Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#3841 |
Alliance Member
Does the coupon code that you have work on the tool cart in a test environment, like say, the website?
__________________
Demon4x4.com |
#3842 |
Senior Member
#3843 |
Senior Member
Just checked the coupon in the latest Hot Rod and it states tool cabinets, not carts. Not sure if they have something in the system that would not allow the coupon if you tried or not.
#3844 | |
Senior Member
Quote:
so far, so good... but I'll withhold judgement until i've recharged them a couple more times. these aren't any cheaper than eneloops at normal prices. but when they are on sale and with the 20% coupon, they can come out to a better deal. |
#3845 |
Senior Member
Slide Hammer and Bearing Puller Set
http://www.harborfreight.com/blind-h...ler-95987.html don't remember if i posted this before. this works great, just used it again yesterday. surprisingly well built. |
#3846 |
Senior Member
McPherson Strut Spring Compressor
http://www.harborfreight.com/macpher...-set-3980.html PASS - Can't beat it for $20 bucks. Changed the rear struts on my wifes jeep this morning and it was a piece of cake using these. 1.5 ton Racing Jack http://www.harborfreight.com/rapid-p...html-7814.html PASS - Got this for Christmas but finally used it for the first time today doing the struts. Worked like a champ. Orange Goop Hand Cleaner http://www.harborfreight.com/16-oz-o...ner-47943.html PASS - Hands were black from grease and are now clean again, lol. It worked well. |
#3847 |
Senior Member
The offset oxygen sensor socket is a major fail. It's junk, the oxygen sensor gets stuck in the socket and it's a pain to remove. I guess it gets wedged, last time I tried to use it I had to use a malot to loosen it off the sensor
#3848 |
Senior Member
they sell several, and some in sets. can you be more specific about which one? like item number?
#3849 |
Senior Member
Yeah, I have the set, and it works great. I've used a 24" breaker bar on the offset. It has a nifty 8pt drive.
__________________
Wanted: Green Snap-on Tools Wanted: Green Stuff |
#3850 |
Senior Member
Once you get the O2 loosened, tighten it again to get the O2 back into the correct location of the hex. Then continue to loosen to remove from exhaust.
__________________
My Garage Refurb Mr. Heater 75k BTU Installation Stacked two 44" HF 13 drawer boxes |
#3851 | |
Senior Member
Quote:
http://www.harborfreight.com/3-8-eig...nch-97177.html |
#3852 |
Senior Member
I tried that but it would tighten the sensor too much before it would reseat. It was more trouble than it was worth
#3853 | |
Senior Member
Quote:
Similar to when taking off a water pump pulley with its 4 bolts... using one wrench against another continually loosening and tightening until they all come free and don't lock onto the wrench. Personally, I prefer the socket style O2 sockets because they seem more rigid. Not sure if HF has those though.
__________________
#3854 | |
Senior Member
Quote:
__________________
Good Garage Journal Sellers I've Bought Tools From: Hiball, Justinmc, Hank McMauser, franksinatra, V70R, latebreak, Lost Road,kc-steve, Rickster |
#3855 |
Senior Member
Those screw style ones were always dangerous. No matter the brand. If I don't have access to a press, I use ratchet straps to compress springs for doing struts, and such. One on each side. Wrapped around a couple times on each end, the hooked to itself. Then you can ratchet it enough to take tension off the bucket/strut.
__________________
#3856 |
Senior Member
The first time I used mine (several years ago) I thought "typical cheap chinese crap." So I decided to grease the threads - it was night & day. Still doesn't feel "robust & trustworthy", but honestly has never given any indication it was being overworked since.
#3857 |
Senior Member
Location: Northern WI in Summer - Southern CA in Winter
They don't call em "suicide sticks' for nuthing...
__________________
Donor Heart Recipient 3.28.10 Beware the lollypop of mediocrity, one lick and you will suck forever... Wanna keep track of all your vehicles maintenance? Click here! Still Seeking Snap-on 12pt standard length combination wrench. Underlined Script Only: *OEX8 1/4 that's OEX8 not OEX80 and underlined script only....... Have MINT later version I could trade plus cash. |
#3858 |
Senior Member
#3859 | |
Senior Member
Quote:
those types aren't called "widow makers" for no reason..
__________________
"Behind every successful man is his woman. Behind the fall of a successful man is usually another woman." |
#3860 |
Senior Member
Felt perfectly safe using them. Now I will say this...the strut springs I worked were pretty short so they really didnt try to bend side to side if you tightened one side down further than the other. I dont know how they would do working on a strut with a taller / narrower spring that would easily bend while compressing it.
| Tags |
| harbor freight |
| Thread Tools | |
| Display Modes | |
