Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
The instructions state:
The vent must extend at least 3' (1m) above the highest point where it passes through a roof of a building and at least 2’ (0.6m) higher than any part of a building within a horizontal distance of 10' (3.05m) unless otherwise specified by the (American) National Fuel Gas Code, ANSI Z223.1 or (Canada) CAN/CGA-B149 Installation Code The way I read this is that the vent tube must stick out of my roof by a minimum of 36". If this is true, why do you only need to have a horizontally vented unit protrude 12" from the side wall? It seems like the would be the same. I do not like the idea of a 36" tube sticking out of the top of my garage because the garage attached to the front of my house either vent would be very obvious from the street. Any way around this? |
#2 |
Not really. I had the same problem. The best thing I could do is vent it out the side of my garage which I can see from the street. I could go through the top, but I can see that pretty obviously from the backyard which I didnt really want either.
#3 |
Senior Member
IMO... the BBQ grille paint did wonders for making mine blend in better. Not sure how it will hold up long term on the galv. But heck, redoing it every couple years if even necessary is better than looking at a big ugly wart....
__________________
My Truck Shop Build thread... http://www.garagejournal.com/forum/s...ead.php?t=9671 |
#4 |
Senior Member
Google the installation manual for the hot dawg 45,000 it has different spec's.I have a 4/12 roof and the nearest taller roof is 14' away and the peak is 12' away I installed mine with a 2' height and it works fine.If I ever go to sell it and an inspector say's something about it I can just remove the cap and put another section of pipe in.The height is mainly for snowfall but I live in south jersey and we don't get to many big storms.I do remember about fifteen yrs. ago we got a bad storm and a retirment development they had built had real short vents that got covered over the fire dept. had to come out and clear all the vents.
#5 |
Senior Member
Enerco manufactures Heat Star which is the same thing as Mr. Heater. Contact their technical service department at 800.251.0001 and they'll be able to help.
http://www.heatstarbyenerco.com/prod...atid=74&id=374
__________________
Roark Industrial Solutions now powered by SEK Solutions www.RoarkIndustrialSolutions.com www.SEKSolutions.com jroark@seksolutions.com or (804)684-8655 Garages, Private Hangars, Wine Cellars, Work Shops & Home Offices – what space do you want to improve? |
#6 |
Senior Member
Helpful tips guys. Whatever I decide to go with, I will definitely be doing the BBQ paint, as that seemed to make a huge difference in that pic above.
| Thread Tools | |
| Display Modes | |
