My DIY press brake
Joe From NY
NY
Here is my cheap solution for my need to find a way to bend some ¼” aluminum diamond plate for some brackets I needed to make. I made it after seeing some examples of DIY press brakes online. The die I made from an old piece of ½” thick railroad scrap I found at the local Rail Road crossing.
The 3/16” x 1 ½” and 3/16” x 2” angle iron and ¾” round bar I had left over from other projects. The ¼” steel base plate I cut from the edge of a larger piece I was using as a welding table top. The round pipe was scrap left over after relocating some steam radiators in my house.
I cut the railroad scrap down to about 12" x 2½” with a cheapo 4 ½” Harbor Freight/Northern grinder with a good quality cut-off disk. I started out by using my plasma cutter on it, but found that the low-tech method of using the grinder and cut-off wheel worked better, leaving a beautiful clean edge.
I then used the plasma at an angle to get a rough point along the edge, and then finish ground the point with another cheapo grinder with a grinding wheel. (They are so cheap, I keep four, each with different disks and brushes on them for different needs. It is easier than swapping the disks.)
I cut two pieces of the 1 ½” angle iron to the same length, and welded them, butted up against each other to form a c-channel, almost to the edge of my ¼” steel plate. Then I cut the ¾” bar to two pieces of the same length. These got welded into the angle iron to act as structural support to go underneath the bottom die.
Then I cut and welded a piece of 2” angle iron to be the cradle of the brake.
After aligning the top die to the bottom of the angle iron forming the base, I cut two pieces of the pipe and welded one to each side of the die.
Then I cut some more ¾” rod for the pipe on each side of the die to ride on, and welded them in place on the ¼” base. I used a cheap grinder attachment from Northern that turns it into a mini chop saw.
The top gets slid onto the posts, and that’s it. I welded it along the edge of a larger piece of 1/4" plate i am using for my welding table, and just cut the edge of the plate off the table when I was done. (The table fits better in my garage now). I will add suitable springs under the pipe on each side when I can scrounge some up somewhere. In the mean time, it works for me. It bends 3/8” flat stock like butter
Amitygravel
Claremont Illinois
Slick as hell. Did you end up trying to heat treat the edge? Its plenty thick may not be needed. Like the idea of multiple grinders set up with different wheels. Nicely done.
rasit
SE Pennsylvania
Admit it.... you were havin a blast building that weren't you? That thing looks like it could stand up to a 100 ton press. I always go for function over fashion too....... :thumbup:
J
Joe From NY
NY
Yeah man, i would have built it even if i didn't have a use for it now. I saw something like it online, and there is a guy selling all the steel to make one for $150! and you still have to weld it together. I figured i could make a quick and dirty one similar to them for a lot less.
Now i am looking around my house to see what needs bending...:bounce:
J
Joe From NY
NY
That Northern Tool brand one i use is a torque monster. And those cheapo Harbor Freight ones at less than $20 each are great also. It is not worth the hassle to keep changing and swapping disks, just get one grinder for each use and a multi-tap plastic outlet plug for the end of your extension cord. Use three different disks without walking away from the welding table.
T1320T
Indiana
Nice setup without much fab time. Looks like I just found my next project. Someone ^ asked about heat treating the working edge, does anyone have any insight on doing that?
J
Joe From NY
NY
Well it did what i wanted it to do. I bent up some aluminum diamond plate that i need to use where it will be exposed to salt water air. Now i am going around the garage looking for **** that needs bending... :D
[/QUOTE]
juiced10
Parish,NY
I made the same basic setup for my press.The only difference is I welded a piece of pipe on top of the die so the rod on the press could fit in it.That way it couldn't kick out if you weren't perfectly lined up.Also I put a set screw on the piece of pipe so the die came up with the press.
J
Joe From NY
NY
Great idea, that will be my next rainy day project.
thanks
