IR 2135TiMax vs. CP 7750
BB26
oregon
I am going to be upgrading my 1/2’’ impact from the trusty IR 231C to one of the following guns:
CP 7750: http://www.tooltopia.com/chicago-pneumatic-7750.aspx
IR 2135TiMax: http://www.tooltopia.com/ingersoll-rand-2135timax.aspx
Don’t get me wrong, I love my 231, but it just does not have enough guts for some of the jobs I run across. It will become my back up.
What do you guys think about the above guns? The CP is a little more powerful, but about a pound heavier. This is not too concerning as I do not use my ½’’ impact all that often. I usually use hand tools or my 3/8’’ impact. The main purpose of this gun is to tackle tough jobs. The CP can also be had for about $40 less. I anticipate most members recommending the very popular IR, but for some reason, I am leaning towards the underdog (CP).
Let's hear what you have to say...:beer:
ImportTuner
Sounds like you already made up your mind on what you want .. Both impact guns are excellent .. the IR having slightly more torque and a bit lighter ..
gofastman
Minnesota
I second that. I would go for the IR due to the weight. If, for some reason you can't loosen a fastener with one, I doubt the other will knock it loose anyway.
rjohnson
Marengo, Illinois
I can sell you a new in box 2135Ti (not max, but a great gun) for $225 shipped. Please pm me if interested, it's an extra-I love my everyday one, VERY powerful and light!
gofastman
Minnesota
is their specs stated too high or low?
Far too high, all company exaggerate their outputs, but Aircat's claims are ridiculous, my 1375XL for example, is advertised as having 700 ft lbs of loosening torque. Dont get me wrong its plenty powerful, but I wouuld say at most it has 400-500 foot pounds of absolute-fullbore-short socket-no extension-just oiled-running at 150psi-hammering for 30 seconds loosening torque
longroof63
South Louisiana
http://www.cornwelltools.com/webcat/products.php?product=CAT4135-%252d-Blue-Power-1{47}2%22-Super-Duty-Impact-Wrench
I have been selling these by the boat load. Super strong gun. Not bad weight. And a HELLUVA great price.
Got Blue? :thumbup:
BB26
oregon
Got Blue? :thumbup:
Who makes that gun?
supertooljunkie
Lilburn, GA
I have an IR2135Ti and the only time it would not break a bolt loose, I had to put a 24" breaker with a 4' cheater on it. I broke the bolt.
I don't have any info on the CP, but I have no problem with the IR. Before that I had a Snap on 1/2. It was stolen and I replaced it with the IR and haven't been dissappointed.
Marlin
:spit: I hope not. Anyone knowledgeable on COO for the IR and CP, speak up.
The 2135TiMAX, 2115TiMAX and 2141 are all assembled in Athens, PA with many of the crucial internal and external parts also made in the US.
BB26
oregon
Thanks. :beer:
Does anyone have experience with the CP?
What's the difference between the Ti and TiMAX models?
supertooljunkie
Lilburn, GA
2135Timax 1,100 ft lb. max rev. with 780 ft lbs. working. 500 ft lb. forward.
2135Ti 1,000 ft. lb max rev. with 700 ft lbs. working.
kmorgancraw
The IR is actually more powerful for breaking things loose. I've used both guns back to back on the same job and the IR is more powerful, no doubt.
ukvauxtech
manchester
The ir is the way to go. No question.
I have one and it's excellent but generally i use my snap on 3/8 mg31 very loud but gets out virtually every bolt i put it on.
Just a thought....
Fedwrench
Valley of the sun
Search the archives, you find plenty of threads about the IR 2135TI versus other impacts but, probably not the 7750. I've used the IR 2135 series since it first came out and have never been disappointed. I even bought a MG725 to see if it was better and I sold the MG725. Shop around for the best deal from internet vendors. The CP7750 doesn't have push button direction change. It uses a rotary knob to change direction and regulate power. I only use impacts with simple one hand push style direction changes. CP just released a new gun the 7749 that I saw at SEMA. It still wouldn't make me give up my 2135 series but, it's a good looking impact. Its grip is a little on the narrow side though but, it has push button direction change,and more power than the 7750.
http://www.thetoolwarehouse.net/p-9358-chicago-pneumatic-7749.aspx
BB26
oregon
Thanks, Fed. As always, you are a wealth of knowledge. :beer: I know there have been tons of threads on the IR, but I was hoping to get some info directly comparing it to the CP.
Thanks to everyone for the input. I will probably end up going with the TiMAX. :thumbup:
Fedwrench
Valley of the sun
A further recommendation would be to get the Quiet version. I have both and the TIMAX is pretty loud. It's worth the extra money especially if you work at home and have neighbors.:bounce:
BB26
oregon
I was thinking the same thing. :beer:
peter_x
Hicksville, NY
Neat. As soon as I saw that, I was thinking "that's the only air gun I've seen with a side-to-side direction switch like electric guns". Then it says right in the description that it is the first 1/2" gun to have it (where there other sizes that had it?).
I was thinking of going with the IR (or the Matco rebrand of it to match my 3/8" MT2120) but now I think I will get the CP!
IRMan
Thanks. :beer:
I have repaired a few of those CP 7750's they are a unique impact thats for sure and I cannot say anything really good about them.
I also repair IR and the only differences between the the Ti and Timax is the cylinder has 3 exhaust ports instead of 2 that the older IR composite impacts have like the 2131. And also the housings seem to be either gray or black, I think the newer ones are gray but the replacement housings we use are black?? Doesn't really matter because they are both identical.
I will also share : the Q models "quiet" that they charge like 100$ more for are only silenced by a few pieces of cloth/foam. 1 piece covers the exhaust ports on the cylinder and then the inlet bushing has a plastic piece molded for a piece of foam that is simply held on with scotch tape :/
The suckers are a lot quieter and only loose a couple ft. lbs. of torque.
Since I have no care to comment on the CP7750, the CP734H 1/2" is a good contender to the 2135 but is much smoother with its oiled clutch vs. the IR's twin hammer setup but is much heavier
On the other hand though. we got one of those nitro cats in and it put out more torque than both the IR and CP's I was a little shocked lol. The only problem with the nitro cat is replacement parts.
hope my .02 cents helps someone :)
gofastman
Minnesota
I find that hard to believe, not saying you're a liar though. I have use the nitrocat and the it Ti guns back to back and the ir appears way stronger. Perhaps the nitrocat's pin clutch mechanism delivers more torque, but the higher number of blows per minute with ir's twin hammer setup can bust loose a tighter fastener :confused:
Which model nitrocat btw? what were the testing conditions?
IRMan
Not exactly sure on the model off the top of my head but it had the flame job on the hammer case.
This is how we do torque testing
We have 2 bolt tension testers that measure "bolt tension in pounds"
The smaller tester goes up to 30,000 and the large goes up to 170,000
For 1/2" impacts we use the small tester with a 7/8" bolt head. Since we use the same air regulator for both stands the air is normally set to 120psi ( which has sheared rotors on the 2135 :wtf: . So the testing is done around 100psi 90-120 depending on tool.
The conversion we use are
7/8" - Take guage reading of bolt tension in lbs - 2135 gets around 25-28k
so I take the 25,000 and divide by 105
25,000 / 105 = 238~ft. lbs
on the 3/4" and up we use a 2 3/8" bolt head and divide the results by 60 for foot lbs.
The typical IR 261 gets around 80-90k on our tester
85000/60 = 1,420 ft. lbs
The tools are ran until max torque is achieved.
That nitro cat maxed out our small tester at 30,000 in a hurry!
30,000/105 = 286 ft. lbs.
The IR's are great if well taken care of but I only average 240 ft. lbs with them but thats on our tester, not sure how close to accurate it is but we have them callibrated every year.
EDIT : All torque readings are in fwd only. Do not have a tester to guage reverse torque :(
Marlin
Just a couple of things to maybe help with any confusion. 1) The 2135 series is a reverse biased tool, when you bias a tool you purposely give up some performance in forward in favor of gaining more in reverse where it is most needed, if you're not running in reverse you are not measuring the max torque. 2) Testing should be done on the larger size tension tester, the 2135 can yield the 7/8" test bolt on the Model J skidmore(I assume that is what you are using) 3) Using a conversion factor may not give you accurate results because it assumes a correction factor based on friction in the joint. To really understand the torque achieved you can measure the torque required breakaway the fastener in the tightening direction
IRMan
Correct, we have a model H and J - J being the 7/8" bolt. I'm confused on "To really understand the torque achieved you can measure the torque required breakaway the fastener in the tightening direction"
Are you saying to get a torque wrench to test the torque on the bolt? Please share more! I would really like to get the most accurate results but able to do in a timely manner. I just use the conversions like they tell me to do :)
Marlin
You got it, just use a torque wrench to see how much it takes to move the nut further, but on the larger Skidmore/bolt you need a good size torque wrench. If you're trying to gage performance after a repair and you have a good reference tool then what you are doing is fine. I'm just trying to let you know how the torque ratings are arrived at.
Moose-LandTran
The Brink of Insanity (England)
Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand Ingersoll-Rand
Yes, Ingersoll-Rand. Or go home.
gofastman
Minnesota
