Stop the peak - garage door windows
viper522
SE FL
I have clear glass windows across my garage door which enable a curious peaker to peer in and have a look at my dirty mess. I'm looking for suggestions. I've considered adhesive window film and a light coat of black spray paint. Either would probably do the trick, but are they crude compared to your solutions? fire away...
ghnl
Mebane, NC
The adhesive window film is likely the neatest, easiest and most 'reversable'. I used some for our front door giving it the look of frosted glass.
65BCUDA
Eustis,FL
X-mas window snow/frost out of a spray can?
I don't know about the long term duration, but its a thought.
1320stang
Edmond, OK
During the 70's, we all had windows across the 3rd panel up on our garage doors. Many people solved the peeky problem with curtains.....
rsanter
visalia ca
use red paint to create the look of blood splatter
if anyone asks. just tell them 'its really no big deal, I just found someone lurking around in my garage one night. I took care of it though.'
bob
rsanter
visalia ca
actually, you could swap the pieces out with some frosted ones.
you could take the ones you have and sandblast them
you could put some of the film on them that makes it look like stained glass
you could cover them in shelf paper that matches the color of the doors. you could also paint them the same color as the doors
you could install mirror behind it
clip some images off the web and print them out that make it look like children are peering out of the window
bob
V
viper522
SE FL
Thanks fellas, some really solid ideas. rsanter I don't know where you got the blood and children ideas (note: do not mix the two!) but they're hilarious!
The glass isn't easily removable as each panel is held in by adhesive weather seal strips. I suppose it's designed to be Hurricane-resistant. They are one row from the top but by removing one horizontal bar I would have full access to apply window film (or pictures of very unattractive **********?).
I also want to put a sign on my shed door that reads: "Smile, you're on camera, dummy". But it won't fend off the illiterate. My rifle speaks the universal language!
autoclassicnut
Montana
I had my garage door installer put my windows up to the second from the top spot and if you aren't 7' tall, you can't see in. My wife thought I was being paranoid, but none of her stuff is out there either.
( and it will stay that way, too! )
Motofixxer
How about just simple cheap window blinds. Open when you want light. Closed when your not in there. Custom cut widths for any window...
mrpowderkeg
Bismarck North Dakota
I lightly fogged my windows with bomb can white paint. It lets light in, but you cannot see in.
Oh yea forgot to say be sure to tape off what you don't want painted.... as if I had to tell anyone that. You can clean the glass with a razer blade pretty easy.
Harm
http://www.gilafilms.com/
I used this on three bedroom windows. They're window films but they don't apply with adhesive. You clean the windows and then wet them again with solution and squeegee. Home Depot and Lowes carry them. They have several options to choose from. One is kind of mirror-like and they also have a frosted.
river1
peoria az
i used self adhesive clear shelf paper on my shower window. on glass it applies to a frosted look. it's cheap and reversible. i didn't get windows on my garage door just because i didn't want looky lous knowing when i'm home or what i have in the garage.
later jim
Daniel Dudley
This is a very professional solution. The stuff will last forever if you do it on the inside.
V
viper522
SE FL
Here's the windows so you can 'see' what I'm talking about. It's actually the top panel, and I can still tip-toe to see through them.
I'm liking the gila films stuff. I don't want any dangly bits or fabrics that can catch dust/debris or would otherwise get in the way of hurricane reinforcement bars. Besides the obvious, the other reason I'm going to do this is because the door into the house has clear glass windows as well and so you can see straight through the garage, into the house, and right out the back sliding glass doors. Too much transparency!
rieferman
Collegeville PA (30 min west of Philly)
my neighbor got some custom "fatheads" printed and then just used an exacto blade to trim to fit exactly in each window space.. you can upload a photo to create your own, or do your favorite team etc. (he uploaded pics of his classic cars). They're decals (not stickers) so he can pull them off whenever he wants a change.
V
viper522
SE FL
I found the Gila privacy film at my HD. I think it will do what I need. Thanks for the tips! Will post before/after when I get it on.
Costner
You can also go to a hobby store and get glass etching solution. It goes on as a paste and will etch the window resulting in a frosted glass look. It is obviously not reversible.
A low-budget or temporary option is plain old wax paper taped to the inside of the window. From a few feet away it looks like rice paper or frosted glass. Still allows some light to pass but keeps prying eyes from seeing the contents of the garage.
Cameronl
Connecticut
later jim
I bought "frosted window film" from one of those crappy old-lady catalogs like Lillian Vernon. It was just clear shelf paper. So, yeah, I'm with Jim.
Possum
KS
I would say get a can of the cheap window frost paint. Non permanent. But then again I don't understand posting a picture of the inside of you garage on the internet and then frosting the windows for the neighbors. ;)
Gary S
Bismarck, ND
Curtains can really help the decor. You can select a nice paisley or perhaps stripes in a color that match your shoes. But, there is so much disagreement about whether horizontal stripes or vertical stripes make your door look wider.:)
jonny o
I used shoe polish (dial in paint) for a temporary fix. Working on some solar pop can units for each window cause they are the exact size of a PBR tall-boy!
V
viper522
SE FL
ok the Gila Films mirror privacy film works during the day...
but at night you can still see straight through the house! $30 down the drain. I'm now looking for shelf paper.
NUTTSGT
Northern Central Ohio
I was just posting elsewhere. My garage door (wood door) windows let everybody look inside. I bought some 1/2" foil backed rigid insulation and screwed it to the door (foil out) covering the windows up.
It's also a better R-value than the glass.
river1
peoria az
it's not the neighbors i'm worried about, it's the riff raff that passes thru every neighborhood.
later jim
Brunsi
I ran into the same problem with the window film, I left it on and purchased some black foam board that is used for the back of posters, cut it to the frame size and used heavy duty velcro to attach it. It works great and easily comes off if you want some light in the garage or for cleaning.
usmc_noma
virginia
why not try mirror tint or limo tint? it won't let light in, but it won't let the prying eyes see what's inside either.
Brunsi
I think I purchased the darkest film the home store had available but as soon as I fired up my neon signs and lights at night you could still look into the garage so I just did the poster board thing because I had some around. I left the tint on because it does give the windows a nice blacked out look in the daytime as well. If you could find totally black tint I am sure it would work.
Joe Reed
Cordova TN
As a previous post mentions, you can get window frosting paint in a spray can from places like Hobby Lobby. I used it in a window in my Mom's front door. It worked great and seemed to be permanent - at least until I scraped it off a few years later to replace it with a stained glass panel I made. You can start with a light coat and, if you want it more opaque, just spray additional coats.
ProGun3400
Will County, Illinois
I like this idea. Remove it when you want some light, replace when you close up shop. Or-you could just spraypaint them to match your outside door color?
bd8134
Franklin, MA
I went with the white frosted glass spray paint. It still lets the light in, from the inside it just looks white. From the outside when the lights are on you can see shapes but they are blurred, you cant make out the posts of the lift. Works for me.
Smilodon
Titusville, FL
I can also vouch for the "cling" type vinyl stuff (a couple of brands at Lowes/HD). We had some clear glass "pseudo-transom" windows when I moved in, and the glare was oppressive.
I found some that was "mission" style stained glass and put it on the windows. Looked great and cut the heat down as well as the glare.
61scout80
Crestwood, KY
Used this last winter, and it held up great during the phoenix hot summer with no ac in the garage. I recommend this route.
I tried the spray first, it lasted about 3 phoenix winter months (most peoples summer) before it turned yellow, cracked and needed to be scrapped off. I forget if i used rustoleum or krylon's version of it, but it was a reputable named product. The customer service for the company even told me it would be fine for at least a year, that was not my case.
It was easy to use, went one nice and looked great at first. in my opinion this stuff might be good for glass not exposed to the sun.
