Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#2021 |
Senior Member
Awesome. Thank you for posting that. I was looking at those just the other day.
#2022 |
Senior Member
Caution: Paul bought his at least a year ago. There has been a cheapening since so now they aren't nearly as good as they used to be. They use cheaper casters now that don't work very well. Follow Shadowdog's advice and check they work with weight on them, and/or use the "hold them vertical and rotate and make sure wheels caster by themselves and don't get hung-up" check somebody else suggested
__________________
#2023 |
Senior Member
this is true, at least a year or two ago. Casters are great, hardwood, rolls like a champ. I've moved sofa's, steelcase cabinets, tons of other stuff. But as you know it's still HF, word to the wise.
#2024 |
Senior Member
Paul, I bet they have the plastic bearing retainers/dust shields between the caster frame and mounting plate. The new ones do not.
__________________
#2025 |
Senior Member
Yea, I was shopping the casters there last week(I imagine they're the same as used on the mover dolleys).. They all seemed pretty crappy and were about the same price as HD/Lowes. I ended up still buying 4 of the clear ones with swivels/brakes
#2026 |
Senior Member
Those are a huge pass. I have 6 of them with Big Block Chevy Blocks on them. I have one that is home to a Valkyrie engine and a few spares for moving heavy stuff around my shop. A lot of bang for the buck. all mine are about 7-8 years old and cost a whopping 7.99 each
__________________
Try to be the person your dog thinks you are. Last edited by mrholeshot; 11-01-2010 at 02:53 PM. |
#2027 | |
Senior Member
Quote:
I also have 2 of the smaller ones which I put a 3/4" sheet of wood on and use to either put car wheels directly on or jack stands on so I can wheel around cars which no longer have front suspension.
__________________
My Garage Refurb Mr. Heater 75k BTU Installation Stacked two 44" HF 13 drawer boxes |
#2028 |
Senior Member
my school's got about 50 of them, they're awesome. my uncle builds custom kitchen cabinets and has about a dozen of em too, they work very well.
__________________
99 GMC Sierra Classic 1500 Z71 05 Polaris XC SP 500 |
#2029 |
Senior Member
4 Piece Heavy Duty Pry Bar Set - 1654 - PASS
http://www.harborfreight.com/clearan...-set-1654.html I've have a set of these that I've used for over 10 years (8+ everyday heavy use as an automotive tech.) They've held up to stress I've placed on them and handles hold up to automotive chemicals well. 2 Lb. Brass Hammer - 42000 - PASS http://www.harborfreight.com/2-lb-br...dle-42000.html I thought for sure that every time I would strike something, brass would fly all over hell, and ultimately the handle would snap off, but I've been using mine for a couple years and no problems yet. 3 HP, 21 Gallon, 120 Volt Vertical Air compressor - 94667 - PASS http://www.harborfreight.com/3-hp-21...sor-94667.html It's a pretty good compressor for what it is. It isn't a big dog and I didn't buy it expecting it to do the things a bigger compressor would be needed to do. My only complaint is the wheels, but for what I paid for it (< $120), it was a good buy and I can live with that issue. 3 ton floor jack - 34271 - PASS http://www.harborfreight.com/3-ton-s...34271.html?p=3 I've been using this jack for many years (3+ years everyday heavy use up until 3 years ago). It's been used, abused, and overloaded and it's still around to tell the story. I originally bought this jack because I didn't want to take my good Sears jack I had at home, to work. It's far exceeded my expectations for a harbor freight jack. Now it's my go-to jack here at home. (No longer fixing cars for a living...
#2030 | |
Senior Member
Quote:
![]() don't hit with hammer Ed
#2031 | |
Senior Member
Quote:
Electric Paint Spray Gun-------FAIL http://www.harborfreight.com/electri...gun-47274.html |
#2032 |
Senior Member
Anyone have any experience with the 12v high volume air compressor? I'm looking to keep one in my truck for on the go inflation or just a quick inflate at the house. Item number is 96068.
3ton jack 34271 - pass. Only thing I wish is the lift was faster with less pumps. 3ton jack stands 38846 - pass. 6ton jack stands 38847 - pass. zip ties - pass. I've used them for light duty applications. I'm not sure what the item number was for the ones I bought. clear safety glasses 9916 - pass. 11" canvas tool bag 35539 - pass. I'm sure the same bag in 15" is a pass also. low pro creeper 2745 - pass. red shop towels 46163 - pass. This is all I can think of off the top of my head. Last edited by usmc_noma; 11-04-2010 at 03:38 AM. |
#2033 |
10" socket rail (set of 3) #96343 http://www.harborfreight.com/10-inch...ree-96343.html 2/3 Pass
The 1/2" holders take way too much force to get the socket on or off. The 1/4" and 3/8" holders work well. |
#2034 | |
Senior Member
Quote:
#2035 |
Cast iron, rubber tire casters - PASS
http://www.harborfreight.com/3-inch-...ter-38709.html 1/2" Drive 25" Breaker Bar - PASS http://www.harborfreight.com/1-2-hal...bar-30395.html Large Bearing Splitter - PASS http://www.harborfreight.com/large-b...ator-3979.html Three Jaw Pullers - FAIL http://www.harborfreight.com/4-piece...set-40965.html |
#2036 | |
Senior Member
Quote:
http://www.harborfreight.com/12-volt...sor-96068.html |
#2037 |
Senior Member
96157 - 5-in-1 Portable Power Pack - Preliminary PASS
![]() Bought this for $80 on-sale for Inside Track Club. Fairly solid construction, gauges are not heinously inaccurate. Successfully started two cars with dead batteries. The battery clamps are a tad small but open plenty wide and grip well. Pumped up four tires with the pump. Inverter ran a light for an hour. Not bad. Smells like cheap Chinese crap, but that will dissipate as the probably toxic chemicals leach out of the rubber and plastic. My only wish is that there was a compartment to store at least the DC charging cord.
__________________
#2038 | |
Senior Member
Quote:
#2039 |
Senior Member
Their autodimming eelding helmets are great and a good deal for $35 on sale.
#2040 | |
Junior Member
Quote:
In fact, I would label them "Likely to FAIL and damn near kill you". The threaded rod is NOT a hardened bolt, but instead simply a soft steel piece of threaded rod with a nut screwed on and then pinned to the rod with a rolled piece of sheet metal. For me, the pin sheared, the thread stripped and the nut came off. Thankfully, the strut was relatively un-compressed at the time. It ended up being more trouble than it was worth, because my job was incomplete and I had to make an extra trip the next morning to Sears to get some adequate Spring Compressors. OTOH, I liked their electric impact wrench (45252) I got on sale for like $30 and give it a PASS. Still use it often and for the price it can't be beat. It regularly goes on sale for less than it's currently listed $50. My general rule of thumb I have for that place is "Tools that should have hardened components won't, so choose accordingly". Impact sockets seem to be the exception to this rule, but otherwise it seems to hold true. And I still LOVE the place... |
| Tags |
| harbor freight |
| Thread Tools | |
| Display Modes | |
