Odd Williams 725 open end wrench
Danglerb
SoCal
Picked this out a bundle of old wrenches. Whats odd is that each end has several sizes marked on it, and none seem right to me.
michael murder
That's because the measurement is a different system than the one used now. I got a bunch of wrenches like this from my grandpa. He explained there were several systems this might be one based off the size of the bolt, like the actual threaded part of the bolt. If it reads "3/8", that's how big the shaft of the bolt would be, not the head.
michael murder
http://www.wrenchingnews.com/wrench-logos/logos-page-1.html
At the bottom of the page is a little article on standards of measurements.
"SAE Initials: SAE (used with size in inches of bolt diameter i.e. I/2 SAE)
Society of Automotive Engineers (fine threaded nuts and bolts)
Found on older forged wrenches before the 1929 standard want into effect"
"USS Initials: USS (used with size in inches of bolt diameter i.e. I/2 USS)
United States Standard.
These are the two I most commonly come across and occasionally you see, "OC"
"OC Hex logo and initial C (used with size in inches of bolt diameter i.e. I/2OC)
Hex Cap Screw
Found on older forged wrenches before 1920 standard want into effect"
