Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Looks like got vent heater thru the roof. Under 4' from over hang , even with over hang being 5''. Really hate go thru the roof.
#2 |
Senior Member
If I understand your question correctly, you could go thru the exterior wall, 90 degree elbow up, and extend up above the roof. If your overhang is only 5", that should be easy to do, providing that you observe the venting requirements of your application (too many elbows or long flue runs prevent a proper draft).
However, the appearance of such an arrangement might convince you that straight up thru the roof is the shortest, least expensive and best looking choice. If properly installed and flashed, there should be no concerns about a roof penetration becoming a problem down the road. As always, offered only as opinion |
#3 |
Senior Member
check with your building department, you may just need to extend it past the 5 inches, IOW a 12 inch pipe sticking out of the wall
#4 |
Junior Member
go thru the roof...the thru the wall deal willl look like ass
#5 |
MY boiler vent goes through the back wall of the garage and I have been thinking of putting it up in the roof. The big thing for me is the master bedroom is on the back of the house right where the vent is so I hear it all night when the boiler is running (power vent unit)
#6 |
Senior Member
#7 |
Senior Member
IOW = in other words
#8 |
Senior Member
Roof installations are not hard at all. Cut hole, nail/gloo flashing to roof, insert vent, silicone the drip edge, put the cap on, done.
#9 |
Senior Member
I go along with the others, go through the roof, it is really easy and as said, when flashed and sealed properly there will no leaks. I've not had any issues with mine and I really didn't want to cut a hole through my wall.
#10 |
Senior Member
x2. It will look so crappy going out the wall it isn't even funny. It will take a cute little place and make it look like $hit.
#11 |
Uh... ok....
#12 |
Senior Member
Hehe, my post was for the OP. You, as a thread hijacker, are collateral damage.
#13 | |
Senior Member
Quote:
This is what I did. I have little experience with plumbing when I put in a tankless water heater. I later found out I didn't plumb to code (1/2" gas line is what I did, didn't use correct flashing either, but plumber said it was "good enough" and that he didn't think code was really necessary there -- who knows?), but everything seemed to work fine. |
#14 |
Im going thru the roof. From what I was told fom heating / air guy they just put hole thru we ever convinient to them, only thing to avoid is comming out next to something. [such as corner]. Said power vent blows away from building.
#15 |
Senior Member
I think some could one proof reader once!
#16 |
I missed point of what your saying .
| Thread Tools | |
| Display Modes | |
