Pics: before, during, & after. Shows how Vinegar & Salt works.
All
Here are some pics of the results of vinegar and salt derusting. Before and after comparison at the end of this post.
No boring videos waiting for water to boil or watching grass grow... just a few pics of pauses along the way to see interesting turning points in the process.
View media item 31018
View media item 31019
View media item 31020
View media item 31021
View media item 31022
View media item 31023
View media item 31024
View media item 31025
View media item 31026
View media item 31027
View media item 31028
View media item 31029
View media item 31030
Just to remind you what the before was like, without you having to scroll back up...
View media item 31031
View media item 31032
View media item 31033
View media item 31034
I've tried Evaporust. Heck, I've put my money where my mouth is and bought 6 gallons of it. It doesn't work like vinegar & salt does.
And the cost? Vinegar $2.00 + salt $1.00 = $3.00 a gallon. Compared with $30.00 a gallon for EvapoRust at Harbor Frieght. Or on Sale? Vinegar $1.59 a gallon compared with the current and rare "hot deal" of $15.99 a gallon.
Please pass me the salt, thank you!
:thumbup:
J king
Ne oh
Too cool.gotta try that now.. What's the measurements for the two ingredients.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Damn!!!!! :eek:
How much salt to how much vinegar?
Thanks for posting that and I will be using the recipe :thumbup:
shiftdrift
Indianer
Heres some of mine. Picked a bunch of stuff up at a garage sale that was Rusty, put it in vinegar and salt for 3 days, took them out and wiped off with rag, put in soap and water and then wiped off. No wire brushing.
Haveblue
kansas
I should have taken pics, but after reading about this method here before, I tried it on some VERY badly rusted channelocks, and pliers. I used about a quart of white vinegar and a few tablespoons of salt in an aluminum baking pan. I set the pan in the sun to warm it a couple of times, then left it to set in the garage for a week. You could see the foaming action, and the rust just falling off, I am still amazed! I cleaned the pan and soaked them in about the same ratio of water and baking soda. I just pulled them this weekend, and washed them with soapy water. The rust had already taken off the chrome plating, but they arent pitted, and look pretty good! I didnt even use a wire brush on them, and the rust is gone! I havent decided yet, but i may just try polishing them, and see how that goes.
sophijo
Here's another that works. Examples can be found on YouTube. About $9/10 gallons. One part feed grade molasses (Tractor Supply) to nine parts water.
goodboy
Vancouver Canada
i just finished using the same idea to remove the black crust/slag thats on hot rolled steel...
i didnt add salt though.. but ya it worked...and much faster than i thought i would... an afternoon of spraying on the vinegar (keeping the 2'x8' foot sheets for a bench top wet with vinagar) the slag was almost all gone... and what twas left was no problem for my tiny 1/4 sheet sander
I read muriatic acid was the stuff to use...but when I went to home depo and asked if they had any the looked at me like I was a terrorist...lol
Big-Foot
Midlothian, TX
Very cool...
I read on another site, that the ratio of vinegar to salt was controlled by how much salt you could get to dissolve in the vinegar. IE mixing in salt until the vinegar would no longer dissolve the salt.
I have a jeep wrangler with a rusty chassis, I don't want to tear into the whole jeep and try to submerge the chassis, what I would like to have is something that I can spray on and hose off, or just spray it and it turns the rust into a hard coating to protect the steel underneath.. I'm probably dreaming though..
spongerich
Monroe, NY
That's great, plus when you're done, you can use put the salt and vinegar on potato chips so there's no disposal issues.
mayday0017
Houston Texas
Great idea for cleaning inside of rusty motorcycle gas tank, wish I would of known about this when I was a kid and always had problems with filters and what not clogging on my old hand me down dirt bike with the rusted gas tank!
IndyGarage
Indy
The only problem is the smell. My 5 gallon bucket of vinegar/salt practically knocks me down when I open it.
InPrimer
lake Havasu AZ
about muriatic acid,be careful nasty stuff , eats skin, lungs, etc does a great job, but will "flash " into surface rust right away, in other words, dry object asap
Mandres
Cool! Any chemists around to explain exactly what's happening here? What role does the salt play?
mod600
Central Minnesota
Any idea if this would work on Black Oxide coated impact sockets without taking the Black Oxide coating off? I've got some with some surface rust on them.
Lhorn
wow, I was fixin' to throw up about half way through those pictures. Glad I stiffled the urge. Looks like a cool process.
nonhog
Arizona (Tucson)
never heard of the salt part. Thanks for that.:beer:
I did this brand new 454 balancer that has been sitting for 20 years.
Just a day (or two?) in the vinegar bath. Quick wipe down and WD40.
Could have spent more time and made it perfect. As is was good enough.
A
All
For my next trick, I'm making an electrolysis tub, and using vinegar and salt as the electrolyte.
I just need to get it far enough away from the house, but not too near any neighboring properties, to allow enough air space to dilute the hydrogen gas.
And I need the right cartridges for the respirator.
And now I need some rusty metal, 'cause I temporarily ran out with all my other experiments.
NHBandit
East Tennessee
Does anyone know if the vinegar & salt solution will hurt plastic ? I have some old straight razors that were wrapped in newspaper & then stored in a damp basement and the blades have alot of surface rust. Would like to try this but I'm concerned about it hurting the handles. Some of these razors are over 100 years old and have some collector value.
Wingnut65
Tampa Bay, FL
Thanks for posting this procedure. I had learned of the vinegar on GJ a while ago here: Vinegar For Rust Awesome! , but I had never heard about adding salt to the mix. I've got plenty around...
And for the electrolysis, I've used just water in a 5 gallon bucket and kept it in my garage. Never had an issue with fumes. But using vingar and sugar could cause issues...
Mike Miller
La Pine Or.
When your done with the salt vinegar solution you can add a little liquid dish soap to it for a wetting agent and use it for weed killer.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
If you have neighbors, you MAY just want to inform them as to what is going on. I really don't think you would want the SWAT Team and Hazmat to show up thinking that you're cooking some crack :lol_hitti
HTGTS350
I had a neighbour who was cooking crack and when I reported it to the police I got investigated, turns out the cook was selling 2 sorts of crack to the police.
