66tang
LIVELY
Illinois
A PROJECT I FOUND LAST WEEK-been sitting 25 years in the garage:drool:
137,000 miles--2 owners:bounce:
with a title:beer:
moose knuckle
Have complete interior, drivetrain? I'm doing a 65 coupe, and like seeing other mustangs saved after sitting left for dead. Mine sat in a garden for 10 yrs, stiped.... LOTS of rust, most of which is finally replaced. Whats your plans for the car?
L
LIVELY
Illinois
6 cylinder--3 speed standard[spark plugs sitting on the fenderwell]rear frame rails at the hangers ate up--rest of car pretty solid
all the seats were good but all carpet had been removed
not sure if i will redoe the car or market it:headscrat
gonna put tires on it[the old tires are very flat on the bottoms:shocking:] and scrub it down then decide:thumbup:
msmith
Do a thorough rust assessment before you start to spend too much time and money. Cowl, sills, floor, trunk floor are all typical problem areas on a 66, especially one that has been left to rust outside.
z28snksknr
Turnersville, NJ
That looks like my truck's sister - 4 shades of rust and 4 mismatched, flat tires.
Good luck with it - got your hands full there.
tdkkart
Eastern Iowa
Put it on Ebay with a starting bid of about $6500 if it has an interior in it.
If the interior is out and you can see the ground throughthe windows start it at $4500.
That's what 67-68 Cougars were listed at the other night when I was looking. I had a '68 XR7 when I was in HS, wouldn't mind having another, but I'd rather not build one from scratch.
reinhardt
i hate that about a flat tire.... it always seems the flat spot is on the bottom... if u could only get moving fast enough to get the flat spot to roll up to the top of the tire, you would be ok.
L
LIVELY
Illinois
yeah--i cut 2 tires in half and glued the good halves together with Gorrila glue---it holds air alot better now:beer::beer:
this is my 27'th MUSTANG since i was 15 years old[all 65-66]--i am alot older now:shocking::shocking:
also the car was sitting inside a garage not outside:thumbup::thumbup:
rsanter
visalia ca
wow, 27 mustangs
sounds like you are trying to compete with me
the one in my garage currently is number 82 for me
bob
rsanter
visalia ca
thats y i went w/ a camaro. i'm only on number 4.:bounce:
only 4 huh?
I guess you could only find 4 that were decent enough to buy?
currently I have 4 convertables. 2 in show shape and 2 projects
1 coupe that is becoming my hotrod/racecar
the nost I have owned at once was about 20 of them
bob
