Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#4581 |
Junior Member
. . . certainly easier than oil quenching!
__________________
Wayne Cowie Clock 'em |
#4582 |
Junior Member
fantastic job!
#4583 |
Junior Member
Thomas and Chris, What a fantastic job you have done here. I have lurked here for a long time and you are the reason I have joined. Have read thru the entire thread and all I can say is what a fantastic job you have (three) done. Thanks for the running comentary, look foward to new post all the time.
#4584 | |
Senior Member
Quote:
The saga here continues........ Thomas |
#4585 |
Senior Member
#4586 |
Senior Member
#4587 | |
Senior Member
Quote:
![]() Is there a story that goes with your avatar or is it just a neat picture? Thomas |
#4588 | |
Senior Member
Quote:
"It will be all your fault, and everyone will know it." I hope I haven't put the fix in for Philo now. ![]() Don't say it can't because it can! In aviation no truer words were ever said. Thomas |
#4589 |
Senior Member
Thomas and Chris: Glad to hear all is well in Philo. As you have heard all is not well in Southeastern Illinois in Harrisburg and in Ridgway. Harrisburg lost 6 residents in the tornado that went through these two communities Wednesday am just around 5AM. The Catholic Church in Ridgway is no longer standing after 140+ years. Our FD was toned to assist Ridgway and I've been over there helping, took two vacation days and went to work Friday and then helped that afternoon from 4:30 to about 6:30 and yesterday from 12:00 pm to about 6:30 pm. Attended the prayer service this afternoon at 4 pm in the parish center where the names of the 6 victims of Harrisburg were read aloud and a candle was lit for them. Please keep the families in your prayers, and God bless all of you!
#4590 |
Senior Member
This sycamore thing has legs, that's for sure. I haven't been here for a couple of days and wanted to go back and address the "hardwood issue". Abut posts 4550 or so.
For those that are interested here is a site discussing it. http://science.howstuffworks.com/env...uestion598.htm As Thomas has commented on, hardwood does not refer to the "toughness" of the wood but something about the growth physiology. I have encountered walnut that carved like butter and walnut that required a BFH to get the chisel into it. Mahogany is liked because of the ease with which it carves. Pine is liked by chainsaw carvers. Sycamore is a relatively soft hardwood. Easy to cut, pane and sand. I've run into pine and fir that is harder to work than some sycamore. I think Thomas' tables are just beautiful. I only offer this as an alternative that I do, in the finish department for others that read this. On work tables, I like to not put a surface finish on for the reason others inquired about. It chips, scratches and gouges. Instead I like an oil (linseed, beeswax, Danish oil; although some will build up a surface finish over time) finish that I can scrape/sand and re-coat. Let the character show. Dave.
__________________
What do the CIA, FBI, NSA, Pentagon, White House, Microsoft, Apple, VA, ATT, Chase, Bank of America, Target,Walmart, Sony Play Station, the Justice Department and I have in common? We've all been hacked. Mostly by 16 year olds or the Chinese. |
#4591 |
Senior Member
From howstuffworks.com:
The distinction between hardwood and softwood actually has to do with plant reproduction. All trees reproduce by producing seeds, but the seed structure varies. Hardwood trees are angiosperms, plants that produce seeds with some sort of covering. This might be a fruit, such as an apple, or a hard shell, such as an acorn. Softwoods, on the other hand, are gymnosperms. These plants let seeds fall to the ground as is, with no covering. Pine trees, which grow seeds in hard cones, fall into this category. In conifers like pines, these seeds are released into the wind once they mature. This spreads the plant's seed over a wider area. For the most part, angiosperm trees lose their leaves during cold weather while gymnosperm trees keep their leaves all year round. So, it's also accurate to say evergreens are softwoods and deciduous trees are hardwoods. The hardwood/softwood terminology does make some sense. Evergreens do tend to be less dense than deciduous trees, and therefore easier to cut, while most hardwoods tend to be more dense, and therefore sturdier. But, as the classification of balsa wood demonstrates, there is no minimum weight requirement to become a hardwood. --- In framing pictures, it helps to know the type of wood used for the moulding when using v-nails. Chris |
#4592 | |
Senior Member
Quote:
__________________
Joe Jack of all Trades , Master of None.... "Task Master of Thomas' Tool Shed"! |
#4593 | |
Senior Member
Quote:
Thomas |
#4594 | |
Senior Member
[QUOTE=type47fan;2117459]
Quote:
![]() The owner knew I did some furniture work so he contacted me after it had been hit by lighting and was hoping I'd turn the tree into lumber rather than have it sawn up for firewood. He gave it to me in exchange for removing and cleaning all the debris up. Notice how straight the trunk is. That first main branch was over 12' above the ground. The trunk diameter exceeded as I recall 38" and it didn't really taper until after the first main branch.. The main trunk up to the the first main branch contained a massive amount of beautiful, straight, knot free Walnut. ![]() Beyond the first main branch the trunk continued straight with very few branches for another 18'. Many times the most usable yield comes only from the main trunk below the first main branch. But since the trunk continued knot free, and so straight well above that I got several logs out of the secondary trunk. You can see the bark on the bottom center of the trunk here is split and missing. That's where the lighting exited the tree after striking it. About 1/4 of the tree leafed out after the strike the next year and I cut it the following spring so no decay what so ever had set in. All the wood in the tree was useable. Tree sap is found in the sapwood, the outer most portion of the trunk, just under the bark. Sap consists primarily of water, along with hormones, minerals, and nutrients and can conduct electricity from say, a lighting strike. This electrical charge heats up and literally boils the sap causing it's rapid expansion and the bark to explode off the trunk. The damage it caused to the heartwood on this tree was very localized and didn't result in much if any lose of the the heartwood. ![]() So there I am in silhouette slowing taking it apart some 20+' feet in the air. I can't remember if Chris took these or a buddy who was helping me. ![]() All the leaves are off and you can see I'm bundled up, the back of the pictures says it was early spring 1982. I wanted to harvest it before the outside air temperature warmed up to minimize splitting and checking. ![]() I didn't want to waste anything so I made sure the trunk wasn't damaged while the upper limbs were removed. It took all day to cut down and another day to clean up all the smaller limbs and work site. Then to load those massive logs I borrowed a trailer that would tilt and was low to the ground. It's the kind of trailer that you can lock the wheels and slide the trailer floor so that one end is on the ground. I don't know the name of those types of trailers but farmers used them to haul combine heads. Then I wrapped a chain around the end of the log and using a come-along wenched it by hand onto the trailer. I didn't have access to any power equipment back then. I was on a pretty strict budget. I don't know how much weight was on the trailer but I had to make 4 trips to the saw mill with just this one tree to spread the weight around. The saw mill I used was an old, one man operation. I've got some pictures of it being sawn up. The old fellow at the mill was pretty impressed with what I brought him. ![]() ![]() These are some of the boards and slab that came from that tree. Some of the most attractive Walnut colored wood I've got. Thomas Last edited by BB767; 03-06-2012 at 12:42 AM. |
#4595 |
Junior Member
(Is there a story that goes with your avatar or is it just a neat picture?)
That Thomas is the results of a 10/32 set screw going thru the blower and hanging an intake open. Norwalk 07 IHRA. Could see the thread mark on the rotors from the blower where it went thru it. The screw came out of the blower drive support (its a PSI set back blower). Switched blowers, put in new burst panels in the manifold and ran next Q session, no major damage. I have worked on Alcohol and Nitro Funny cars for 16 years. We finished in the top 10 (national) running NHRA Top Alcohol Funny Car in 04 with Paul Lee driving. Lot of good memories from RT66 Raceway. By the way I love the Impala's ! Last edited by Bumpy55; 03-06-2012 at 12:51 AM. |
#4596 |
Junior Member
Thomas,
Thanks for posting pictures of the "Harvest of the Walnut Tree". It's amazing that you were able, with limited equipment and help, to bring that tree down in 2 days, minimizing damage to the tree (and yourself) and haul it off to be processed. Your planning and execution some 30 years ago produced a valuable and meaningful stock of raw material for your future spectacular woodworking projects. For me, the impact of seeing a picture of you in the top of the tree followed by a shot of the milled lumber resting properly in the racks is tremendous. It is consistent with the nature of your documentary, showing the before and after conditions. What a journey! Thanks, again, for sharing it with us.
__________________
Wayne Cowie Clock 'em Last edited by type47fan; 03-06-2012 at 02:21 PM. |
#4597 |
Senior Member
I did not take the picture of Tom up the tree. He knows I'll tell him "no!" about doing those dangerous things. Thus, I also wasn't around for the digging out of the Rotary lift or the clean-up of the out-buildings on the property. I do better at nursing after the fact - and, believe me, there have been plenty of times! He just goes all-out, no matter what, even if he has to do it himself..
Chris |
#4598 |
Senior Member
MArkviii....do you own a Markviii? I own 2.
#4599 |
Senior Member
Yes, I do (early 1993 model)! You've got a lot of catching up to do if you don't remember post #392 (pg. 20) from over 2 years ago! What year are your MarkVIIIs and do you show them? Do you belong to LCOC? We'll be in Chattanooga, TN, for the Eastern National LCOC show in May. I'm after my 2nd Emeritus the second time around to another crystal bowl (not that I'm in it for the awards, but it helps me keep the car maintained). Time to start prepping it soon.
Welcome to our thread. Chris |
#4600 |
Senior Member
My wife and I have 2 98's. Owned mine for 6 years and now retired to summer only. Her's for 12. Both are slightly modified. My main Lincoln site/club is Lincolns of Distinction (LOD) at www.mark8.org. Checkout if you never heard of it. I also frequent cadillacs vs lincolns. That is one nice looking mark 8 in post 392. I added LCOC to my sites to frequent.
This garage build is awesome! Too bad I do not come down to the champaign area anymore. Used to have some family in Urbanna. |
| Thread Tools | |
| Display Modes | |
