sharkytm
Well, after over 1.5 years of Craigslist searching, 20+ calls to people with compressors for sale, and not a single hit (either too late, or the compressor sucked), I gave up and took the high road: I bought a new Campbell Hausfeld XP5810 compressor from my local Lowes. $599 for this: http://www.chpower.com/webapp/wcs/stores/servlet/chPrd3_10051_10001_110213_-1_10646_10689_
Not too bad, I'd say. Now comes the fun part: Wiring it in. I know the motor draws 22A@240v when it runs. I know I needed a minimum of AWG8 wire and a 40A breaker to handle the load, but I found a 30' piece of NM-6/3 w/ ground in the cull pile, and scored that for $40. I'm going to put in a 60A breaker and wire it with this massive cable. I'm also planning on getting a 250A welder soon, so I'll need the 60A breaker soon enough.
SO. Here comes the question part:
1. There isn't a switch on the compressor. I assume thats because I need to run a separate disconnect switch for it, located at the compressor location. Is this correct, and what switch can I use?
2. Any hints on wiring it up? I haven't looked at the wiring diagram yet, but I imagine its pretty easy. Hot1 and Hot2 to two lugs, neutral to another, ground to the box.
3. Any hints for setting things up that you folks with more experience have found?
