Air Compressor: How important is filter and water separator?
snakyjake
I've used the smaller air compressors, and notice no filter or water separator.
I'm now considering a 60 gallon stationary vertical air compressor for the home garage (ratchets, grinder, metal work, auto work, no painting). Compared to the portables, it doesn't come with much, just an open port for the air.
I'll probably run my tools off a 50 ft hose.
Air Filter
1. There's already an air filter on the intake of the compressor. So why do I need one on the outlet?
2. Are those tiny dust particles that get through the intake filter going to ruin my air tools?
3. How important is an air filter?
Water Separator/Filter
4. How important is a water separator?
5. Is the amount of water coming from the compressor going to ruin my tools?
Tool Lubricator
6. Is an auto lubricator mounted at the tank going to offer much lubrication? Or is it significantly better to have the lubrication closer to the tool?
7. Any advantages of an auto lubricator vs. manual oil drops in the tools?
8. Since I plan on using a metal grinder, will more frequent lubrication from an auto lubricator be better?
9. From the tank through a 50 foot hose, will the auto lubricator create an oil mist that will better lubricate tools?
My goal is to keep this setup extremely simple.
Thanks,
Jake
nissan_crawler
Wichita, KS
Air Filter
Tool Lubricator
Thanks,
Jake
I would run a filter such as the motorguard m-60, and a separator. The filter keeps things from inside the compressor out, also.
I'm against automatic oilers, especially right on the compressor. You've contaminated every air line you own that way. Put a few drops in the tool and go (holding the trigger down lets the oil go right down).
e-tek
Saskatoon, SK
I'm with Nissan on the oiler. If they are your tools and you keep the oil handy, you're likely to use it before each job. Oilers are good for shops where emloyees may or may not use tool oil!
Compressors have intake filters to stop dirt going into the cylinder of the pump. That's totally seperate from the air that develops moisture and rust from the inside of the tank and lines. It's good practice to have a filter/seperator at the end of your metal piping run. As you're gonna use a hose right off the compressor, you'd put the filter right at your compressor. It'll keep the water, etc out of the hose.
Hope that helps!
Red Green
South Central Michigan
I have never had an air filter it hasn't seemed to be an issue but I drain the tank often.
If you are not painting or sand blasting a water separator isn't needed if you drain the tank often.
The main reason for an auto lubricator is because people don't put oil in their tools as E-tek said.
snakyjake
Is there something that can filter, separate, and regulate all in one device?
The Motor Guards look interesting, but confusing: M-300 Ambush, M-60, AF-4510 Particulate Filter, AC-4535 Air Control Unit.
Looking for the most simple/compact setup.
Hiball
Missery
Yes.. Please stay away from automatic oilers... Especially if you run Air/Over hydraulic jacks, It makes a mess of the Air system and requires a full teardown and cleaning. Keep a bottle of your favorite air tool handy and just drop some in when needed.
