Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Junior Member
I s there anyway to speed up the blower motor for more air flow through my ducs,i was told that you rewire for more speed?thanks for any help,steve
#2 |
Junior Member
Most blower motors I see have a receptacle fitting where a plug is moved to the desired speed. Usually mounted on the motor. Mine came from Grainger and has 5 speeds.
#3 |
Senior Member
#4 |
Senior Member
If it is a belt drive, find a smaller pulley for the motor, and a shorter belt.
#5 |
Senior Member
That should be a larger pulley for the motor and a longer belt
also look to see if the motor pulley is adjustable loosen the set screw and move in and shorten the adjuster bolt on the motor Brad |
#6 | |
Senior Member
Quote:
You can reduce the fan pulley size also. |
| Thread Tools | |
| Display Modes | |
