Built-it-myself tools/machines - show us what you've done
Jim Stabe
San Diego, Ca
I have been hanging around here for a few months now and I really like this place because it is full of tool lovers. I am a fanatic also but I have built many of mine mostly for economic reasons but also because I want features or capabilities I can't find commercially.
So grab the digital camera and show off a little.
jam022316
Indiana
You first :) Just kidding. I don't have anything but love these types of threads. They always give me so many ideas!!!
lametec
I only have pictures of two of my creations handy:
Valve spring compressor:
Sand blasting cabinet:
bimmer1980
York, PA
Here is a tube notcher that my twin brother and I built. It is an abrasive belt notcher that will quickly and easily notch a tube at any angle.
lilredex
Toronto
A sampling of a few simple helpers:
#4 - Extended 9/16" extra deep socket for things like gas tank "J" bolt nuts. 1/2" drive socket, length of 1/2" pipe topped off with a 1/2" coupling nut.
#5 - Puller for those steering box pitman arms. 7/8" threaded rod with a captured nut internally. Big, ugly, crude.............but it works.
#6 - Assortment of thread chasers for cleaning the crud out of threads (like those "J" bolts on gas tanks or your table saw adjustments) These nuts clean the threads rather than climb on top of the junk, as an unaltered nut does.
bimmer1980
York, PA
THe tubing notcher can do different sizes by swapping out the front shaft. We made a couple of different shaft sizes. It is a bit forgiving in that you can grind a couple of different tube diameters with the same shaft--of course, you will have joint that isn't as tight as it could be... but as long as you're not building an aircraft, it will work. it is especially less critical when MIG welding. for thin walled TIG, it is best to have a tighter joint... but it sure beats using a hand grinder or a hole saw!
bimmer1980
York, PA
yeah, we had looked at that style when we were building ours, but given the materials we had on hand, it made sense to build it that way. Also, keep in minde that the mill bit will turn way sloooower.... so the machine would have to be geared way down. Notice the gear box.... it also requires a collet holder--a lot tougher to find or build. It is a nice compact machine, but it probably costs a couple of grand. We built our machine for a couple of hundred buck--that was mainly for the bearings, belts and pulleys. we had nearly everything else on hand....
eborcim
Central, MO
I see another plus, you have a heavy duty sander to remove rough edges on metal :thumbup:
jamesemery728
#6 - Assortment of thread chasers for cleaning the crud out of threads (like those "J" bolts on gas tanks or your table saw adjustments) These nuts clean the threads rather than climb on top of the junk, as an unaltered nut does.[/QUOTE]
The photo kind of tells it all but can you explain how you made these and how they work. Thanks
lilredex
Toronto
The photo kind of tells it all but can you explain how you made these and how they work. Thanks[/QUOTE]
OK, they are simply standard nuts that fit whatever you are working on. Hack saw cuts are made through about 1/3 of the way (that provides an outlet for the crud). Then oil up the stud/bolt and put on that modified nut, with the leading edge having the saw cuts. You could just use a thread chasing die if you have one and it fits, many times there is no room to swing a die. Next time you have a rusty old bolt you do not want twisted off, try it. Good example are the bolts holding up gas tanks, the nuts are cranked way up and leave a bunch of threads open to the elements.
krehmkej
Oregon
Bead breaker for motorcycle tires.
When needed, it just bolts to the top of my welding table.
jamesemery728
Thank you for the explanation. Great idea, using something you already have with a little modification and no $$ spent. I like it.
jam022316
Indiana
Man! Awesome idea's everyone!!! Especially love that sand blasting cabinet. Thanks for giving me more things to add to my ever growning list of things to make/do!!! :)
jkeyser14
(rural) Maryland
Bimmer, modify it to is a mill bit instead of an abrasive like Mittler Bros. machine.
I'm not a fan of those notchers, on thin walled tubing the endmill always bends the tube and doesn't give crisp, tight-fitting cuts. We ran into this problem on .049" wall chromoly and smaller. We wound up making a tool holder for our lathe (similar to a boring bar holder) to hold the tubing at any angle. We put a hole saw in our lathe and power fed the tubes into the hole saw. Perfect cuts every time.
1320stang
Edmond, OK
Yeah, but if you're TIGing something then you have to worry about inclusions in the metal.
Depends on what you're building, that machine is designed around the thought of it being in a chassis shop. Jerry Bickle's shop has many of thos in it, .083" 'moly is the thinnest you can legally run in a drag car for a structural member and the fit is great. You should quantify your statement with what you do, A&P?
lametec
I like the valve spring compressor. Did something similar to get long reach vise grips from the cheap HF ones.
Same cheap grips I used. Bought a two pack and kept one intact. :) The compressor cost about about $15 to make. To buy one would have been at least $50.
J
Jim Stabe
San Diego, Ca
Good one........let's see that O/A cart behind it!
Not the cart you were referring to but here is the one I made. I wanted something that would store in a narrow area so I put the bottles in-line. The front and rear braces swing up and hold the bottles in place with turnbuckles. The rear brace also has the handle for moving the cart around. Quick to change bottles and holds them very securely.
While I was taking the pictures of the bottle cart I ran across this and thought it might be interesting. It is a plate bender I made and it can bend up to 1/4" plate up to 90*. You lock the work down with the 2 bolts on top and then lift like a regular brake. It can bend 3/16" up to about 6" wide and 1/4" up to about 2" wide. You can do 1/4" wider but you have to heat it first. It is very handy for making brackets and the like
[/ATTACH][/ATTACH]
jkeyser14
(rural) Maryland
This is for baja cars I used to build. We used the thin wall tubing in a lot of places to attach components to the chasis. For example, a piece of tubing coming off the cage to mount the steering wheel/shaft to.
Falcon67
Merkel, TX
Mr. Stabe, I think you just solved my Oxy/Actyl tank problem. I haven't bought tanks because of space issues. *ding* why didn't I think of that. ;)
I make small tools as required. Things like spanner wrenches for rear end bearing install, spring compressor for auto trans work, press tools, seal drivers, etc.
J
Jim Stabe
San Diego, Ca
Mr. Stabe, I think you just solved my Oxy/Actyl tank problem. I haven't bought tanks because of space issues. *ding* why didn't I think of that. ;)QUOTE]
The bottle cart I had before was one I made in 1972 when I got my first O/A torch set. It had the bottles side by side and the wheels stuck out beyong that so I really took up a lot of room. It had a chain holding the bottles in place but I could never get it tight enough and they would flop around. It only took 35 years of hating that thing before I finally snapped and made a decent one.
I'll post some pictures of some of my other stuff when I get a little more time. I have an English wheel, helve hammer, power shrinker, ring roller, stand for my 4' finger brake, powered bead roller, belt grinder and a 12' jib crane
Jim
72chevy
/QUOTE]
I'm digg'n this idea too. :)
lilredex
Toronto
While I was taking the pictures of the bottle cart I ran across this and thought it might be interesting. It is a plate bender I made and it can bend up to 1/4" plate up to 90*. You lock the work down with the 2 bolts on top and then lift like a regular brake. It can bend 3/16" up to about 6" wide and 1/4" up to about 2" wide. You can do 1/4" wider but you have to heat it first. It is very handy for making brackets and the like = QUOTE]
Yes, I like that narrow cart and your plate bender. I was looking at these, but yours is better (sturdier, and ready for bigger jobs) Note on the last one where he has an adjustment on the clamping jaw to compensate for various thicknesses.
http://www.millerwelds.com/interests/projects/ideagallery/project/1924165732/
http://www.millerwelds.com/resources/communities/mboard/showthread.php?t=14831
My version of the "narrow isle" O/A set up. but on a smaller scale.
J
Jim Stabe
San Diego, Ca
I like your rack on the side, a version just may appear on mine...
J
Jim Stabe
San Diego, Ca
This is my first tool project ever that I didn't have any cash out of pocket to build - zero! Everything I had left over form something. It is a 1" belt sander that fits on the end of a pool pump motor. The previous owner of my house left the pump behind when he moved out, it was really cruddy and the pumpmade a lot of noise. When you remove the pump there is a nice 4 bolt corcle on the shaft end to bolt to. Once the pump was off the motor ran beautifully so I had a 1 hp 3450 rpm motor. The motor mounts in a piece of 4" channel and I can rotate it around to different angles. I have no idea what I bought the clamps for eons ago but they fit the motor perfectly. I milled 3/8" slots in some 1/2 x 1" for the attachments / adjusters. The frame is 3/4 x 1 1/2" x 1/8" tubing. When I slit the top another piece of the 1/2 x 1" was a perfect fit for the tensioner. The tensioner spring was something in my can of old springs that I finally found a use for - one out of about 60 I have accumulated isn't a bad hit rate. The wheels are old iron casters that I bored and installed oilite bushing stock in and crowned the surface on the lathe. Most of what I use this for is slack belt deburring and tool sharpening. I still need to put a short platen behind the belt for about 4" of the height for those times when I need it.
I just finished a 2" x 72" belt sander that is an absolute beast removing metal so I needed something that I could use for detail work breaking edges and such and this works perfectly for that. I run 60 grit ceramic belts on the beast and 150 - 220 grit AO on the little guy
This is the beast
This is the little one
A_Pmech
IL
Jim,
Great work! I love the simple design of your little one especially. Very clean and purposeful. The tensioner detail is excellent.
J
Jim Stabe
San Diego, Ca
Jim,
Thanks, this was a one day project that I needed to fill a void. I really was amazed how simple the thing ended up because it was a design as you go kind of project. I call the big one the beast should the little one be the beauty?
A_Pmech
IL
Yep! Know about those one-day filler projects. That's well-executed for a one-day project too.
LOL! I dunno... If you do, I wouldn't let them stay in the same room together. You might end up with a third. :lol_hitti
J
Jim Stabe
San Diego, Ca
Maybe I'm crazy for asking but what would a 3rd one do that these wouldn't?
rsanter
visalia ca
the base is made from some 2x2 material I had on hand. the cabinet is made from 16ga material I had on hand that was given to me by a place I used to work.
the sand tank is an old freon tank that I was given and I turned in into a pressure pot tank. when the tank runs out of sand you have to reach in and remove the pipe plug and the sand in the cabinet drains back into the sand tank.
there is enough sand to blas smaller stuff in one shot, bigger items you will have to stop and replenish a couple of times.
the side doors (one on each end) are made from the same 16ga material, the hinges were free (given to me by a friend) and the latches were salvaged off something else and the casters were free (used, given to me by a friend).
the front 'glass' is actually lexan that had a few scratches and was given to me by a place I used to work and there is a piece of the same lexan on the top. on the top is a 4ft shop light like you get at the big box store for $9 that I happened to have sitting around. it is the best lit blast cabinet I have used.
the gloves are replacement blasting gloves like you can get at an industrial supply place and they are held on with hose clamps
there is a port in the back that you hook a shop vac to so you can pull some of the flying dust and stuff out of the cabinet
pressure feed is the way to go, I can blast a distrubutor in about 5 min
I think the cabinet as about 14 or 15 years old now and it has been 'stored' at several friends houses over the years
bob
A_Pmech
IL
Here's my little entry:
It's a steel rule cutting die, made specifically to cut out those little cardboard spacers shown in the photo. It's made from three pieces of scrap aluminum and sharpened .007" feeler gauge stock.
The spacers are used in my wood shaper for adjusting the height of stacked cutters. Why cardboard and not brass? I can make minor adjustments to fine-tune the stacking simply by torquing on the spindle nut. Once torqued, they're remarkably stable.
My favorite source of cardboard is high-quality manilla file folders and .015" card stock. I also make shims from standard printer paper, which is about .003" thick.
J
Jim Stabe
San Diego, Ca
I've thought about making punching dies before but usually just sharpen the edge of a piece of tubing. These are slick! How do you make the circular slit for the .007" feeler gauge stock (and where do you buy feeler gauge stock)? Do you sharpen before or after you insert into the base? Details, details...
Jim
A_Pmech
IL
Jim
Jim,
The die is actually made in four pieces. There's a center circle, an outer ring, a 1/8" 4130 backer that fits inside the cavity in the die body, and the die body. The feeler stock is sharpened and pre-curved before installing into the die body. The die rings are made to provide a snug interference fit to each other and the feeler stock. They must be tapped into place with a wooden stick and a mallet. Standard light press fits apply.
There is a though hole in the back of the die body to permit tapping out the 4130 backer, thus removing the ring, center circle, and feeler stock when the die needs to be sharpened. With practice, you can make many hundreds of pieces with a plastic mallet before the die "folds over" when the feeler stock loses it's edge. Use end grain Maple for best results.
I find leaving about a .02" gap between the ends of each sharpened ring to provide a "hanging chad" helps remove the material from the punch. After punching, simply pull on the little tab to remove your part and the scrap.
The feeler stock I use is .007" thick, available in 25-foot rolls from victornet.com, MSC, etc.
:beer:
J
Jim Stabe
San Diego, Ca
My daughter's wedding was Saturday so I have some time for some pictures now. This is a ring roller that I made to form a gradual curve in some 1" tubing for the rolled edge of the cowl over the dash in my MG project. The stock car had a padded, leather covered piece that I couldn't use because I widened the car. The tube needed to have a smooth curve in two planes and I wasn't having any luck trying to bend it around large round objects.
The first project was the handwheel for the machine and I have since done other handwheels (the English wheel adjuster) for myself and friends. The 12" diameter E-wheel adjuster wheel only runs out 1/16"It does a good job on square tubing and flat steel stock as well. I made the tops of the gate frames with it out of 3/4" square tubing.
W-Cummins
Iowa
How did you turn the nice groves in the dies?
On the rings do you cut the flat part out on the starting end and roll it closed??
BTW the stuff looks great!
William....
