Wright Tool Versus Snap-On, Combination Wrench Test ( * picture heavy * )
Joe Mamma
I don’t think I ever heard of the Wright Tool company until recently. I read about them on this forum, and I recently bought a lot of Wright Tools (mostly brand new but old stock sockets and ratchets) from a local tool distributor that is going out of business. Not knowing much about Wright, I did some research on the tools and company. There really isn’t very much information out there, but I am starting to be a Wright fan.
As some of you may know, I am a ******** Snap-On guy and I also collect old tools. When I first handled a Wright combination wrench, I knew it was professional quality (good enough to be used by professionals every day, for many years), right up there with Snap-On Mac, Proto, etc.
From this forum, I knew that TR Tool Supply sold Wright tools. I contacted them to find out more about the company and tools. The owner (Richard) was very helpful. He’s a great guy and a great ambassador for Wright tools, and he does sell other companies’ tools.
I couldn’t really understand the WRIGHTGrip design and wanted to do a test. Richard was good enough to donate a combination wrench for me to test. That’s the Wright wrench you see here. The other wrenches are all mine.
My main goal was really to just do a Wright versus Snap-On test. More specifically, I wanted to compare the open end design of a Snap-On wrench (with Flank Drive Plus) to the open end of a Wright wrench (with WRIGHTGrip). I consider the Snap-On to be the gold standard of combination wrenches. One of the ways I was planning to test these two designs was to see where the exact contact points are on a fastener when using each wrench. Here are the results.
Given the very limited amount of information on the internet about Wright, I thought some of you would be interested in this comparison. (I apologize in advance for the poor picture quality!)
I. General Comparison and Description
Here is what’s pictured. They are all 9/16” combination wrenches (an open end and closed/boxed end) with the boxed end being 12 point. From top to bottom:
1. A Blackhawk ratcheting combination wrench, model # BW-3216. Although it’s short, it’s not the “stubby” model. For those who care, this is an older model with a flexible head, that is non-locking and non-reversible (Made in Taiwan).
2. An old Craftsman wrench that I believe is from the mid 1960s. This has the =V= symbol with no model number.
3. An old Easco wrench, model # 63118. I think this is from the 1970s. I think this is a good representation of a common and typical 9/16” combination wrench, even for today. I believe Easco was bought by Danaher, and the Easco brand no longer exists. I also believe that Easco used to make a lot of Craftsman tools.
4. A current production wrench from Wright Tool, model # 1218. This is one of their “Full Polish” and “Long Pattern” wrenches. It has the “WRIGHTGrip” design on the open end, and “Wright Drive” design on the box/closed end.
The WRIGHTGrip design is the teeth/serrations and the subtle curves in the open end. This is supposed to help the wrench grip the fastener and make it less likely to round off. One thing that is not immediately noticeable is that the opposing surfaces of the open ends (the teeth and the curves) are not symmetrical.
The Wright Drive design is on the closed end. It’s how the wrench contacts the fastener away from the corners of the fastener making it less likely to round off of the corners when tightening (or loosening if it’s stuck).
From what I can tell, all of the combination wrenches that Wright currently sells are their “Long Pattern” wrenches.
Also, from looking at their current catalog, I believe Wright makes combination wrenches in “Flat Stem” (chrome plated with satin finish), “Heavy-Duty Flat Stem” (very thick handles), “Black Industrial Finish” (what I think is a black oxide type of finish from the way it sounds), and “Full Polish” (typical smooth mirror polish chrome plating).
5. A current production wrench from Snap-On wrench with “Flank Drive Plus”, model # SOEX18. This is a very popular model, and is pretty much the gold standard among combination wrenches. The “Flank Drive” design is the same concept as the Wright Drive design where the closed end of the wrench makes contact away from the corners of the fastener, making it less likely to round off.
The “Plus” in Flank Drive Plus is the teeth/serrations in the open end. Again, this provides an advantage where the corners of the fastener are less likely to round off.
II. Overall Length
I like long wrenches for most of what I do. I appreciate the extra leverage. Of the 4 wrenches shown, the Snap-On is the longest at about 8 3/4”. The Wright is shorter, but not by much (about 8” overall). The Easco is next at about 7”, The Craftsman about 6 7/8”, and the Blackhawk about 6 1/4”. Again, I think the Easco is the typical wrench that most people would use.
III. Other Dimensions
The Wright wrench definitely feels a little thicker than the Snap-On. Don’t take this the wrong way. The Wright is not thick (in my opinion), just a little meatier. My measurements of the head thickness and handle thickness confirm this. The Wright’s open end head is about 10% thicker, and the Wright’s handle is about 14% thicker. I don’t have a small scale, but the Wright seems a little heavier.
Wright head thickness:
Snap-On head thickness:
Wright handle thickness:
Snap-On handle thickness:
I was careful to measure the handle thickness of each wrench where there is no stamping on either side of the wrench. I think this would give the most accurate measurement. The caliper placement shows approximately where I measured on each wrench.
The extra thickness of the head and handle on the Wright MIGHT give it an advantage in strength. I’m not going to break my wrenches for a test, but I am curious which would fail first.
I’ve heard some people complain that they don’t like how the Snap-On wrenches are thin. They say it hurts their hand when they really crank on it. I’m not one of them, but if you are, the Wright is an excellent alternative.
IV. Closed End
The Wright is on the left, the Snap-On on the right. Both are designed so the wrench doesn’t contact the fastener on the corners. It’s very subtle but it’s a good idea and it works.
There are no issues with either here. The cutouts for the holes are perfectly centered on both wrenches. The holes are chamfered nicely, and there are no sharp edges on the outside. The walls of the closed ends are not too thick, so neither wrench should have much problem getting into tight spaces:
The wall of the Wright is just a tiny bit bigger (about 3%) than the Snap-On. The difference is not noticeable or significant.
Wright:
Snap-On:
V. Open End
I didn’t bother taking close up pictures of the open ends of the first three wrenches (Blackhawk, Craftsman, and Easco). I also didn’t bother taking pictures of fasteners tightened with them. The open ends were all smooth, and the fasteners were what you would expect. The wrench contact points were on the corners of the fastener, and I could see how a lot of force could damage the fastener by rounding the corners off.
Here are the open ends of the Wright (on top) and Snap-On (on bottom). If you look carefully, you can see that the upper and lower surface of the Wright are not symmetrical (not mirror images of each other). The Snap-on surfaces are symmetrical. On the Wright, you can see how the lower surface is more curved that the upper surface. Also, the lower right corner of the Wright is cut in a little further than the upper right corner. The lower right corner actually matches the WRIGHTGrip symbol on the handle of the wrench. (You can see that symbol clearly in the picture above where the Wright handle thickness is measured.):
Here are 2 more pictures of the open ends on top of each other. In both pictures, the Snap-On is on top of the Wright. They are lined up exactly so you can compare how each specific area of the wrench teeth would contact a fastener. Also, as you can see in the picture, the teeth on the Wright are not very deep on the surface shown in the first of the 2 pictures:
Upper surface” of the open ends. To clarify a definition used below, the left part of this surface is the “outer part” (“outer” being relative to the handle of the wrench):
Lower surface” of the open ends. To clarify a definition used below, the right part of this surface is the “inner part” (“inner” being relative to the handle of the wrench):
[contiuned in the next post below]
Joe Mamma
J
Joe Mamma
[this is part 2]
VI. Fastener Contact Points
How I tested this: I used a red magic marker to cover part of the fastener. Then I tightened down on the fastener using the open end of each wrench. I also slid each wrench sideways a little bit to scrape the fastener and make the contact points more clear. You can see the contact points where the metal is shiny. One thing that makes it a little confusing is that I did not completely cover the fastener with the red marker, and it’s hard to see exactly where the corners of the fastener are.
This is the contact point of the outer part of the upper surface of the wrench. The fastener tightened with the Snap-On is on top (Wright on bottom). The Wright wrench contacts the corner of the fastener:
Snap-On:
Wright:
This is the contact point of the inner part of the lower surface . The fastener tightened with the Snap-On is on top (Wright on bottom). It looks like the Snap-On contacts the corner but it doesn’t. The contact point is on the flat of the fastener, but not as far in as the Wright:
Snap-On:
Wright:
One complaint of the Snap-On Flank Drive Plus open end is that it mars up fasteners like chrome plated ones. For this reason, some people like to use traditional smooth face open ends. I was asked which open end is less likely to mar up a fastener. As you can see, they are both different, but it’s hard to say which would be better. If I had to say, I think the Wright would be better for two reasons:
1. Where the “lower surface” contacts the fastener, you can see 2 tooth marks on flat of the fastener tightened by the Wright, versus one tooth mark when using the Snap-On. In theory, with Wright, the same force is spread among 2 teeth instead of one. That’s less force per tooth, so the teeth won’t dig into the fastener as deep when using the Wright.
2. You can see from the picture above that the upper surface of the wrench contacts the fastener on the corner with the Wright, and on the flat with the Snap-On. I think the corner contact point of the Wright would be bad but, that’s where traditional smooth face wrenches contact a fastener, and those designs are considered less marring than the Snap-On (with Flank Drive Plus).
One thing I did not test (due to time and the fact that I ran out of fasteners!) was the fastener contact points when turning the Wright wrench in the other direction. Like I said, the open end surfaces of the Wright wrench are not symmetrical. So I’m not sure what the fastener contacts points would look if I had flipped the wrench over. Specifically, I didn’t test the inner part of the upper contact surface, and the outer part of the lower contact surface. I might test this at a later point.
Thoughts, questions, comments, and criticisms are all welcome.
Joe Mamma
Monte
Germany
what a nice review ! Good pics and explanation too !! thx !
ps: If you should do pics again could you make a pic with the fastener inside the open end so we could see how much play there is ! Thanks ! :thumbup:
ourkid2000
Nova Scotia
Anyone know where I can get a hold of these wrenches in Canada? I'm looking for a set of 1/4" to 7/8", can't seen to find a set though.
Bull
I enjoyed reading this a lot, and appreciate the time you took to do all of this. Very cool. Makes me want to get some Wright tools :drool:
TRTOOLSUPPLY
Bull...if you need a catalog,let me know!
Need a catalog just call Wright Tool at 1-800-321-2902 or PM me.
TRTOOLSUPPLY
Coach...Thanks for the positive testimony.If you ever need anything,please let me know.:thumbup:
TR Tool Supply
jhl1963
Super post! Curious if you have any durability comments after a few
Years of ownership/use? Deciding between snapon and wright now. Thanks!
J
Joe Mamma
No issues with either. But I have to say that I use Snap-On as my "go-to", and I rarely use my Wright. I like the idea of a longer wrench (the Snap-On) for more leverage--maybe I'm getting old!
Joe Mamma
jhl1963
Thanks Joe, makes sense. Appreciate the info
jhl1963
Thanks gb, didn't I just see a wtb snapon wrench ad from you lol
3/4 drive
Carnegie Pa.
Great review you put some time into this, bottom line I got alot of Wright sockets, ext. and ratchets but no wrenches. Snapon again sockets ratchet ext. only a few wrenches most of my wrenches are MAC, Craftsman only because I was able to get great prices on those wrenches years ago. Price is a bigger factor for me now with my affordable health care doubling this year.
Davefr
OR
I'd rate Wright slightly above SO for overall quality. However when price is factored in it's a no brainer in favor of Wright.
The problem is it's really tough to find a supplier for individual Wright tools.
abvw
Toronto, Canada
:dunno:
Looks to me OP was pulling the wrench on the wrong side of the open end. I don't think you're supposed to be pulling against the offset, like how you would pulling an adjustable wrench properly. My FD+ have always made 3 teeth marks on "top" and a wide mark near the edge on the "bottom", and I have never pulled the wrench the other way like how OP did. It's no wonder people spread and break the open ends........
