Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
I mount small fragile ceramic discs - 1/4" diamater by 1/8" thick, in cylindrical molds of 1" diamater, and then fill the molds with epoxy. After it cures, I polish the disc.
Now, are there any tools that can be used to remove the discs from the epoxy mounts? Previously we used cold chisels and cutting tools, but I'm looking for an easier/simpler method. Something like a plug cutter or coring bit that can be used with a hammer instead of a drill. Any ideas are welcome! Thanks in advance!
__________________
ToolGuyd Blog (Tool reviews, deals, new tools) Amazon 50-70%-off Tool Deal-Finder Last edited by Stuey; 10-08-2009 at 10:38 AM. Reason: Added Imgs |
#2 |
Senior Member
Let's see pics of the work proces to get an idea of what you are trying to do.
#3 |
Senior Member
Can you modify the molds so that they have an ejection screw to push the ceramic out?
#4 | ||
Senior Member
Quote:
The sample is mounted in epoxy for polishing, and so it then has to be carefully removed so that the sample can be remounted in the opposite direction so that the bottom can be polished. The sample then has to be removed once more in a manner that does not risk ruining the polish. Quote:
I suppose that as a last resort, I'll just find a coring bit, but I was hoping that it wouldn't come to that.
__________________
ToolGuyd Blog (Tool reviews, deals, new tools) Amazon 50-70%-off Tool Deal-Finder |
#5 |
Senior Member
A gasket punch might do the trick.
#6 |
Senior Member
Same here - I'd look at mounting a length of polished 1/4" stainless rod centered in the mold, spray it with dry lube and set the disc on it, pour the epoxy around it. When curing and disc polishing is completed, hold the mold vertically in hand, disc up. Tap the bottom end of the exposed rod on a solid surface and the disc should be ejected.
#7 | |
Senior Member
I'll take a look into this, thanks!
Quote:
__________________
#8 |
Senior Member
Why is epoxy necessary? Wouldn't another adhesive hold long enough for polishing?
I customarily turn hard tropical hardwood in a lathe, mounted with nothing but heavy double stick tape. I have also glued things together with paper inbetween and then split the paper afterward, but you have to scrape the glue and 1/2 paper back off later and this would risk your polish. Maybe a solvent release glue and paper? best luck yours Scott |
#9 |
Senior Member
Solvent-release temporary adhesive may be an option, but the high chance of residue demands more solvent than I would be comfortable subjecting the sample to.
It must be embedded to help provide for a uniform polish. Polishing a 1" diameter face will provide much more uniformity than polishing a 1/4" diameter face would.
__________________
#10 |
Senior Member
What about a poured-in flexible rubber mold used to remake hard-to-find plastic knobs and hard rubber pieces? You could put the disc in, let the rubber dry, polish and then pop it out.
The ejector described above might be your easiest method with the existing setup. |
#11 | |
Senior Member
Quote:
Plus, if the rubber were soft enough, it could make things much, much worse. For example, I have enough issue with the epoxy trapping polishing compounds. If a softer compound were used, even more cleaning and sonicating would be required. One of the things I plan on trying next is heating the epoxy to see if I could deform it away from my samples.
__________________
#12 |
Senior Member
why not machine a holder out of aluminum or steel that will hold the item to be polished.
then you can remove it with a screw/bolt pushing from the back bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand...... |
#13 | |
Senior Member
Quote:
I'm also having trouble visualizing such a holder. There would still need to be a larger face in contact with the sanding/polishing papers to produce a perfectly planar surface. Whether we continue to polish manually or move to use an automatic polisher, the manner of polishing will be the same - the mounted samples are held against a rotating 8" wheel.
__________________
#14 |
Senior Member
This is still a tough ask.
I have no idea -why- the little ceramic buttons are made or examined at all? What is the real goal here? Also, barely can discern the method of polishing them? Its a guy addressing a spinning disk freehand? So anyway, kind of one detail at a time. It is beginning to sound like a firm urethane or other decent quality polymer cylinder, with a screw pusher to remove the sample from the back, might be good. The seat for the sample to be accurately machined for a very light press fit. No adhesive or residue necessary. Aluminum would work as well but the sample may be too fragile to take even a light pressing. Some press jig pushing straight in and supported might be useful? Any machine lathe could machine a cylinder pocket accurately, quickly, for uniform samples. If the samples themselves are not actually uniform in size, the entire line of planning would require a whole new tack. More background please!! yours Scott |
#15 | |
Senior Member
Quote:
the part will be hald in as a 'press fit' however if you cannot press it in for fear of damage, you could heat the holder so it will expand, and then drop the part in and when the holder cools it will shrink and grab the part for several different sizes you will need several different holders bob
__________________
#16 |
Senior Member
Scott, the samples are very similar to each other in size, but some variation is expected - enough that any machined holder would have to have an adjustment mechanism. Such an adjustment mechanism might not provide as solid a contact as epoxy.
The fragile ceramic buttons are made for the purpose of scientific research. Some of the analysis techniques I wish to use demand as high a polish as possible. Our polishing wheel closely resembles a horizontal disc sander, if that helps. Mounting samples in epoxy for polishing is essentially an accepted practice, even for some companies with very deep pockets. Edit: rsanter, the problem with such a holder is that aluminum and steel are much harder than epoxy, and might even be harder than the samples. This may create unforseen complications during the polishing process. Possible concerns would be sample contamination, sample damage due to metal dust embedded in the paper, or uneven polishing.
__________________
ToolGuyd Blog (Tool reviews, deals, new tools) Amazon 50-70%-off Tool Deal-Finder Last edited by Stuey; 10-08-2009 at 09:21 PM. |
#17 |
Senior Member
OK it actually sounds like epoxy mounting is probably the best, especially as you are used to getting your preferred polish this way.
So............... How about a bandsaw and a cold chisel? Set up a jig that you can saw off the cylinder just below the button, leaving, say 1/8" or less of epoxy below the sample. Then a light tap with a small hammer n chisel should neatly split the now fragile epoxy very easily? yours Scott |
#18 |
Senior Member
Just throwing this out there, I can think of a dozen ways that it might be a dumb idea. Have you thought about designing a fixture that would hold the disk in place with vacuum?
#19 | |
Senior Member
Quote:
I don't think this would be feasible for such small specimens.
__________________
#20 |
Senior Member
We just figured that if a sharp circular chisel existed, it would be easier and quicker.
Sure, hollow punches are available in any size you want and any thickness of punch you need. I don't think you'd like them on an inch thick block of epox, at least at first. They seldom line up just perfect between the punch and hammer for an even blow against a firm surface. I have tried. Hollow punches are generally used for soft materials like leather and gasket stock. If you do this 98 times a day though, practice might get the job done. http://shop.ebay.com/i.html?_nkw=hol...ches&_osacat=0 You might also consider a flypress. A jewelers arbor press with a big toggle on top of a screw in place of the rack and pinion on a standard arbor press. The flypress can deliver more delicate but still very rapid pressure straight down. A hollow punch might be just the thing to use with this. I would still saw off the excess epoxy regardless. yours Scott |
| Thread Tools | |
| Display Modes | |
