Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#161 |
Senior Member
I have the same cheap dollies (I think $80 for all four) and I had a hard time moving my car around (jeep project with a FIBERGLASS tub). I just assumed it was because the floor was pretty rough concrete.
#162 |
Senior Member
PASS!!! I have both the 3/8" and 1/4" version of these and I like them a lot. The ratcheting action is very very precise. The only improvement they could make would be to have a little more grip on the outside. I'd recommend these for any tool box. I think I bought them on sale for $6 for the pair.
#163 |
Senior Member
US GENERAL RECHARGEABLE 24 LED WORK LIGHT
ITEM 95181 A big PASS. I love this thing. Very bright, had for over a year. Holds a charge for a long time. |
#164 | |
Quote:
Jeb |
#165 |
Senior Member
has anyone used their tap and die sets?
#166 |
Senior Member
#167 |
Senior Member
Fail... but all I can afford because people keep outbidding me at auctions. Good bandsaws go for big money and when you need one, I guess you use what you can get. Hard to keep tensioned and on track, motor wont even turn over on a new blade. No way it makes 1/4 hp, let alone 1 HP.
![]() Fail... Valve is hit or miss, sometimes it starts, sometimes it hisses, however, it's a good cheapie for a single project vs. the $100 for a real one. I'll be getting an IR or CP to replace this one. ![]() Fail... The good news is they dont' last long enough to explode but I'd still wear ballistic safety glasses. ![]() They also used to make a Grinder/Buffer in green hammer finish for about $100. This is a beast but it pulls every ounce of 25 amps when you start it up... and don't wear baggy clothes. I've polished A LOT of aluminum with this sucker and it' going strong... too bad they discontinued it. Awesome pass: natural bristle brushes can handle the worst strippers or paints and you just pitch them. If there's one thing the chinese know... it's paint brushes.
__________________
Poor guy, big garage. |
#168 |
Senior Member
stock up on those brushes.
I've been buying, using then throwing, them for years but just last week I went to the cheap shop and the chinese brushes had horrible man-made bristles.
__________________
Best Cheers Frank --------- I !__[_]|\___ I ____|"_|"__|/ Range Rover Vogue SE "(o)======(o)" Beluga Black LPG "TAZ" |
#169 |
Senior Member
46 pc. Radio Removal kit BIG PASS.
http://www.harborfreight.com/cpi/cta...emnumber=96675 I think this is the Astro Pneumatic kit everyone else sells for much more $$. ~Steve |
#170 |
Senior Member
Evapo-rust, major PASS. I think this is the best thing I've purchased at HF.
![]() There was a thread on this product a while back, and I figured all rust treatment products were alike so I got HD's Must for Rust instead. It's OK, but not nearly as good as Evapo-Rust. I am truly impressed. None of my tools are rusty anymore, and on most of them, you wouldn't be able to tell they ever were. Dad's old rusty tools look new.
__________________
Delmar O'Donnell Bolster. A bona fide Soggy Bottom Boy. There is no certainty; there are only people who are certain. --Renouvier Casually collect Proto with pebble field & other Proto Los Angeles items. Last edited by Bolster; 01-13-2009 at 07:28 PM. |
#171 |
Senior Member
HF wrench racks (made in India)- FAIL I had to cut the heck out of them with tin snips to be able to fit my wrenches. Only a few of the slots would fit a wrench. The rest I had to modify.
__________________
-Steve ΜΟΛΩΝ ΛΑΒΕ RIP TSgt Jason Norton and SSgt Brian McElroy, KIA 22 Jan 06 near Taji, Iraq. You'll never be forgotten... |
#172 |
Senior Member
10" Compound sliding saw PASS
I bought one for the cottage build. These are not for doing a hardwood floor project, but for general zapping of construction lumber, I have thousands of cuts on the original orange version. The safety switch was bypassed immediately, its awkward. It is so nice to be able to cut 2 x 8 and 2 x 10 lumber with it. Did I mention it did the 3 stall garage last summer too? I also bought the new style silver one and tossed it in the basement for the remodel I'm doing, no more carrying them around! 6 Ton Jack Stands PASS (Sturdier than the old set I've had for 30 years) Car Dollies PASS (I have a smooth floor, push the car myself) Air Regulators/Moisture traps FAIL (They all leak or restrict air flow too much) Purple Brad Nailer PASS (Lower your air pressure to 80, or it will blow up, ask me how I know) Recip Saws PASS (light duty, but I have one with a metal blade and one with a wood blade loaded for $60 less than a single Dewalt was gonna cost) 4.5 Grinders PASS ( I must be lucky, although I rarely run one for more than 5-10 minutes at a time. I now have 4, 2 up north, 2 at home. Cutting disk in one , grinding disk in another, all for less than 50 bucks!) Automatic Float Battery Chargers PASS (5 bucks on sale, my battery failures have dropped 80% since I started sticking these on everything) |
#173 |
Senior Member
Okay, I'll chime in:
SAE/Metric Pittsburgh PRO stubby combination wrenches. Old ones made in Taiwan. ------ PASS Too bad they don't sell these anymore. These are very good quality with a great finish. Light blue gloves----- FAIL. 24" 3/8 breaker bar----- PASS under light use. RED finger ratchet mentioned earlier------PASS Made in India wrenches....ALL of them----- FAIL I could cast things that look better and function better in my kids sand box! Large MM 1/2 impact sockets-----PASS Screw Drivers (SO look a likes)-----PASS under light use. (Household) Black tape------ PASS but needs to be kept cool. 4" Bench vise (Blue One)------ PASS Home use only and the screw is very tight. Ball Pein Hammers (Fiberglass handles)----- PASS Dry tile cutter (not the wet saw)----- PASS worked good for me. Heat gun------ FAIL 22ga nailer (Blue one)-----PASS Used a lot and works great. |
#174 |
Senior Member
Hose grip pliers - FAIL. I feel like I've used these enough to make a fair assessment, and I really don't like them. They flex too much so they don't provide much grip, and the teeth don't seem to bite into the hose either. On 2 of them the jaws bent.
http://www.harborfreight.com/cpi/cta...emnumber=37909 |
#175 |
Senior Member
I figured out a cool way to view this thread. Search for "harbor freight pass fail" using the search function. It will highlight PASS and FAIL in red, making it easier to read.
#176 | |
Senior Member
Quote:
__________________
If guns cause crime, all mine are defective. Ted Nugent "A man with a gun is a citizen. A man without a gun is a subject. " John Lott "Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis |
#177 |
Senior Member
#178 |
Senior Member
He said drilling hammer, not hammer drill.
__________________
#179 |
Junior Member
Mini Grease gun ----PASS
(refillable Dualco clone) works as good as the Dualco I have had both http://www.harborfreight.com/cpi/cta...emnumber=93486 Cable Cutters (red handle older style) ----PASS I haven't seen these in a few years, they were FELCO copies. for small gauge cable they have worked great for years. heres what they would look like, but this is a link to the real deal FELCO http://www.felcousa.com/felco/pages/...ame=FELCO%20C3 Grinding Wheel Dresser ----PASS for the $3.00 works well http://www.harborfreight.com/cpi/cta...temnumber=1682 Pro Seal Threadlocker Blue& Red ----PASS seems to be as good as loctite and way cheaper http://www.harborfreight.com/cpi/cta...emnumber=96059 Emory cloth in box on roll ----FAIL one use and pitch it, it's cheap but the PITA factor is high http://www.harborfreight.com/cpi/cta...emnumber=93069 |
#180 | |
Senior Member
Quote:
| Tags |
| harbor freight |
| Thread Tools | |
| Display Modes | |
