-056
7726 Wire Twisting Pliers - Milbar 25W, Matco 25W, MAC WTR6, Proto J196
gsingh
NOVA
Thanks for doing this.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
I
ihateminimumwage
Thanks guys! I'm finally having a couple of beers to get rid of the headache from reading numbers on my computer all day. There's a reason I could never work in an office!:willy_nil
As I stated in the first post, the tools with a '#' are the ones that I still need to dig up a number for. Some aren't listed as singles online, and some I just couldn't stand to keep staring at, so I put them off for a minute (can only stare at re-branded pliers and hammers online for so long).
That said, if anyone has a set of Snap-On hard handles and can get me the missing numbers for these drivers:
SDD# 12" Blade Slotted 3/8 - Williams SDS-33
SDD# 3" Blade Slotted 3/16 - Williams SDR-22
SDD# 3" Blade Electrician's Tip 3/16 - Williams SDE-43
SDD# 6" Blade Electrician's Tip 3/16 - Williams SDE-46
Also looking for 2 of the Craftsman numbers from the 3pc hose pinch plier set:
Matco HP54 Mini Hose Pinch Plier - Craftsman# , KD 3791, SK 7601, Blue Point PHP3
Matco HP56 Heavy Duty Pinch Plier - Craftsman# , SK 7603, Blue Point PHP2
Going to keep digging and adding more. I have way to many air tool reference numbers to sort through. Hoping to eventually be able to have numbers for individual Snap-On to Williams USA sockets and Blue Point to Williams Taiwan Sockets.
Cheers folks!:beer:
EDIT: If anyone is having a problem seeing the company logo pics at the top of each list because of their phone, let me know and I'll type the company name in underneath.
abvw
Toronto, Canada
Some of those "Williams" tools are considered to be obsolete Snap-On tools, not exactly an equivalent.
JDSV
Sierra Vista, AZ
While I'm not entirely positive, I think the MAC roto ratchets and the Napa Carlyle ones are the same. They both have a very similar or the same head design, and are both 100 tooth count. The grips differ, but I think that is acceptable for this thread. However, I do not know who the original OEM for this roto ratchet. While the Napa prices are more appealing, I think the thicker grips on the MAC would be my preference since I have somewhat large hands.
MAC
MR100SPA - 1/4" - $98.99*
XR100SPA - 3/8" - $114.99*
VR100SPA - 1/2" - $139.99*
*Per the November 11, 2013 Price List
Carlyle
CHTR14S100 - 1/4" - $49.99*
CHTR38S100 - 3/8" - $64.99*
CHTR12S100 - 1/2" - $74.00*
*Per my Napa location, may vary
I
ihateminimumwage
Updated with the Snap-On - Precision Instruments Torque Wrench Numbers, and a lot of "Specialty Tools" added to Matco.
Also been sorting through Part numbers on Circlip/Retaining Ring/Snap Ring Pliers. Holy overlap!:willy_nil
Brownsfan
Cleveland Ohio
Heres some help with Mac and Cornwell USA made pliers. They have Channellock part numbers in their numbers. Ex... Mac M338G= Channellock 338 Cornwell CCL338= Channellock 338.
I saw you had some of the Mac Channnelock labeled Knipex. The Knipex will usually start with a P. The CL rebrands will start with M and end with G. With the CL part# in the middle
I
ihateminimumwage
Excellent. Thanks for the info. Explains the M coded pliers I couldn't find, and should help with some Cornwell info.:thumbup:
EDIT: Thanks to your info, I was finally able to update the Cornwell post. Thanks again.
davethorik
Norka, Ohio
just thought I'd mention on the armstrong ratchets, at least the locking flex versions, are still only 60t, while matco are 88. The rebuild kits will swap, though.
I
ihateminimumwage
I can't seem to find either one of these (matco or astro) :confused:
Am I missing something?
It looks like it's an older model that is no longer produced. Thanks for bringing that to my attention, I can either pull it or make a section for Out of Production tools and update it as need be.
The air tools have been a pain, since all these companies seem to change who's tools they're selling every 2-3 years. Then there's MAC who is currently selling impact wrenches from 5 different manufacturers.
Many of the websites haven't made it any easier (Snap-On, MAC) to find what I'm looking for, or seeing what is still in production.
If I type in "3/8 Ratchet" into the MAC search all kinds of misc stuff pops up. If I go through all the tabs to get to the 1/2" ratchets, the 24" flex isn't on the page. If I google "MAC VR24FPA" the link on their page for the 24" Flex pops right up. It definitely has slowed things down.
I'll see if I can find any info on an OEM, but I'll post the MAC/Carlyle numbers up in the meantime. If the forum is okay with that?
EDIT: Case in point; the Roto-Ratchets aren't anywhere to be seen on the MAC site, just on PDF fliers.
OxJaw
Medina, Ohio
The 1/2" regular handle (12-992) is also only 60 tooth. You are correct about the the rebuild kits as well, mine all have Matco 88 kits in them now.
Armstrong also offers the 88 kits for 1/4" and 3/8" but not 1/2".
Brownsfan
Cleveland Ohio
The Cornwell rotos are identical to the macs. All 3 are COO Taiwan.
JDSV
Sierra Vista, AZ
...I'll see if I can find any info on an OEM, but I'll post the MAC/Carlyle numbers up in the meantime. If the forum is okay with that?
I was able to find the 1/4" ratchet: http://www.mactools.com/ShopOnline/Product/tabid/120/productid/331465/variantid/322226/Default.aspx
But when searching for the 3/8" and 1/2" all I come up with are the repair kits.
I think your right. The reversing mechanism is a bit different (Cornwells goes all the way around, while MACs has ressesed spaces for grip), but both are 100 tooth gear count. Even the length of the tools are the same.
Cornwell
CTGTSHHR - 1/4" - $80.00*
CTGJSHHR - 3/8" - $95.00*
CTGSSHHR - 1/2" - $105.00*
*Per Cornwells website
I
ihateminimumwage
Cornwell
Thanks! Added to the Cornwell post.:thumbup:
Also addressed the Matco/Armstrong tooth counts.
Thanks for the input, folks! Keep it coming!:rocker:
ADSR
I would be much abridged if you could find out the equivalent to the SO PWCS7CF - Wire stripper/crimper/ cutter.
That looks like SO only. And at 43 bucks, prob a little cheaper on the truck, i don't even think i would look for something else.
I have been wrong before tho:p
dleonard1122
New Jersey
Yeah I know 43 bucks for a SO pliers is pretty cheap to begin with. The cheapskate in me was just wondering if the off-truck equivalent would be around $20[emoji39]
techenthusiast
Is there an equivalent to the snap on hole aligning hook bars?
