Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#221 |
Senior Member
Plastic Socket Holders, Set of Three....PASS
The website list these as being 10in long, however to my surprise they are 14in long! They come with plenty of sockets, 15 1/2in, 16 3/8in, and 15 1/4in. The only downside out of the box was that the 1/4in socket studs were consistently not able to fit sockets since they had some excess plastic when they were molded. With 15 min and a dremel they all were fixed. ![]() 3 Piece Hex Drill Socket Extensions....Pass They work fine and cost less than the Craftsman ones. I've used these in my Bosch Impactor and they held up. ![]() 4 Piece Socket Adapter Set...PASS Not much to say other than they haven't broke.
#222 | |
Senior Member
Quote:
http://www.harborfreight.com/cpi/cta...emnumber=94036 |
#223 |
Senior Member
Anyone have the pneumatic Roller seat?
Only $20 in my flyer..Hard to beat..Thinking of picking up a couple.
#224 |
Senior Member
I'd have some concern over load capacity with the height adjust part, but the cheapy $10 rolling seat works fine for me at em, eh 240 lbs.
Rolling seat, PASS http://www.harborfreightusa.com/usa/...do?itemid=3338 |
#225 |
Senior Member
#226 |
Senior Member
i use one almost every day. they're very durable
__________________
#227 |
Senior Member
Sounds like a good deal. Thanks..
#228 |
Senior Member
#229 |
Senior Member
I have these too and so far they haven't broken, but I don't feel I've used them enough to give a fair assessment.
#230 |
Senior Member
New additions to my lists;
28 Degree frame nailer. PASS. Got it for 56 bucks. Been using it to frame a shed and after I figured out why it was splitting wood it has worked great. The wood splitting was not the nailer, the nails were 'too pointed' Dulling the nails fixed that and now it works great on 60 pounds of air. Cheap angles PASS. What the heck, an aluminum angle for 1.50? what's to go wrong. Evaporust. Stuffs great PASS. Autodarking welding helmet. Not only works great, it's fun to play with. PASS. FAIL the spot welder gun, like the Eastwood unit but won't work on A/C. Says it will on the box, but a piece of stapled paper inside says it won't. It won't. |
#231 |
Senior Member
They do flex quite a bit with the 1/2in standard depth chrome sockets. I do not remove entire rails from the tool chest though so it isn't a factor for me. I ended up buying several 3"x14" 1/4" thick poplar wood strips and screwed two rails to a strip to keep them upright. With the poplar base, I can remove two sets at a time and there is no flex.
#232 |
Senior Member
http://www.harborfreight.com/cpi/cta...unction=Search
![]() Anyone have this cabinet? Its listed for $176 in my local ad..Plus the 20% off coupon..Puts it around $140. The drawers are a bit small..but good for most small hand tools, and other misc machine work stuff. Last edited by Tom2; 02-19-2009 at 08:06 AM. |
#233 | |
Senior Member
Quote:
The bottom cabinet is crammed full of heavy body repair tools, and it has held up nicely. It uses a locking bar, which makes it a "pain" to lock/unlock, but it works well enough. The krinkle finish is very tough and the casters are of decent quality. They hold up well on a concrete floor, but being small, they don't work well on a rough sevice. For that price it's well worth it -- just don't expect "ball bearing" performance.
__________________
"...The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants..." Thomas Jefferson |
#234 |
Senior Member
Thanks for the review! I just realised though..I probably cant use the 20% off with the $176 coupon in my ad. Dang.
#235 |
Senior Member
I have the one with the seat back. Can't find it on their website. The bottom black sheetmetal base with wheels is the same. This thing is no good. FAIL. The base is made of light gauge sheetmetal and cant support the load above causing the wheels to cock inward when you sit and roll. And no I'm not overweight. 180lbs.
#236 |
Senior Member
Central Pneumatic "Earthquake" 3/8" drive impact wrench - PASS
Central Pneumatic "Earthquake" 1/2" drive impact wrench - BIG PASS Just purchased the 13pc SAE and 14pc Metric shallow-well "Earthquake" impact sockets to complement the Stanley SAE and Metric deep-wells that I bought at Wal-Mart a couple years ago, so I can't comment on them much yet, but I'm sure they'll do just fine. |
#237 |
Central Pneumatic Auto Drain - Fail (w/ Campbel Hausfeld Compressor)
Tubing supplied with the kit appears to be the standard size tubing for air horns, air brakes and similar from NAPA. The air hose on the CF 60 gl from TSC is the same OD but much smaller ID so the fittings with the auto drain kit will not work with the fittings on the compressor. Every single fitting was loose and required removal and new teflon tape. In the end I extended the drain valve on the compressor. Pry Bars - Pass Impact Sockets - Shiny, thick walled set - Pass |
#238 | |
Senior Member
Quote:
He upgraded the tubing to copper, and for $10, what do you expect? |
#239 |
Junior Member
Has anyone used the large english wheel?
__________________
MacMotor was here |
#240 |
^^^ I didn't "expect" anything and simply offered my opinion.
| Tags |
| harbor freight |
| Thread Tools | |
| Display Modes | |
