I just bought a new house a couple months ago. I'm finally settled and taking on the job of cleaning and epoxying the floor.
I've done a lot of research and decided to commit the time to get this done. I documented everything I've done so far to help others. Also, I still have a lot of questions, so please read and help out if you can.
Background:
I'm the second owner of the house. The garage floor is 55 years old. The previous owner was pretty handy and did a lot of things in this garage over the years, so there’s a lot of stuff on the floor. Apparently, about the only thing they didn't do was clean it, there’s all kinds of contaminants on it.
The house is in southern cal. so as is typical for the area the workmanship is not that great. The garage floor is no exception. It’s very coarse and porous. Also there’s a lot of tool marks from the trowel or whatever they used to spread the cement. It’s not all nice and smooth like I’m used to seeing. I haven't seen too many people taking on really old floors (maybe there's a reason) so I thought this might be helpful to others with crappy old floors.
The two pictures below are what the floor looked like when I started. There's a lot if **** going on.
- generally very dirty
- nasty dark oil stains
- many, many different kinds of paint droppings all over
- rust spots
- plaster & stucco blotches in many places
- roofing tar (?) along some of the edges
- tile adhesive along 3” edge of right wall from a remodel
- bad crack & hole repair jobs
- large holes
- large pitted areas
- hairline cracks
Cleaning Supplies:
The first I did to clean the floor was to scrape off all the surface contamination I could. There was a lot of plaster chunks, tile adhesive, tar-like stuff, and some other residue from what I found after the fact to be extra material from a previous patching job. I used a large chisel and a pry bar to scrape. It’s all I had and it worked pretty well. I couldn’t get everything but I got a great deal of the stuff. This pic is what some of this stuff looked like:
I got the following cleaning items at Home Depot:
- stiff bristle scrubber
- foam squeegee
- ZEP Driveway, Concrete & Masonry cleaner (3g)
- Behr No.990 Concrete & Masonry Cleaner/Degreaser (2g)
- rubber boots
- tsp
- 5g buckets (3)
- pressure washer 2200psi (rented $130 for two days… I could have bought one for not much more!)
- Surprisingly the hardest thing to find was a large plastic watering jug with a large diffuse spicket, every store I went to had these small metal cans. I found one at a local plant store but had to pay $8!
- The gloves I’ve had for many years. I bought them from marinedepot.com for my reef aquariums but you can probably get similar ones elsewhere.
- I got the respirator at Lowes by the paint isle. It’s the one that comes with the pink/purple filters. It worked great. When I had it on I could not smell any of the cleaner, muriatic acid, ammonia etc… When I would take it off I would just about faint.
I picked up 4g of 30% muriatic acid at a local pool supply store. They do still sell muriatic acid at Home Depot outside in the garden area but it’s only 15% HCL and much more expensive.
Background:
- rust spots
- large holes
- hairline cracks
Cleaning Supplies:
- foam squeegee
- rubber boots
- tsp
- 5g buckets (3)
