Compression - Show Off Your Compressor
Mikeyworks
I love this board...after recently joining I felt it was time for me to contribute.
I recently picked this compressor up and was looking for some others to share their systems with the rest of the board.
Mine is a Kellogg-American, Model 321 TV
2 Cylinders
Bore LP/HP – 3.25 & 1.75
Stroke – 3
HP Range – 1, 1.5 & 2
Speed RPM 1750 Motor – 350/823
PSI – 50 to 200
Normal Free CFM – 3.5/8.8
Most of the information can be found here:
http://www.aircompeq.com/ka.htm
...and I can only assume that I have the higher power unit. :)
I have yet to want for air with it. If I open the main valve, it will blow strong all day long.
I think I will either rebuild or upgrade the pump and motor in the next few years as I would love more power...wouldn't we all? :)
The current plumbing is only temporary until I get the walls done and can run better plumbing. It's only a 1 car garage, but I want a separate unit for oiled air (tools) and one for dry air (blaster/paint).
The best part is it was a hand-me-down and cost me a whopping $0.00!!!!
Mikey
bmwpower
Sorry, but mine isn't worth showing. It's nothing fancy. Nice comp BTW.
astroracer
Mid_Michigan
I bought mine used also...
7.5 hp, 2 stage w/ 80 gal tank.
I just got the pressure switch fixed last weekend so it starts and stops all by itself now.:beer:
I ran the hard lines this spring. it sure is nice not having air hose running all over to trip on.
Mark
justinmc
KCMO
Speedaire unit...
30 gallon
can be wired to run 240/120.
2.0HP
5.7 cfm @ 90psi
4.8cfm @ max (135psi)
875 rpm
It doesn't make huge HP.. but the cfm range is consistant and accurate (if not under rated) since its an industrial type pump. I can run an air ratchet or impact gun on it for quite awhile before the she kicks back on. Then again I use good quality air tools that have low air consumption. Haven't done any painting with it yet... soon enough though.
SteveL
St. Louis, MO
Sorry for the crappy pic! I got the whole set up with the blast cabinet and vacumm for $500 from a freind!!!! 60 gal, 5hp. He said that he paid around $1400 17 years ago for it all new.
bmwpower
Steve, we didn't forget how much you **** for getting an awesome deal like that! Nice, quality setup as well as the others.
G M
Winnipeg
80 Gallon 2 stage in the Attic with a remote air filter mounted outside = very quiet.
LeeBoy
North Central Pennsylvania
Here is my 80 gallon 2 stage that I got a couple months ago. I got this new for $600. A good deal I thought, although not as good as bmwpower's.
bmwpower
You mean SteveL? You don't want my 33 gallon Craftsman.
RAYJAY
UNION DALE PA
Ok here is mine
the old 30 gallon 5hp craftsman
and my christmas present from my wife ( she ordered and had it shipped )
sss5l5 IR 60 gallon 5hp 135lb max 18.1 cfm @90lb 100% duty cycle got the single stage because I really don't do a lot of sand blasting ,most of the tools I have only use 10 cfm at max
Jeff
Jeff
Runum
DFW
Here is mine. I got it in a trade. It says it's 80 gallon. Looks like 3 cyl. Don't know the HP. Moved it once by hand, it's HEAVY.
Randall Edge
Savannah, Ga.
Well, my garage is not quite finished. So I don't have a proper compressor yet. You could call my current compressor 'portable'. I belive it has a 190 h.p. engine. The compressor is 10.3 ci which is sorta small, but pressure switch is set to turn off at about 145 psi and all the fittings and hoses are 1/2" so I get plenty of air too run an impact or air up my 33" tires. Pics are here. http://www.imagestation.com/album/pictures.html?id=2134193148
Mikeyworks
I love the on-board unit!!! It's perfect for a trail rig!
Anyone that does a lot of over the road driving should also have one of those in their car. I keep a 12V 200 psi Black & Decker unit in my car at all times. You never know when you need air!
Mikey
Randall Edge
Savannah, Ga.
That's exactly what it is. It pulls double duty as a work truck and a weekend warrior. I put about 25,000 miles on it every year. I have 4"x4" back bumper plumbed for air that give me about 1.5 gal of storage with an additional 2 gal tank (not currently installed) inside the frame rails. It will fill the bumper from 0psi to 145psi in less than a minute at idle. 1.5 gallons of air doesn't sound like much, but using 1/2" air lines gives it enough Oooomph to break just about any bolt loose with an impact. I can usually break a bolt loose and spin it off with one shot. Sometimes I can even spin off a couple of bolts without waiting for more air. Since it will fill the tank in less than a minute the wait is never long.
Junkman
Northeastern CT
I have a Quincy 5 HP with a twin cylinder, pressure oil feed bearings, and the optional oil filter. Mine is portable in the fact that it has casters mounted under the original shipping skid. My garage is a mess right not, moving stuff from one corner to another trying to make room for all that has to go in there before it snows. I know, I am running out of time. :mad:
ron in sc
Charleston, SC
The specs on mine are as follows:
Saylor-Beall model 75-80 splash lubricated-two stage compressor with electric Baldor motor running at about 1725 rpm, single phase, with a magnetic starter, Asme tank mounted, 5: HP, weight: 612, tank size: 80, pump model: 705, pump rpm: 845, DVLD CFM@175 psi, 17.3
Just finished wiring it to power yesterday complete with service disconnect box with time delayed fuses.
I still need to change air piping to filter to 3/4'. So far I've only got it at 3/4' from the ball valve to the point where it goes into a flexible pipe and then to ceiling.
Morrisman
Angeles City, Philippines
Here's a couple of pictures of part of one of the compressors i work on, but they are not actually in my garage:pimpflash
The're made by a company called Sulzer Burckhardt, put out 1600cfm, at 2000psi, have five seperate compression stages, are watercooled between stages and require an 800hp electric motor to drive them. :bounce:
1320stang
Edmond, OK
Finally, a thread I can post a pic in. I'm still in the process of getting my side of my 2 car garage to the point where I can work.
RayJay, that's the one I was going to get before my wife bought me this one for Christmas.
BTW, that's a hug, not me trying to lift it.
If you ever wondered how to unload one of these beasts without a forklift or any friends....
RAYJAY
UNION DALE PA
nice......ow many hp and what size is that monster...lol
Jeff
1320stang
Edmond, OK
It's a Delta 2 stage 80 gal. 175 psi kicks in at 145 psi, 16.0scfm @ 90 psig. I think it's 5HP with 6.5HP peak. It's the one Sam's carries. I've been drooling over it for about 3 years. It's a single phase 240V 30A. I don't have it bolted down or wired yet. I wasn't quite ready for it yet. I can't decide how I want to plumb it. Been thinking 3/4" K copper for the main line and 1/2" K copper drops. I was thinking about making a bypass and sitting a galvanized tub outside with a coil of 3/4" M in it that I could put water and ice in for media blasting, not sure it's necessary though.
RAYJAY
UNION DALE PA
did a lot of reading and after looking at it all ( even right in the owners manual for IR it states do not use plastic pipe , rubber hose or lead tin solder joints in th compress air system)
read the pdf here and I'm going with black pipe 3/4 mains and 1/2 drops
Jeff
heavychevy454ss
Nice setups guys!!! :thumbup:
I don't understand what problem there would be soldered copper lines. I work for a mojor AC manufacturer & we manufacture thousands of AC units piped with copper line that are tested to over 400PSI. These are directly coupled to compressors (vibration) and start up torque. A properly brazed joint should not fail in 200 psi air service.
:soapbox:
RAYJAY
UNION DALE PA
:soapbox:
when doing ac work do you use tin lead solder or silver solder ?
also 20 ft of black pipe us made is $29.00 the copper is 46
Jeff
Junkman
Northeastern CT
Where do you find US made black iron pipe. All the plumbing supply houses around here only stock the Made in China pipe and fittings. I can't remember when I last saw US pipe available.
toms73novass
grand island, ny
Well here is my Kellog American (an couple year old pic),
It is also a 321, you might notice I still have the original 2hp induction motor on mine, it is HUGE and HEAVY. It is actually pretty cool seeing the sparks when it is running because it uses brushes! I actually had to use my engine hoist to get the motor up there because it was too heavy for me to lift!
Mine put out about 8CFM at 150.
toms73novass
grand island, ny
Mikey,
I noticed that you do not have the check valve on your unit. Where it enters the tank there should be a check valve when the unit is not on a power stroke /pumping so there is no pressure on the pump assembly. You can see mine under my right arm where it enters the tank.
I don't know if will give you any problems with pump life or with the total amount you can get out of the pump.
Just thought that I would mention it.
Tom
toms73novass
grand island, ny
Junkman said:
I did notice that you are storing chlorine next to the motor that produces sparks........ that is not good:shocking:
No chlorine in the buckets, actually my glass bead are in the buckets because they seal well and keep it dry when I am not using it. Thanks for the heads up anyway.
Hawk231
Okeana, OH
Deja vu on unloading the compressor. I ended up taking the belt guard off and slipping a chain through. The engine crane had enough reach to lift the pallet 1/4" off the bed, after I let some air out of the back tires of the truck. We had two 10' 2x4's slipped through the base of the pallet for leverage. My wife drove the truck out from under it while two of us kept the pallet level. I would have gotten pictures but it was 10:30 at night. The compressor is an 80 gallon two stage 5hp Eaton.
I'm working on getting the compressor mounted, wired, and connected to the copper air line this weekend. I'll post a few pics once it's in place.
RAYJAY
UNION DALE PA
home depot has the china made junk around here, my 2 bigger plumbing suppliers have the usa made pipe and fittings
the different is hd is 9.75 for 3/4 black 10 ft the usa stuff is 15.02 for 10 feet
Jeff
Junkman
Northeastern CT
To be honest, I can't tell the difference between made in USA and made in China iron pipe or fittings. I have asked at the plumbing supply house if they have had any comments from the plumbers and they said no one seems to care. I would rather have a USA product, but can't find it anywhere around here. I think that it is sold more on price and the perceived quality is the same. I really wonder if there is actually a quality difference? Only time will tell. If I were burying it in a wall, then I think that I might care more, but for air lines, I don't think it will matter.
RAYJAY
UNION DALE PA
I have had a problem with the home depot fitting leaking on me last couple of times I have used them , I think they just went to a cheaper line than they used to carry
Jeff
Junkman
Northeastern CT
When I put iron pipe together, I use pipe dope and then wrap some cotton thread around the male pipe threads. This makes for a tight fit and stops all leaks. I never use Teflon tape on new pipe threads, since the sharp edges of the pipe thread will just cut the tape to shreds. I have used with good success liquid Teflon pipe sealant. When using the cotton thread, make sure to always wind it on the threads in the direction of the threads, otherwise, the cotton thread will just unravel and jam up. I have tried lots of different pipe dopes in the past, and the one that I like best is the new blue stuff, but I don't remember the name of it. It is for just about all chemicals, oils, and gasses.
ptschram
Churubusco, IN
What is your fear of Chlorine and sparks?
I'd be more worried about the chlorine tearing up everything in the shop, more than being worried about sparks and chlorine.
My compressor is a HD special that was bought after my nearly 20-year-old Craftsman finally bit the dust after 15 years of storage and then daily use.
I'm embarrassed to say that I'm using PVC pipe for the plumbing, but it won't be in the new shop once it gets built.
PT
