Wildfire
Guys,
Two questions:
Question 1: What size wire to use? Copper or Aluminum?
Installing an "external tap of unlimited length" from a 320amp meter base to the 100amp main disconnect panel in the detached garage other lug will connect to the 200amp panel in the house. Garage is approximately 150' away.
Question 2: What size wire to use? (I'm thinking copper 8/3 with ground)
From the 100amp panel in the garage, we will connect to the barn (approximately 250' away). The barn will be a subpanel and have a 30amp main breaker.
I am concerned about voltage drop over these distances. All will be buried at depth specified by local code and in conduit.
And if you know anyone in or around Abingdon, Virginia qualified to do this, holler back.
Thanks in advance,
Scott
Two questions:
Thanks in advance,
Scott
