Motofixxer
- Joined
- Oct 10, 2009
- Messages
- 695
Motofixxer's new almost dream shop 25x32
It would be a dream shop if it was 4 times larger. But residential zoning has limits without going through all kinds of permits and hoops. I have already had neighbors calling the city to ask why they allowed such a large garage. And complaining to the city about the distance from the lot lines. Ha I gave myself an extra foot from the lines just to make sure. They couldn't say anything at all. It meets all the zoning requirements without problems. So to keep it simple and moderately priced but meet my wants. I have what I have.
After years of dreaming of being able to work on things under a roof rather than in a driveway its finally coming true. No more stretching a tarp over my work area to keep the rain off, or sitting next to a heater to keep warm. No more laying cardboard in the snow and slush to lay on. No more neighbors saying I seen you last night working under a tarp, asking if I got cold out there. No more picking up tools when I have to leave to pick up parts, then pull them back out when I get back. That will all be a distant memory. I'm nearing completion of my 25x32 800 sq ft shop. It has 10' walls and cathedral trusses. Center height of about 13 1\2 ft. Roof is a 5\12 pitch and inside is a 3.5\12. 2 10x8 R11 overhead doors that follow the ceiling and jackshaft opener. I have wiring in place for a lift. As well as 240v table saw outlet. I will also have a motorcycle lift that will double as a height adjustable workbench. 30A circuit for air compressor. And 40a extra box for something higher amperage in the future. I'm also installing a second 20a 120v circuit that will be ready to switch wiring for another future 240v if the need arises. Walls have R13 and ceiling has R38 insulation and headers are also insulated in between. It will be drywalled and painted. I just finished putting down Epoxy-coat in Assembly Blue with Black Charcoal and White flakes, due to the lower temps we are having. I had to do it ahead of schedule before the temps drop too low and possible adhesion problems. I have an air conditioner installed thru the back wall along with plans of a propane powered Modine type shop heater. For lighting I have 6 plain porcelain fixtures with 100w cfl's. I also will have 2 switched outlets in the ceiling which are centered over each main bay that will control task lighting etc. There is also wiring in place for 2 ceiling fans that will run off a dimmer switch. I trenched conduit for the electrical feed and ran regular Service Entrance Cable 2-2-2-4. I have separate conduit running the Coax for tv and Cat6 network cable giving me gigabit network access for internet and access to my server with my 200+ cds on file(and yes they were purchased). I rented a mini excavator and dug and poured 4' frost walls with 1 1\2” foam insulation on the inside of the walls. I contracted the slab due to the manpower and equipment needed. I have had some assistance from my uncle who graciously donated years of knowledge and experience as well as a few days of labor and loaning of equipment etc. I have also had a little bit of help from a couple friends and family. But primarily I have put in all the time and labor of everything. I have a few pics posted but more are available on the link.
http://s955.photobucket.com/albums/ae33/Motofixxer/
