Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#2581 | |
Quote:
![]() I have been a long-time GJ member, but as you can see from my post count, I am an (almost) incurable lurker. I was steered here by the Car Craft article and knew after the first few pages I would have to comment. But I wanted to wait till I had read it all. I can only add a big +1 to all the kudos, congrats and "atta-boys" that you have already heard. And a big thanks to the both of you for the time and effort it took to keep coming back and keep this thread going for so long. Good luck with the framing shop, may it cause you to have to pay more income tax! ![]() John |
#2582 | |
Senior Member
Thomas, I posted a thread in Free Parking about your Garage being the third from GJ to make it onto the pages of CarCraft. Of course, being what your resurection of Virgil's shop is, it rightfully garnered 6 FULL pages! I absolutely love what Jeff Smith does with "This Guys Garage" and especially liked the "side bar" he wrote about GJ/your shop in the feature. I'd like to meet him in person one day.
I have to also say I especially enjoyed the several paragraphs devoted to your Dad, his teachings and how much you learned from his perfectionist ways. Between that and the part about finding Virgil's name patch in the grass, I was tearing up enough to blurr the pages. Thanks again for the ride!
__________________
VISIT me at www.E-TekRestorations.com OR, read the blog: www.E-TekRestorations.blogspot.com Quote:
#2583 | |
Junior Member
Quote:
#2584 |
Junior Member
![]() kudos i liked every bit of this tread and..... add Croatia on the list
#2585 |
Senior Member
becarsb - thanks for joining! The world gets smaller as it comes to the center of the universe.
Page 97 state/country list is updated. hey, old salt racer - we're about over our jet-lagging, but the good vibes continue. We'll pick up where we left off sometime in the future - hopefully sooner rather than later. It's going to be 60 degrees here all week. Hopefully winter won't return for one last snow! Chris Last edited by markviii; 03-17-2011 at 09:30 AM. |
#2586 | |
Senior Member
Quote:
![]() Thomas |
#2587 | |
Senior Member
Quote:
)I also note e-tek, you were an extremely early supporter of this thread commenting on here in only the second day I started posting about it back 2009. Thank you for your staying power. Thomas |
#2588 |
Senior Member
mhcomp
Junior Member Join Date: Jul 2008 Location: Grand Junction, CO Allen, I don't know if you're still lurking here, but yesterday was your 75th birthday. Last year we honored you with.... ![]() ...a picture of the more than 250 prune juice jars found on the property. Well for this year you get to see where they were found... ![]() ...in this trailer. Note the brick barbecue and white pine tree to help orient yourself. Many happy prune juice jars to you sir! ![]() Thomas Last edited by BB767; 03-17-2011 at 05:39 PM. |
#2589 |
Senior Member
#2590 |
Senior Member
In the continuing saga of the Walker floor jack...
![]() The jack splits apart left and right around the power cylinder and lifting arm assembly. To help facilitate that... ![]() ...I put the jack body up on blocks just like a car. Next the wheels need to be removed. ![]() The hubcaps on the front wheels will need to be removed first. The caps are a press fit onto the front wheel hubs. Look closely and you'll see two notches on the sides across from each other. This will allow you to place a hook tool into the notches and work the cap off from side to side. These notches will probably be be covered in harden grease and difficult to locate but they are there. Also the caps might be rusted on, so liberal use of penetrating oil ahead of time would be helpful. I was unsure how these were installed when I removed the first one so I worked veerrry slowly, didn't want to break anything. The first one took an hour to remove. Once I saw clearly what I was working with the second one took less than 5 minutes. ![]() The front wheels from the factory had pins holding the hubs on. When removing them lightly tap from both ends of the pins. You'll probably find they move in one direction easier than the other. Note there is a washer between the pin and the wheel hub. ![]() These pins are frequently replaced over the years with cotter keys. ![]() With the pins removed the wheels slide off. If the end of the axle has been mushroomed you might need to file it down before the wheel will slide off. Look inside the hub, they contain needle bearings so when removing them place something under the wheel to catch any that might fall out of the hub. I use paper towels, they're white so anything falling on them is easily seen. ![]() Here's a better view of the wheel hub. It's a good habit to count the needles as they're removed and make note of that number, 20 in this case. Note the wide space between two of the needles at the 9:30 position. The other wheel was just like this one. Intuitively it would appear they are both missing at least one needle so 2 new needles were fabricated for each side. Once the wheel is reassembled I'll know if it needs one or two more. If nothing else the additional needle will serve as a spacer and prevent these from cocking in the hub. While I don't know for a fact it's missing a needle or two, experience tells me they are. ![]() With the needles removed you can see that there is a plain bearing pressed into the wheel hub. It's the slightly raised lip on the inside.(why yes that wheel has been powder coated, I didn't get a picture inside the hub until afterward) ![]() This close up shows inside where the zig-zag ends of the bearing come together. Also you can see at the 9:00 position one of three holes in the plain bearing where grease from the zirk moves through to the needles. Walker went to great effort to provide a well engineered piece of equipment here. Take your time to ensure you don't damage anything by rushing through the disassembly process. Harden grease will masquerade as metal, rust will challenge you, previous damage will sadden your heart, but by prepping ahead of time (days ahead) allowing penetrating oil time to soak parts will greatly aid your efforts. Stay tuned for more exciting action... Thomas Last edited by BB767; 03-18-2011 at 09:07 AM. |
#2591 |
Junior Member
I find myself getting anxious waiting for the next post and I know the guts of it completely. I finally got to read the article in car craft today very good spread Thomas
#2592 |
Senior Member
I'm sorry I forgot to show the final, completed handle sheet metal repairs in case someone was interested. Most of these have been posted but not the final inside pictures. This puts them all together.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() These handles get cracked for two reasons in my opinion. If the attachment screws at the base of the handle are allowed to get loose and from rough, manhandling. A contributing factor is the jacks themselves are quite heavy, mine each weigh approximately 187 lbs (85kg). When you want to move them from place to place it's easy to just grab the handle while you're walking and yank them from a standing start. The handles are about 4' (1.2 m) long and that gives them a fair amount of leverage which aggravates the problem. Click on the link below from biggee's post #2427, and you'll see how those handles were reinforced right where they tend to crack. http://i258.photobucket.com/albums/h...2-16110250.jpg While in a school environment it's not realistic to expect them to receive love and affection but with a just a little care you can greatly minimize the damage. ![]() This is the base of the handle of my original paint jack. It's older than the one I'm restoring and yet there are no cracks on the handle anywhere, testimony to what greater care can do for you over the years. So remember to show your Walker Big Boy, Roll-A-Car jack a little respect please. Saving old equipment, one jack at a time. Thomas |
#2593 | |
Senior Member
Quote:
Patience Don, patience. No fair peaking ahead to the last post to see how it turned out like you can in a book! ![]() I thought Jeff did a nice job on the article too, thanks. Thomas |
#2594 | |
Senior Member
Quote:
but even that's thinning these days. Maybe it's a good thing the passengers can't see me after all. Seriously bestatv, you're the first to bring it up and frankly to mention me in the same breath with Peter Egan is beyond an honor. I'm not fit to empty the shavings from his pencil sharpener! What a talent and one of my favorite writers. I thank you from the bottom of my heart for the thought.Thomas |
#2595 |
Senior Member
It looks like its came out great. Nice work.
__________________
Wayne 69 SS/RS 454 sbc Viper 6 spd Fab 9 4 link G bar w/coilovers. http://www.lateral-g.net/forums/showthread.php4?t=17217 |
#2596 |
Thomas, a question... did you ever remove the data plate from the powder-coated jack? I know you were waiting until you had rivets in hand to do so, and you showed us the donated rivets, and I saw the post about painting it and cleaning off the letters. But it looks like the original rivets. Did I miss a post about removing and reinstalling the plate? Say it ain't so, cauz I stayed up late wayyyyyy too many nights reading this "cover-to-cover", and I don't want to find out I was reading with my eyes closed!
![]() Also, I noticed on the other jack (unrestored), that the data plate states "Factory Rebuilt" So, even though it is older than the one with the handle cracks, it could have had cracks in an original handle that was replaced during the factory rebuild. Not that it matters, just a thought. And I agree,about taking care of those jacks, and it applies to all tools, new or old, "use 'em, but don't abuse 'em". John |
#2597 |
Junior Member
You brought the place back from the dead.
Really great work and very cool. Last edited by libbydog; 03-18-2011 at 02:14 AM. Reason: word |
#2598 |
Junior Member
Thomas something to help you put the wheel-caps back on. If you can freeze the wheel with the bearings in place heat the caps and you can put them on by hand ,then when they reach the same temperature the wheel expands and the cap shrinks and you have a tight hold.I use outboard motor needle-bearing assembly lube to hold the needle's in place.
#2599 |
Junior Member
whoa!
i'm at the end? just stumbled across this thread somewhere this morning, now it is almost 3 in the morning here in the netherlands (that's about 15-20 hours of almost non-stop reading) and my eyes are sore and my head is allmost exploding, what a great job you did on the shop and the tools... just awesome the part about the Y-manifold gave me a lump in my throat... keep up the good work, i'll be following from now on, danny Last edited by PlekVis; 03-18-2011 at 09:03 PM. |
#2600 |
Lou Bingham's gift
I know you all are tool nutz.. Well Lou Bingham sent me a 50 year old tool today It is a Proto tool company DZUS 1/4 turn fastener tool... I know that doesn't sound like much. BUT this tool was give to my Uncle Chuck Chenowth in 1961 when he had his Indy Roadster at Indianapolis motor speedway. Chuck gave it to Lou many years ago & Lou just gave it to me. ![]() On one side it says PROTO PROFESIONAL QUALITY , on the other side is says INDY 500 SAFETY FIRST. THANK YOU LOU Last edited by BigDaddyUSMC; 03-18-2011 at 08:58 PM. |
| Thread Tools | |
| Display Modes | |
