ukiltmybrutha
- Joined
- Apr 23, 2016
- Messages
- 683
Brand new metal garage leaking at garage doors
OLD SUBJECT WAS BRAND NEW METAL GARAGE LEAKING AT BASE RAILS...I AM NOT SURE IT EVER LEAKED AT THE BASE RAILS AT THIS POINT...WAS PROBABLY AN ILLUSION.
I just had a company install a 2 car metal garage on top of a concrete slab that I had poured for that purpose.
I have been lurking for a while and know that this is a cheap setup, but I'd rather have than have not.
I waited for a rainstorm to see if I had any leaks and sure enough there is water intruding at the rear base rails for the entire rear wall of the garage and slightly up the rear sides.
I didn't know what base rails were before having this thing installed and on the contract it said not responsible for leaks around base rails.
I have done some reading and noticed that the slab shouldn't be much bigger than the garage.
Unfortunately the slab is 1 foot longer than the garage in the rear and this is the area where the water is coming from.
It's not like a torrent of puddles or anything, but I don't know how much worse it will be during a heavy rain.
The slab is not perfectly flat and is slightly slanted downwards to the rear so that the water should be flowing away from the garage. (Not intentionally but this should work in my favor).
Maybe some outdoor specific caulk might work or at least help?
What sort of caulk should I buy? I am sure that is not the end all solution, but really want to know what sort of caulk might work best in this application.
Also, would I caulk the inside or the outside. Googling this thing has yielded ambiguous results. Some say inside and others say outside.
Thanks
Thanks
