Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-18-2010, 04:40 PM   #2201
sanddrag
Senior Member
Default Re: The Harbor Freight PASS/FAIL Thread...
Quote:
Originally Posted by granitestater View Post
These bar clamps, item 46805 are a pass.
First time I used one, the plastic nub that the orange plastic pivots on inside snapped off. I drilled and put a #10 machine screw through the whole thing, and it's much better now. When clamped tightly, it's a bit rough on the fingers to push the darn button to release it. The design is not great, but they seem to work ok for the $2 I got them for a while back.
sanddrag is offline   Reply With Quote
Old 12-18-2010, 04:42 PM   #2202
BiltFordTuff
Senior Member
BiltFordTuff's Avatar
Quote:
Originally Posted by ROCK4185 View Post
Does anyone have a report on the Pittsburgh torque wrenches??
which ones, i have the 3/8" clicker type and it works fine,
BiltFordTuff is offline   Reply With Quote
Old 12-21-2010, 07:29 PM   #2203
JohnFreeman
Senior Member
JohnFreeman's Avatar
http://www.harborfreight.com/recharg...ght-95181.html
It's a strange form factor 24 LED light, rechargeable
The good news : It's one VERY bright light
The bad news: It self discharges in a week
What good is a dead light? So---> FAIL
I had high hopes for this, but it inexplicably self discharges if left off, in only a week.
I should have known better...
__________________
Looking to buy Par-X tools, please IM me if you have any FS.
JohnFreeman is offline   Reply With Quote
Old 12-21-2010, 08:12 PM   #2204
bchee
Senior Member
bchee's Avatar
Maybe it needs a few more charge/discharge cycles
bchee is offline   Reply With Quote
Old 12-22-2010, 02:20 AM   #2205
TN_GARAGE
Senior Member
I'd return it/exchange it.
You might have gotten a bad apple.
User's manual says to charge it every month if not used.
TN_GARAGE is offline   Reply With Quote
Old 12-22-2010, 07:36 AM   #2206
jakeb
Senior Member
jakeb's Avatar
I agree these are a pass.... I actually used the bar of the short one as a BMW fan clutch removal tool....
Took the fixed clamp off, bolted the bar to the water pump pulley to hold it from moving. Didn't bend a bit when using a fairly long 32mm wrench on the fan clutch nut.
jakeb is offline   Reply With Quote
Old 12-22-2010, 06:58 PM   #2207
JohnFreeman
Senior Member
I should take it apart and fix it...can't be much in there.
Like most/all HF stuff, it's ALMOST good and might be, if you spend the time to fix it.
Sigh....
(It's a month or so old, before I noticed this... no receipt now, etc...)
John
__________________
Old 12-22-2010, 08:55 PM   #2208
41ratrod
Senior Member
41ratrod's Avatar
found a HP battery drill in my yard had the cast broken and had some of the screws missing . put it back together and it works, I had for about 4 years
its slower then most drills, went to get another battery and got a new drill
in the cast with battery and charger cheaper then just battery alone.
My Dewatt 18 volt drill is alot better and is used more often.
jack stands pass
car dolly pass (one wheel broke) two sets
tin snips sucks
24" hyd. cyl. for engine hoist pass
pipe bar clamps are ok broke one had bad casing
pop rivet gun pass ( sears one broke and they would not replace it lest then
a year old)
sears torque wrench 1/2 "leaks oil and not right bought it on sale and there was no return on it .
41ratrod is offline   Reply With Quote
Old 12-23-2010, 08:30 PM   #2209
southernfriedcj
Senior Member
southernfriedcj's Avatar
Quote:
Originally Posted by beelsr View Post
nitrile/latex gloves - FAIL, buy them at costco/sam's. HF's are pre-hardened and brittle.
I use a box per week of the blue nitrile HF gloves and they are great. The latex HF gloves have never let me down either.
southernfriedcj is offline   Reply With Quote
Old 12-24-2010, 09:01 AM   #2210
IONH
Senior Member
Sigh....
John
It's stuff like this that gives HF a bad name. People buy stuff and, if it happens to be broken, they sit on it till the excuse time kicks in. This way, they can't exchange the item for one that potentially works perfectly and will always badmouth HF for the item.
IONH is offline   Reply With Quote
Old 12-24-2010, 11:18 AM   #2211
TN_GARAGE
Senior Member
Quote:
Yep. HF is a bit inconsistent that's why you have to take it home and immediately put it through its paces before you lose the receipt and the warranty runs out. Guess that's the price you pay for inexpensive tools.
Old 12-24-2010, 01:20 PM   #2212
Tom2
Senior Member
Quote:
Yea, I use the latex gloves daily and love them. They hold up better than any other latex/nitrile gloves I've ever tried. nice and stretchy so they stretch instead of breaking easily.
Tom2 is offline   Reply With Quote
Old 12-24-2010, 01:30 PM   #2213
Fueler
Senior Member
Fueler's Avatar
I also use the blue gloves. Boy was I surprised to find them holding up far better than some more expensive name brands. That will probably mean they will be of cheaper quality as time goes on since we like them. Pass
__________________
Dave Koehler - Koehler Injection
Fuel Injection - Nitrous Master software - Balancing
"Never let a race car know that you are in a hurry."
Fueler is offline   Reply With Quote
Old 12-24-2010, 01:48 PM   #2214
xcgates
Senior Member
Do the blue gloves have a pattern on the fingers/palm?
__________________
-Anonymous Coward
In order of acquisition: '85 Kawi ZN700, '99 Subie Legacy Outback, '07 Ducati ST3, '79 Suzuki GS850G
In order of use: Duc, Kawi, ..., ..., Subie (where did the keys to the Subie go???)
Beer is an acquired taste. You should acquire the taste of the cheap stuff.
Shop Motto: If it ain't broke, we haven't fixed it yet.
Blaidd Drwg
xcgates is offline   Reply With Quote
Old 12-24-2010, 08:15 PM   #2215
subarub4
Senior Member
subarub4's Avatar
blue nitrile gloves? If so no
subarub4 is offline   Reply With Quote
Old 12-24-2010, 08:37 PM   #2216
yjcrawler
Junior Member
yjcrawler's Avatar
the big gantry craine works awesome epic pass
the "el cheapo" sissor trans jack it works okay for occational use
__________________
help distroy america join an enviromental club...f*** the e.p.a
yjcrawler is offline   Reply With Quote
Old 12-24-2010, 08:41 PM   #2217
yjcrawler
Junior Member
yjcrawler's Avatar
also the little air angle die grinder the 10 dollar one pass pass pass had one used the crap out of it for 3 yrs never even oiled it gave it away and lasted that guy two more yrs
__________________
Old 12-26-2010, 08:36 PM   #2218
IONH
Senior Member
Absolutely. I've also been prone to buying an item here and there and not touching it for months. My father purchased a band saw for me (93762) last February and I did not open it up until earlier this month. Even though the box and foam were in good condition, the motor had a dent in it and the bracket it mounted to was bent. Anyway, I straightened out the bracket and with the dent the motor still works. I doubt they'll fix it under the 2 year warranty should it fail, but I wish I had opened it sooner so I could have brought it back right away.
I also have a 40 pound blasting cabinet still in the box for a year or so now... hope it's not beaten up as well. But at least that's an item of basic construction and I can probably fix anything which may be wrong with it.
Old 12-28-2010, 01:26 PM   #2219
brats.n.harleys
Senior Member
brats.n.harleys's Avatar
6'' cross slide vise- pass
only used on my drill press to line up items without messing with removing bolts or clamps, cleaned it up a little, some lock tite on the screws and its awesome
http://www.harborfreight.com/media/c.../image_224.jpg
__________________
Always remember you're unique. Just like everyone else.
brats.n.harleys is offline   Reply With Quote
Old 12-28-2010, 03:03 PM   #2220
Vern X-100
Junior Member
Vern X-100's Avatar
Hand Riveter set w/ gun and rivets - FAIL
http://www.harborfreight.com/hand-ri...set-38353.html
Couldn't even get the first rivet to set. In fact, the rivet got stuck in the gun. Threw this POS as far as I could, walked over to it and threw it even further outta sight.
Vern X-100 is offline   Reply With Quote
Reply
Tags
harbor freight
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
