Montezuma 72" roller cabinet/top chest review
nissan_crawler
Wichita, KS
Here are the part #'s:
Note the bottom one is for a stainless top, mine was switched to mdf, due to removing it anyway to install the top chest.
and the top:
The bottom box is made by Montezuma solely for strictlytoolboxes.com. That's global72 on here, his name is Shannon, great guy to deal with.:thumbup:
The difference is the second drawer on the far left of the cabinet under the locking drawer is a 4" drawer vs. 2 - 2" drawers on the 17 drawer model.
I chose to upgrade to the spring loaded casters, and personally feel it would be stupid not too. Where my old box teetered with 1/4" under the wheels, this sits level. Run over cracks, or the 3/4" lip into my garage is much easier, as the wheels lift up and let you go over it easier, rather than slamming into them.
On to the pictures. I realize this is more than just a review, but...most people will also have to get it put together in a similar fashion, so I'm providing that info, also. Some may not be able to do it all, due to not having the equipment, or will need to borrow it, I figure posting the process will help people plan for the box's arrival and make things easier.:beer:
I drove to Montezuma and picked them up myself. The people there are very nice, and easy to work with.:thumbup:
Here's the boxes back at home:
These are packed VERY well, and VERY tight. To take the box of the top chest, I just cut the straps on it, wrapped a chain around it with a boomer to give it a little tension, and hooked it up to the cherry picker with a chain and lifted it off. You could also tear the box down, I just thought this was quick and easy, with no possibility of damaging the toolbox itself.
Unfortunately...here's where my camera batteries were dying and quit taking pictures without me knowing it...so no shots of removing the top box off the trailer...I'll explain how and why later on in another picture.
I had no way of lifting the shipping box off the roller cabinet, so I just broke it down by hand. I removed the wood strips blocking the wheels, and just pushed it off the pallet onto the trailer. This rolls so easy, it was no problem.
I used a lifting sling and the winch to ease it down the ramps. Two guys would be a bare minimum to get this off a trailer with ramps, IMHO.
Now, onto setting the chest on the cabinet. You'll notice the lifting setup...I tried lifting it with just attaching chains from the eye hooks to the cherry picker and slowly lifted. As I had wondered, it was too much side load and it began to bend the top around the threaded inserts, so I quit. If somebody had something that lifted really high and had 5-6' long chains, this might not be an issue. My cherry picker was about maxed out on height as it was, so I needed to keep things as short as possible.
I think Montezuma needs to warn the owner about this. I didn't get much damage due to expecting it, but there is some minor damage, and the next guy might not expect it. I would think the sheer physics of this would make it nearly impossible to make it so they couldn't bend, but again...there should be a warning stating that in the first place.
So, I made this quick lifting setup. Nothing fancy, just one long 2x4 across the box, and two short 2x4's across the ends. I ran 2 3" screws on each side to keep the short boards from sliding around. These don't take weight the way I did it, so this is more than sufficient.
I ran 4 chains between the lift hooks and the short 2x4's, and then wrapped a chain around each end of the long 2x4 to the cherry picker. Doing it this way makes the long board lift on the short ones, which are attached to the chains, no relying on screws for weight.
I also had to clean up the threads on the lifting eyes with a thread file before installing them. They probably could have gone in anyway, but they had some resistance, the threads weren't perfectly machined.
Long story short, it worked great:
Now, onto bolting the top down. It uses 6 large bolts to hold it onto the bottom box. One in each front corner, two about 6" either way from each back corner. You have to pull the bottom drawers of the chest out, and you will have a much easier time if you find a 6'5" 10 year old to reach the bolts in the back. I didn't, so I managed.
Now, here's the next thing I think Montezuma should address. The bolts are provided without washers, which doesn't grip much of the slot. I personally found this unacceptable, and think 6 washers should be provided also. This isn't a big deal, but still.
As provided:
With washer added, much better:
So, that's all done. The next thing was casters. I didn't even think to mention how I wanted them setup, and do to the garage setup, and project vehicle in it, I could only get the box in the garage with them setup one way. They came with the casters at each end and the fixed ones in the center.
I used the lift strap to pick up one side of the box. It had too much stretch and I couldn't lift the box before maxing out the cherry picker, so as you can see, I attached a chain to the strap and the cherry picker frame and used a boomer to get some slack out of the strap before ever lifting the box:
Here's a shot of the wheels:
All together and back on the ground:
Now, onto the features...
Here's a shot of the stiffeners on the bottom of the roller chest:
Here's the stiffeners on the bottom of the long drawers:
Drawer slides:
Locking mechanism:
Warning stickers if anybody cares:
I took the MDF top for the roller cabinet, used a spade bit to countersink some bolts, and bolted it down to the top box using the lifting eye mounts. Might as well, the edges are beveled, corners are rounded nicely, good coating on it, I couldn't bring myself to throw it out.
Here's the box in it's home, you can see how small it makes the 56" International look. Oh, I got the old chevy emblem mounted on it, too.:thumbup:
Drawer shots, this will show which ones come with dual slides, and which ones can have them added. I believe Shannon said the slides run $36/set. He recommends not adding them unless you have the weight, due to the detents being stiff if you don't have much weight in the drawers. You can also see how the sides and back of the drawer are bent 90*, this really stiffens up the drawer.
Here's the pile of packaging left, along with a couple extra pieces of plywood I threw in:
Here's the two boxes that it replaced:
Both of these boxes were plumb full, plus I put other tools in the Montezuma box that weren't in these. I still have 9 drawers completely empty, and many of the others are only 50% full or so, plenty of room to grow.
All in all, this blows Craftsman/International/Waterloo/C-Pro, HF, etc., out of the water, IMHO. If money wasn't an object, I would immediately replace my C-Pro at work with one of these. A guy at work got an $8,000 Snap-On box, and I can't say I was anymore impressed with that than this. I would love to see the difference between this and the Elite series.
Post up any questions you have, or if you want pictures of anything else. I'm not going to take pictures of the tool layout though, everything is just chucked in right now.
Lookin4'67Galaxieconv
Atlanta, GA
Thanks for the review, Nissan. Very interesting. Again, beautiful box.
Couple questions for you...
How important is it that the top is bolted to the bottom? I don't think it's a bad idea, but there isn't any chance of tipping if you pull out a heavy drawer on the top chest, is there?
And you spoke of damage lifting the top box to set it on the rollaway. What kind of damage was incurred, and do you have pictures of it?
N
nissan_crawler
Wichita, KS
I doubt it's nearly as important to bolt it down as if it was an 18" deep box or such, however, it's provided, so there's no point not doing it. I suppose if one was to pull open quite a few heavy drawers, or move it on a sidehill without locking them, there's a possibility of tipping it. As they say, you can't fix stupid.
While mine isn't heavily loaded yet, I had all the top drawers open, and tried pulling on the top to see how heavy it is. It didn't budge. Under common sense usage, I don't think the bolts would ever be necessary. Better safe than sorry, though.
I don't have pictures of the damage. I put the top on before I thought about it. Basically, it's a nutsert in the top that the lifting eye goes into. Pulling at such an angle on the eyes wrinkled the metal around the nutsert some. As you can tell by how the mdf top sits on it, it isn't much at all. I would say the worst one is maybe 1/16" higher than it was due to it being tilted a bit. Not a big deal at all, but if somebody wasn't expecting and watching for it, it could be much worse. As such, I think it deserves a warning inserted with the package the eyes are in.
N
nissan_crawler
Wichita, KS
about 800 pounds for the bottom, and 500 for the top, I believe. They seemed heavier to me, but I doubt their numbers are wrong.
N
nissan_crawler
Wichita, KS
Just for fun...
That's me and all my 250 lbs of glory standing there. What's that you say? No fair, it's a skinny drawer with dual slides?
Fine, I knew how you picky bastards are. How about the middle of a wide drawer with single slides? :fawk:
Merkava_4
Clovis, CA.
So you're saying Montezuma has threaded inserts on top of the top chest? :headscrat
walrus
Maine
Bolted together how tall is the whole thing? Not sure if you want to share this but how much did you pay for the whole thing?. Looks to be a really nice setup
brian90505
Torrance, CA
Good write-up! Very helpful for big box enthusiasts. Having just relocated my 1023 setup, I am reminded why I kept it all intact and didn't break it all down. But then again, I'm lazy when it comes to stuff like this!
bchee
Texas
This board keeps getting dirtier and dirtier. This pict needs to be in the **** thread! Close up picts of a dude's package??:bounce:
Seriously though, I thought you weighed less than 170...
Any why is your photobucket called chevyman?
N
nissan_crawler
Wichita, KS
Roughly 6', give or take an inch. I can certainly measure it if somebody needs to know for clearance reasons. As for the price, I got a bit of a deal, can't really say.
I got pretty nervous when you stood in that second drawer picture - that's one stout box.
It didn't even flinch.
I haven't weighed less than 170 since junior high school.:spit:
I'm a chevy guy at heart, just hate the new ones.
autoace
Maine,USA
Hi Nissan, great review, I was surprise to see how young you are in the pic. You must have a good head on your shoulders, and have your act together. The way your posts come across, I would have imagined you were an "old dude" like me,lol.
Nice box, love the color, now I have to see if the Cornwell guy will let me stand in a single slide drawer of a Cornwell demo box???????? I am heavier, than most people, bet he will decline. I'll see if I can get my dealer to stand in the toolbox, and see if it holds up, like the box you have.
I am seriously considering a Extreme brand toolbox after your review
Thanks, I still like the old Craftsman pro you have. Enjoy the new box.
:thumbup:
CamarosRus
Renton, WA (Seattle)
Any knowledge, comments or opinions about how this MONTEZUMA 72" compares with the EXTREME 72" Combo ?????
Weight, Drawer Configuration, Price ??????
Thanks,
N
nissan_crawler
Wichita, KS
Hey Nissan, can you take a close up picture of that Chevy emblem you put on the box?
How did you attach it?
Sure, here you go:
As for how I attached it...MERK STOP READING HERE!!
I drilled two 1/8" holes through it and the box and countersunk the emblem, used two stainless countersunk screws and nylocks to hold it on.
Thanks,
Not a clue, sorry. Contact global72 on here, he can tell you. I don't think extreme has a cabinet/chest combo, though.
DaMaN
Rahway, NJ
Nissan, are you looking to sell that what I presume is a Red/Grey drawer C-Man customer cart there? I am interested and curious in seeing more pictures and helping you offset your new purchase :thumbup:
N
nissan_crawler
Wichita, KS
Nope, sorry. I got it for free from somebody at work that retired, so I called him up, and he knows somebody that will come get it. I figured it was the right thing to do, since it was free to me.
My International should be sold to one of two guys at work.
Joelfke
Mt Holly, NJ
If you dont mind me asking....how much did it cost you for that setup....?
i LOVE the blue...AND the chevy emblem...
i work at chevy so I know how you feel
DaMaN
Rahway, NJ
Understandable and really noble of you to do the "right thing".
Can I trouble you to post some pics of it here or in a new thread? I just like the looks of it and would like emulate it in some way, thanks.:beer:
N
nissan_crawler
Wichita, KS
I got a bit of a deal on it. I think they run around $4750, like the others. Contact global72 on here and ask.:thumbup:
Sure, will have to be tomorrow though, no real room to do it in the garage, and not enough light outside.
N
nissan_crawler
Wichita, KS
I was thinkin the same thing.
But nice box nissan, im a snap-on guy all day, but seeing your pics makes me think about my next toolbox upgrade, and possibly exploring other options other then snap-on boxs
Thanks, that's what this was all about.:thumbup:
I made a slight modification:
:spit: She kept doing laps in the drawer, and these things come flying open. Darn near took my head off twice will I was sorting screwdrivers. I figured I better fix it before I have to explain to the ER nurse how my cat gashed my forehead open with a toolbox drawer.:lol_hitti
N
nissan_crawler
Wichita, KS
I spoke with Montezuma and sent them a link to this thread. Vince looked at the few minor issues and simply said "I'm on it".
I have worked with Montezuma enough to know they place a very high value on quality and I am certain will address the couple small issues Nissan brought up right away.
www.strictlytoolboxes.com/montezuma-72-16-tool-cabinet.html
Awesome, thanks Shannon! From talking to him, I didn't figure it would be much of a problem at all. For the rest of you, Vince is a great guy, easy to talk to, and more than happy to explain the product to you.
N
nissan_crawler
Wichita, KS
Another neat little fact for you guys. I checked out of curiosity...where the toolbox sits, it fluctuates being between .1-.2* down front to back with my digital inclinometer. That little bit is enough, that when a drawer is pulled out of the detent, it rolls open on it's own.
Think the slides are smooth:confused::spit:
Wesley B
No where
I'm guessing the drawer liners came with it, maybe? I saw in the show your toolbox thread you have two different styles. Which style came in it if any?
