Vintage Black and Decker grinder restoration
larryq
Hi everyone,
A couple of months back I purchased an old Black and Decker grinder from a nice couple, whose grandfather used it for some light use, including a little gunsmithing.
Grandpa took care of it, as it had to be at least 50 years old and still worked like a champ, though it needed new paint, as you can see. I also rewired it, put in a new start capacitor, along with new bearings. When it fires up now it spins like a dream.
Inspired and shamed by some of the amazing restorations on here, I thought I should do my part and try a mini resto myself. By no means is this as thorough as the one I've linked to, and the many others we've seen here.
The old paint was removed via electrolysis and I used some leftover single stage urethane silver metallic paint, along with a couple of coats of clear for good measure.
For those noting the wiring in back, I should point out the strain relief is inside the base, not where the wire enters. I still need to put a rubber grommet in there, but the wiring won't yank out if I tug on the cord. Otherwise, still need to attach the gooseneck lamp and eyeshields, but she's pretty well buttoned up now.
This thing is cast iron, top to bottom, and very heavy-- at least 40 lbs.
Some before and afters, hope you enjoy them as much I enjoyed the restoration.
y3mpOQU7XDAOsIH9F_dtq6GBbfVj5XBcwQE8CQ5Oco4v3OBT_1VzFBPzlUWR0uXK9pBHgcoX2i8CdDelSqnW75zNhQj7yC0NFqfQy7F4VW2WCJqbfJX8yTb9QYB0Pr8BsaBRJolLxMX--iXX0vA-wuunMimvNIKRwoJ9IrnhFr1Uow
y3mRNlGsYBUFppCgI0Cg-Yb2YQSrqV8mNTjTEIVdDceOa11yonbY2-d26j_cnMGSM8wfEH-aHLl0dGiKWwEaHeyaSlmvhrWwEGL7WX2N_6HphIi0Y_qSQzJYFvPJLGLJOIJKoisKT3OvzDIas5uhC13MrcBnOVAHH21hrYIcm6v5nk
y3m8VQPqR7LuoiZ33-PxZ_O08i3O6QJrUTl9pC11YOBRzuRTA_1zH8lb--Xg57aUEEvK2vCkgywS9JxcZMNEPAhluiqk8y3veFxjE2EbD8GCAXnLXkQCrWVN2brJEw3kqfyomZeWPaou_yYZ3AVVmy9v5uUUS_sTIMX4omQPN6E07A
y3mvrukGXKB0fWGN9xxLE41krRypfuQIcn6y7M4R_jVS55Tk5YIf86rTDXrEHbcXa43sflY-eJqdHiEX7diiuCN5xW3M-kIegV9J-uy3DZOs7u9Zp4t6Vsf8_rGzFBBhKJpgiGn5XSLUqpdYDBIXjVDGJglTsM91WnDiFr3leoMfws
y3mp176TN31w5WT7YVNPA-MQ_WenWV5fhzVEXhijZHqDqbWYuAsBM-3h1fQFXXg6iPsAa2f-qYOLBjdCNMlUX2a5WHmIIJGMCu_ID8LASnTbwHXphH3AVG_KXRdnaIOg6eyNbxgPCdTCSGP3ANjuWz1MYyDIAPCq2yhbu2DD86Dsew
y3mWWA343pYX9ItsfvTJ3Lr76mR2A3Cfw2pHncAqlfyB8gOoT2ivgDQWXMk5CNhq8EgtrSFkXRnki5bzPf36TLPK5Hc3_9ojZ92xuOSOZcz8T_uZwUCyMY9wBPTP2Wy3RMqm9vCcMeakQ1I1NOZEuFu0WCikyV6U4icJ2Ht83klhfU
y3mMCjJvKiNQ0PiZNWSuu2tW6cedU4r6msFvpylF6ShLkD5pXYUEpgRjtmPGdJa_ut78a2pTrr3qTMNJqLEr_BFoOufMgF-a3jRCb2bk2wxHM2fs8t1eZUlmpfGknjvnxU8bZ-XK68BZ9RsLpV4FnhY6sPBJzk1CfVV_8W1M5aYUWo
y3m-3XgNejUuQsH215fZFu0MsTUUoRj4juao_WAP1TkB2cm3swc1McwJ1QclA-tPw0Q-fFS83pmLKgAj3WRvnAyhRMsrZRmKLRRKfhj3fXdhc0bcJ4RwnLT2K3lSbfCnUhyrOZwu7IfD2EdAdBj-UB3fEGpf1oXxv3h6nDNImYdsmU
y3m1_6115cT1qiNkgvmsLtgkRE1YTjVNvbGwLLbAAbky84_rqCEvTYhRAOmqqEDDTHw_1toUujRon39AuIFZETPZKSzcsP-4UfFZ0L8uKgJysR-loPaV-ISPZ49a2oKz6HL4u9KPX0KJqdKwaIpVvq0WJuzM0Gz5mOCtcx71Vcm0JM
y3mcgbJ4LFlcwVHAYwN8UKkZk33oySuwJWKU16M9TdkLooOigQGTCs1DfXLCIUCmn51jD2pWj3csJWMqhvnz6ODivJH0roNcUOIck8fuZN3DRjFZNiI9ldjLDbypfPmZS7qkTk-Vr70BykDEoOnMDWtT-qAsfw3_S0DzwDJPcgpYws
y3mPpW7B7Kb6-PMttb4PP4vV__U4l-7tvU6b6iqAwQanqVpPp2lYVYTB2HK_rXil2wDDU5gHC3R2HPaAa2os9b5HXIIL81xhq5Tm3f3W1fTaXx20f3pPCDY6_ct-4W-qrA97OARgKxACTDKJ10jSphU8JYZcFUaFhg_BpLF5kMh8kc
y3m--lcHdsPUurpVC_xNjkByF_zQXyPUXeIQvtk3FcA_vcf7NjqpVx-aaDcf3HqXbX_E4py-T0BDo-2xnIfuVudipwIsK_Nwzzm0yFtA0wHC97iA4QNxY2IhGu6UZ_dQlZ4AK1BZON5_5Gjsi1KItZp0V8vlZvf2VtG0b8HXhe-sns
y3mobcPrV5umaaDbxlONpylMWlNMwBq1b5HzkxCW4bkqFLlWcq2ChPSi0_pgwk0TEWrp3aIkqcwtw8ksPgT03BUVuDI8FyfxSPNUdnwxOy42M3fMNBmEU2Mt5WkEY723IoxZIcDAeJdj5ljvtZvD35hfINUYToSCYu57dEJSXkxUnk
y3mtN_PhQXPJBdva421Xggeq1R4I5OHbUXIOEzZpvuZfV9feECKLx5xEI-_YxHxwMaSpk7YQvNwttVWnnYn7v_V7dNAirkizrZsCXFwUrumI3ZorWNiVzOoX3DTXbEGgVprD69lH33BWulrBJscAL9nwIIgLQOHQe5E-TVzly7fTE8
1982fxr
Phoenix
nice. I think i have one of those and if i ever do anything with it the paint will maybe be B & D black/orange.
tarbellb
Oregon
Dayum! Nicely done.
I dont usually like textured paint, but for some reason it really works on this.
(was it the metal surface or textured paint?)
L
larryq
Dayum! Nicely done.
Thanks everyone for the kind words.
The paint is a metallic silver, which can give a bit of textured look, but most of the texturing you see is because of the cast iron surface.
If anyone is looking to repaint a vice or grinder or toolbox, I'd consider going the single stage urethane route-- it's much more scratch resistant than Rustoleum or an oil based paint. (Powdercoating is ideal but I don't have an oven I could use.)
Admittedly, with the paint and activator you're looking at about $50 for your first quart at (for example) Summit Racing, but the activator is used 1:4 with the paint, so you can paint a gallon of paint with a quart of activator. Quarts of single-stage paint at Summit are about $25.
drivesitfar
Larry: you did a nice job. i do like those nice old stout US made grinders. you can also post up pictures on the show your vintage grinders in the vintage tool section if you would like to and when you have time.
