Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#21 |
Junior Member
DWG: I trust you when you say what the motor specs are (amps 16.6) which you believe to be start up amperage. That just makes me rethink my plans. You are right, I don't plan on moving forever!! (Have a reverse mortgage and it's the best thing since sliced bread!). Can't wait for the addition either. I'm hoping within the next two weeks to be able to insulate and wire and install the compressor. I guess what I'm thinking is that when and if it ever comes to inspection of this place (either upon my death or the county electrical inspector wants to have his say in the remodel) if I put a 30 AMP breaker on a #12 wire (two conductor or three) he won't pass that configuration. So I have to decide if I want to use #12 wire (3 conductor for a two pole breaker) or #10 wire with a 30 amp breaker (2 conductor) in order to pass inspection and more importantly not trip the breaker at any point while using the compressor. Most pertinent, I believe, the the specs on the motor. Given what you've told me, I have to believe that #12 would be most adequate and can save myself some money by purchasing the 20 amp breaker with #12 wire. The run won't be long (under 8 feet) so, again, a non issue with any voltage drop. Glad you sent the photo of the motor cooling. I will be certain to check out that situation after my installation.
#22 |
Senior Member
Yes, whatever breaker is installed, the wiring upstream must be capable of more current. My AWG12 wire is just for the cord from the compressor the outlet, since I know that's sufficient for the compressor.
#23 |
Junior Member
How did you make the decision to choose this compressor? Is this the one you got: http://www.ingersollrandproducts.com...px-am_en-12885
#24 |
Junior Member
Specs along with price and FREE SHIPPING (Northern Tool) convinced me.
#25 | |
Senior Member
Quote:
#26 |
Senior Member
| Tags |
| compressor, drain, filter, platform, ss3l3 |
| Thread Tools | |
| Display Modes | |
